DSK32-DSK310
SURFACE MOUNT SCHOTTKY BARRIER DIODES
VOLTAGE RANGE: 20 - 100V
CURRENT: 3.0 A
Features
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
High forward surge current capability
High temperature soldering guaranteed:
B
250 C/10 seconds,0.375
” (9.5mm) lead length,
5 lbs. (2.3kg) tension
C
E
Mechanical Data
! Case: JEDEC SOD-123FL molded
plastic body over passivated junction
! Terminals : Plated axial leads,
! solderable per MIL-STD-750, Method 2026
! Polarity : Color band denotes cathode end
! Mounting Position : Any
! Weight:0.0007 ounce, 0.02 grams
SOD-123FL
Dim Min Max Typ
A 3.58 3.72 3.65
3
B 2.72 2.78 2.75
C 1.77 1.83 1.80
D
1
1.02
1.08 1.05
E 0.097 1.03 1.00
H 0.13 0.17 0.15
L
0.53 0.57 0.55
All Dimensions in mm
D
H
L
E
A
Maximum Ratings and Electrical Characteristics
TA = 25C unless otherwise specified
Single phase, half wave, 60Hz, resistive or inductive load. For capacitive load, derate current by 20%.
Characteristic
Symbol DSK32 DSK33 DSK34 DSK35 DSK36 DSK37 DSK38 DSK39 DSK310 Unit
Maximum repetitive peak reverse voltage
VRRM
40
50
60
70
80
90
100
Volts
Maximum RMS voltage
VRMS
14
21
28
35
42
49
56
63
70
Volts
Maximum DC blocking voltage
VDC
40
50
60
70
80
90
100
Volts
Maximum average forward rectified current
I(AV)
3.0
Amp
Peak forward surge current
8.3ms single half sine-wave superimposed on
rated load (JEDEC Method)
IFSM
80.0
Amps
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
at rated DC blocking voltage
IR
TA=25 C
TA=100 C
Operating junction temperature range
Storage temperature range
www.slkormicro.com
0.52
0.55
0.70
0.85
0.5
TJ
TSTG
20.0
10.0
-50 to +125
-50 to +150
-50 to +150
1
Volts
mA
C
C
AVERAGE FORWARD RECTIFIED CURRENT,
AMPERES
DSK32-DSK310
PEAK FORWARD SURGE CURRENT,
AMPERES
FIG. 1- FORWARD CURRENT DERATING CURVE
3
2.4
Single Phase
Half Wave 60Hz
Resistive or
inductive Load
1.8
1.2
DSK32-DSK36
DSK37-DSK310
0.6
50
75
100
125
150
FIG. 2-MAXIMUM NON-REPETITIVE PEAK FORWARD
SURGE CURRENT
80
64
48
32
16
175
8.3ms SINGLE HALF SINE-WAVE
(JEDEC Method)
1
10
AMBIENT TEMPERATURE, C
FIG. 4-TYPICAL REVERSE CHARACTERISTICS
INSTANTANEOUS REVERSE CURRENT,
MILLIAMPERES
INSTANTANEOUS FORWARD
CURRENT,AMPERES
FIG. 3-TYPICAL INSTANTANEOUS FORWARD
CHARACTERISTICS
1
TJ=25 C
PULSE WIDTH=300 µs
1%DUTY CYCLE
DSK32-DSK34
DSK35-DSK36
DSK37-DSK310
0.1
0.01
0.2
0.4
0.6
0.8
1.0
1.1
100
10
TJ=100 C
1
TJ=75 C
0.1
TJ=25 C
0.01
0.001
INSTANTANEOUS FORWARD VOLTAGE,
VOLTS
www.slkormicro.com
100
NUMBER OF CYCLES AT 60 Hz
60
80
PERCENT OF PEAK REVERSE VOLTAGE,%
2
100
很抱歉,暂时无法提供与“DSK34”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.23403
- 200+0.19084
- 600+0.16683
- 3000+0.14323
- 9000+0.13072
- 21000+0.12394
