RLST236A124V
RLST236A124V
    RUILON(瑞隆源)
    SOT23-6
    ESD保护 VRWM=12V VBR(Min)=6V VC=25V Ipp=15A 4通道 SOT23-6
RLST236A124V 数据手册
ELECTRONICS TVS/ESD Arrays RLST236AxxxV Series Circuit Protection System Specifications are subject to change without notice. TVS/ESD Arrays - RLST236AxxxV Series Features • 350 Watts peak pulse power (tp = 8/20μs) • Transient protection for high speed data lines to IEC 61000-4-2 (ESD) ±15kV (air), ±8kV (contact) IEC 61000-4-4 (EFT) 40A (5/50ns) IEC 61000-4-5 (Lightning) 24A (8/20μs) • One device protects one unidirectional line • Two devices protect two high-speed line pairs • Low leakage current • Low operating and clamping voltages • Solid-state EPD TVS process technology Mechanical Characteristics Pinout and Functional Block Diagram • SOT-23-6L package • Molding compound flammability rating: UL 94V-0 • Packaging: Tape and Reel per EIA 481 • Lead Finish: Matte tin • RoHS Compliant Applications • USB Power & Data Line Protection • Ethernet 10BaseT • I2C Bus Protection • Video Line Protection • T1/E1 secondary IC Side Protection • Portable Electronics • Microcontroller Input Protection • WAN/LAN Equipment • ISDN S/T Interface Life Support Note • Not Intended for Use in Life Support or Life Saving Applications • The products shown herein are not designed for use in life sustaining or life saving applications unless otherwise expressly indicated Circuit Protection System Specifications are subject to change without notice. Page:1 TVS/ESD Arrays - RLST236AxxxV Series Absolute Maximum Rating Rating Symbol Value Units Ppk 350 Watts VESD 25 kV Lead Soldering Temperature TK 260 (10 sec.) °C Operating Temperature TJ -55 to +125 °C TSTG -55 to +150 °C Peak Pulse Power (tp =8/20μs) ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Storage Temperature ElectrIcal CharacterlstIcs Per Lin (@ 25°C Unless Otherwise Specified) Type Number Peak Power Dissipation @8/20μS Pppm Reverse Stand-Off Voltage Vrwm Max Peak Pulse Voltage @8/20μS Peak Pulse Current @8/20μS Vc@IPP IPP Reverse Leakage @Vrwm Maximum Capacitance @1MHZ IR@Vrwm Co Max Max W V V A μA pF RLST236A054V 350 5 9.8/13 5/24 5 200 RLST236A124V 350 12 20/25 5/15 1 90 RLST236A154V 350 15 24/29 5/12 1 70 RLST236A244V 350 24 40/44 5/8 1 50 Circuit Protection System Specifications are subject to change without notice. Page:2 TVS/ESD Arrays - RLST236AxxxV Series Typical Characteristics Non-Repetitive Peak Pulse Power vs. Pulse Time Power Derating Curve 110 10 % of Rated Power or I pk PP (kW) 100 Peak Pulse Power - P 1 0.1 90 80 70 60 50 40 30 20 10 0 0.01 0.1 1 10 100 Pulse Duration - t p 0 1000 75 100 A 125 150 o ( C) Clamping Voltage vs. Peak Pulse Current 110 45 Waveform Parameters: tr = 8µs td = 20µs 70 Clamping Voltage - V 80 40 (V) 90 -t e 60 50 40 td = IPP/2 30 Waveform Parameters: tr = 8µs td = 20µs 244V 35 C 100 PP 50 Ambient Temperature - T Pulse Waveform Percent of I 25 (µs) 20 30 154V 25 20 124V 15 054V 10 5 10 0 0 0 5 10 15 20 25 30 