KBL4005-KBL410
Silicon Bridge Rectifiers
KBL
FEATURES
Dim
Min
Max
A
18.85
19.25
B
15.70
16.10
Rating to 1000V PRV
B1
14.65
15.05
C
5.90
6.30
z
Surge overload rating to 150 Amperes peak
C1
3.95
4.25
E
Ø1.20
z
Ideal for printed circuit board
z
Reliable low cost construction utilizing molded
z
F
F1
4.00min
K
plastic technique results in inexpensive product
z
Ø1.40
19.00min
4.70
5.30
All Dimensions in mm
Lead solderable per MIL-STD-202 method 208
Maximum Ratings (@TA = 25°C unless otherwise specified)
Characteristic
Symbol
KBL
KBL
KBL
KBL
KBL
KBL
KBL
KBL
4005
401
402
403
404
406
408
410
UNITS
Maximum recurrent peak reverse voltage
VRRM
50
100
200
300
400
600
800
1000
V
Maximum RMS voltage
VRMS
35
70
140
210
280
420
560
700
V
Maximum DC blocking voltage
VDC
50
100
200
300
400
600
800
1000
V
Maximum average forward Output current
@TA=50℃
IF(AV)
4.0
A
IFSM
150
A
I²t
93
A²S
Peak forward surge current
8.3ms single half-sine-wave
superimposed on rated load
I²t Rating for fusing @Tj=25℃
Thermal Characteristics
Characteristic
Symbol
Typical thermal resistance
Operating junction temperature range
Storage temperature range
KBL
KBL
KBL
KBL
KBL
KBL
KBL
KBL
4005
401
402
403
404
406
408
410
RθJ A
RθJC
19
Rθ JL
2.4
0.8
UNITS
℃/W
TJ
- 55 ---- + 150
TSTG
- 55 ---- + 150
Electrical Characteristics (@TA = 25°C unless otherwise specified)
Characteristic
Symbol
Maximum instantaneous forward voltage
@2.0A
VF
KBL
KBL
KBL
KBL
KBL
KBL
KBL
4005
401
402
403
404
406
408
410
1.0
UNITS
V
1.1
@4.0A
Maximum
KBL
reverse
current
@TA=25℃
at rated DC blocking voltage @TA=100℃
Revision:20170701-P1
IR
ht t p : //
10
μA
1.0
mA
www.lgesemi .c o m
mail:lge@lgesemi.com
KBL4005-KBL410
RATINGS AND CHARACTERISTICS CURVES
(TA=25℃ unless otherwise noted)
FIG. 2 TYPICAL REVERSE CHARACTERISTICS
FIG.1 FORWARD CURRENT DERATING CURVE
100
AVERAGE FORWARD A
CURRENT (A)
4
3
2
RESISTIVE OR
INDUCTIVELOAD
WITH HEATSINK
1
60
80
100
120
AMBIENT TEMPERATURE
140
160
(oC)
INSTANTANEOUS REVERSE CURRENT (μA)
5
10
TJ=125℃
1
TJ=25℃
0.1
80
100
120
140
PERCENT OF RATED PEAK REVERSE VOLTAGE (%)
FIG. 3 MAXIMUM NON-REPETITIVE FORWARD
SURGE CURRENT
250
FIG. 4 TYPICAL FORWARD CHARACTERISTICS
225
10
200
175
150
125
100
75
50
25
10
100
1000
NUMBER OF CYCLES AT 60 Hz
INSTANTANEOUS FORWARD CURRENT (A)
PEAK FORWARD SURGE CURRENT (A)
40
1
0.1
0.4
0.6
0.8
1
1.2
1.4
1.6
FORWARD VOLTAGE (V)
Device
Package
Shipping
KBL4005--KBL410
KBL
500 Units/Box
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“KBL410”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+1.49519
- 50+1.17414
- 150+1.03655
- 国内价格
- 5+1.64776
- 50+1.29395
- 150+1.14232
- 500+0.95267
- 2500+0.86843
- 5000+0.81789
