2N3904(NPN)
TO-92 Bipolar Transistors
TO-92
1. EMITTER
2. BASE
3. COLLECTOR
Features
NPN silicon epitaxial planar transistor for switching and
Amplifier applications
As complementary type, the PNP transistor 2N3906 is
Recommended
This transistor is also available in the SOT-23 case with
the type designation MMBT3904
MAXIMUM RATINGS (TA=25℃ unless otherwise noted)
Symbol
Parameter
Value
Units
VCBO
Collector-Base Voltage
60
V
VCEO
Collector-Emitter Voltage
40
V
VEBO
Emitter-Base Voltage
6
V
0.2
A
0.625
W
Dimensions in inches and (millimeters)
IC
Collector Current -Continuous
PC
Collector Power Dissipation
TJ
Junction Temperature
150
Tstg
Storage Temperature
-55-150
ELECTRICAL CHARACTERISTICS (Tamb=25℃ unless otherwise specified)
Parameter
Symbol
Test
conditions
MIN
TYP
MAX
UNIT
Collector-base breakdown voltage
IC=10μA, IE 0
V(BR)CBO
60
V
Collector-emitter breakdown voltage
IC= 1mA , IB 0
V(BR)CEO
40
V
Emitter-base breakdown voltage
IE= 10μA, IC 0
V(BR)EBO
6
V
Collector cut-off
current
VCB=60V, IE 0
ICBO
0.1
μA
Collector cut-off
current
VCE= 40V, IB 0
ICEO
0.1
μA
0.1
μA
Emitter cut-off
VEB= 5V, IC 0
IEBO
current
DC current gain
hFE1
VCE= 1V, IC 10mA
100
hFE2
VCE= 1V, IC 50mA
60
hFE3
VCE= 1V, IC 100mA
400
30
Collector-emitter saturation voltage
IC=50mA, IB 5mA
VCE(sat)
0.3
V
Base-emitter saturation voltage
IC=50mA, IB 5mA
VBE(sat)
0.95
V
Transition frequency
fT
VCE=20V,I
=C 10mA,f
= 100MHz
Delay Time
td
VCC=3V,VBE=0.5V,
35
ns
Rise Time
tr
IC=10mA,IB1=1mA
35
ns
Storage Time
ts
VCC=3V, IC=10mA
200
ns
Fall Time
tf
IB1=IB2=1mA
50
ns
CLASSIFICATION
Rank
Range
Revision:20170701-P1
OF
300
MHZ
hFE1
O
Y
G
100-200
200-300
300-400
ht t p : //
www.lgesem i .c o m
mail:lge@lgesemi.com
2N3904(NPN)
Typical Characteristics
ht t p : //
www.lgesem i .c o m
很抱歉,暂时无法提供与“2N3904”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.17050
- 50+0.08492
- 1000+0.06424
- 国内价格
- 20+0.17394
- 100+0.17133
- 400+0.13830
- 1000+0.10890
- 国内价格
- 20+0.18976
- 200+0.15088
- 1000+0.11880
- 2000+0.10584
- 10000+0.09461
- 20000+0.08856