0 5 10 15 Peak Pulse Current - I Time (µs) 20 PP 25 30 (A) Forward Voltage vs. Forward Current 5 Forward Voltage - V F (V) 4.5 4 3.5 3 2.5 2 1.5 Waveform Parameters: tr = 8µs td = 20µs 1 0.5 0 0 5 10 15 20 25 Forward Current - I 30 F 35 40 45 (A) Circuit Protection System Specifications are subject to change without notice. Page:3 A A e1 N 2X E/2 D e1 D N 2X E/2 EI 12 E EI E 12 ccc C A TVS/ESD Arrays - RLST236AxxxV Series ccc C 2X N/2 TIPS e1 D EI Package dimension SOT-23-6L 2X E/2 ccc C N EI C E aaa C SEATING PLANE SEATING PLANE e e B C bxN bbb A2 bxN C A-BA2D A bbb GAGE PLANE C A-B D 0.25 A1 C A H A1 bxN bbb H SEE DETAIL (L1) DETAILL A 0.25 DETAIL A L (L1) A bbb C A-B D OR GATE BURRS. 0.25 L Dimensions Inches DIM MILLIMETERS (ANGLES IN DEGREES).Min Nom MinDETAIL A Max 0.90 - 1.45 0.00 - 0.15 0.035 0.045 0.051 0.90 1. CONTROLLING DIMENSIONS ARE IN (ANGLES IN DEGREES). b 0.010 - MILLIMETERS 0.020 0.25 1.15 1.30 - 0.50 AND -B- TO BE DETERMINED AT DATUM c2. DATUMS -A-0.003 0.009 PLANE -H- 0.08 - 0.22 D 0.114 2.80 3. DIMENSIONS0.110 "E1" AND "D" DO NOT INCLUDE MOLD0.122 FLASH, PROTRUSIONS E1 OR GATE BURRS. 0.60 0.063 0.069 1.50 2.90 3.10 1.60 1.75 0.035 SIDE VIEW - A PROTRUSIONS0.000 NCLUDE MOLD FLASH, Max SEE DETAIL 0.057 01 (L1) Millimeters Nom ERMINED AT DATUMAPLANE -H- 0.006 A A2 NOTES: E 0.110 BSC 2.80 BSC e 0.037 BSC 0.95 BSC e1 L 0.075 BSC 0.012 0.018 1.90 BSC 0.024 0.30 0.45 L1 (0.024) (0.60) N 6 6 θ (L1) D 0 A SIDE VIEW NOTES: A2 A CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). 1. CONTROLLING DIMENSIONS ARE IN MILLIMETERS (ANGLES IN DEGREES). NOTES: 2. DATUMS -AAND -B- TO AT DATUM PLANE H BE DETERMINED -H1. 2.CONTROLLING ARE INTO MILLIMETERS (ANGLES IN DEGREES). DATUMS DIMENSIONS BE DETERMINED AT DATUM PLANE -H-A- AND -B01 A1 2. "E1" DATUMS BE DETERMINED DATUMPROTRUSIONS PLANE -H-B- TO 3. DIMENSIONS AND-A"D"AND DO NOT INCLUDE MOLD AT FLASH, 3. DIMENSIONS "E1" AND "D" DO NOT INCLUDE c MOLD FLASH, PROTRUSIONS bxN OR GATE BURRS. GAGE "E1" AND 3. DIMENSIONS "D" DO NOT INCLUDE MOLD FLASH, PROTRUSIONS OR GATE BURRS. PLANE 1. C L 0.25 ASEE DETAIL A SIDE VIEW NOTES: H GAGE PLANE GAGE PLANE C A-B D c aaa C DETAIL A A D SIDE VIEW D SEATING 0.25 PLANE SEE DETAIL A2 SEE DETAIL H GAGE PLANE E A1 B C A-B D EI D 2X N/2 TIPS aaa C 12 A 1 N aaa C SEATING PLANE 2X N/2 TIPS A2 D B 12 ccc CD e1 D e N 2XBE/2 A E e1 2X N/2 TIPS e 0° aaa bbb ccc - ° 0.10 0.008 0.20 0.008 Circuit Protection System 10° 0.004 0.60 10° 0.20 Specifications are subject to change without notice. Page:4 TVS/ESD Arrays - RLST236AxxxV Series Recommended soldering footprint X DIMDIM (C) G C G P X Y Z Z Y P DIMENSIONS INCHES MILLIMETERS MILLIMETERS INCHES DIMENSIONS (0.098) (.098) .0550.055 .0370.037 .0240.024 .0430.043 .1410.141 C G P X Y Z (2.50) (2.50) 1.40 1.40 0.95 0.95 0.60 0.60 1.10 1.10 3.60 3.60 NOTES: 1. THIS LAND PATTERN IS FOR REFERENCE PURPOSES ONLY. CONSULT YOUR MANUFACTURING GROUP TO ENSURE YOUR COMPANY'S MANUFACTURING GUIDELINES ARE MET. Part Number Code R L LOGO S T 2 Package SOT-23-6L 3 6 A 0 Straight foot overhanging 5 Vrwm:5V 4 V V= Unidirectional C= Bidirectional Protects 4 Lines Circuit Protection System Specifications are subject to change without notice. Page:5 TVS/ESD Arrays - RLST236AxxxV Series Ordering Information P0 t D t D P0 P2 P2 Tolerance on Tape. ± 0.2 ± 0.2 Tolerance on Tape. E Top Cover Tape Tape Top Cover Pin 1 Pin 1 A0 K0 E A0 F F W W K0 B0 P B0 P SPECIFICATIONS SPECIFICATIONS REEL DIA.DIA. REEL 178mm (7”)(7”) 178mm TAPE TAPE A0 A0 B0 B0 k0 k0 D D E E F F W W P0 P0 P2 P2 P P tmax tmax WIDTh WIDTh 8mm ± 0.10 3.203.20 ± 0.10 1.651.65 ± 0.10 1.501.50 ± 0.10 1.751.75 ± 0.10 3.503.50 ± 0.05 8.008.00 ± 0.30 4.004.00 ± 0.10 2.002.00 ± 0.05 4.004.00 ± 0.10 8mm3.203.20 ± 0.10 ± 0.10 ± 0.10 ± 0.10 ± 0.10 ± 0.05 ± 0.30 ± 0.10 ± 0.05 ± 0.100.250.25 NOTES NOTES 1. 2. 3. 4. Dimensions are in millimeters. 1. Dimensions are in millimeters. Surface mount product is taped and and reeled in accordance withwith EIA-481. 2. Surface mount product is taped reeled in accordance EIA-481. 3. 4. Ordering Information Warehouse Storage Conditions of Products Part Number Package Min. Order Qty. RLST236AxxxV SOT-23-6L 3000pcs Storage Conditions: 1. Storage Temperature: -10°C~+40°C 2. Relative Humidity:≤75%RH 3. Keep away from corrosive atmosphere and sunlight. 4. Period of Storage: 1 year Circuit Protection System Specifications are subject to change without notice. Page:6 RuiLongYuan Electronics Co., Ltd. · Reproducing and modifying information of the document is prohibited without permission from Ruilongyuan International Inc. · Ruilongyuan International Inc. reserves the rights to make changes of the content herein the document anytime without notification. Please refer to our website for the latest document. · Ruilongyuan International Inc. disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. · Ruilongyuan International Inc. does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. · Applications shown on the herein document are examples of standard use and operation. Customers are responsible in comprehending the suitable use in particular applications.Ruilongyuan International Inc. makes no representation or warranty that such applications will be suitable for the specifed use without further testing or modifcation. · The products shown herein are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment,aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own risk and agree to fullyindemnify Ruilongyuan International Inc. for any damages resulting from such improper use or sale. Circuit Protection System Specifications are subject to change without notice. Page:7
RLST236A124V 价格&库存
很抱歉,暂时无法提供与“RLST236A124V”相匹配的价格&库存,您可以联系我们找货
RLST236A124V
  • 5+1.36160
  • 50+1.07856
  • 150+0.95725
  • 500+0.80590
  • 3000+0.73851
  • 6000+0.69807
库存:10
RLST236A124V
  • 5+1.23553
  • 50+0.97869
  • 600+0.73128
  • 1200+0.72031
  • 3000+0.67012
库存:2930
