MMBT3904
NPN SWITCHING TRANSISTOR
1. BASE
2. EMITTER
3. COLLECTOR
FEATURES
z
Epitaxial planar die construction.
z
Complementary PNP type available
A
SOT-23
E
K
(MMBT3906).
z
z
Min
Max
A
2.70
3.10
B
1.10
1.50
C
Collector Current Capability ICM =200mA.
Collector-emitter Voltage VCEO=40V.
D
J
D
G
H
C
APPLICATIONS
z
B
Dim
1.0 Typical
0.4 Typical
E
0.35
0.48
G
1.80
2.00
H
0.02
0.1
J
K
0.1 Typical
2.20
2.60
All Dimensions in mm
General switching and amplification
ORDERING INFORMATION
Type No.
Marking
MMBT3904
1AM
Package Code
SOT-23
MAXIMUM RATING @ Ta=25℃ unless otherwise specified
SYMBOL
PARAMETER
CONDITIONS
VCBO
collector-base voltage
open emitter
60
V
VCEO
collector-emitter voltage
open base
40
V
VEBO
emitter-base voltage
open collector
6
V
IC
collector current (DC)
100
mA
ICM
peak collector current
200
mA
IBM
peak base current
100
mA
Ptot
total power dissipation
250
mW
Tstg
storage temperature
-65 to +150
°C
Tj
junction temperature
150
°C
Tamb
operating ambient temperature
-65 to +150
°C
ht t p : //
Revision:20170701-P1
Tamb≤25°C
Value
www.lgesemi .c o m
UNIT
mail:lge@lgesemi.com
MMBT3904
ELECTRICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
SYMBOL
PARAMETER
CONDITIONS
MIN.
MAX.
ICBO
collector cut-off current
IEBO
UNIT
IE = 0; VCB = 30 V
50
nA
emitter cut-off current
IC = 0; VEB = 6 V
50
nA
hFE
DC current gain
VCE = 1 V;
IC= 0.1mA
IC = 1mA
IC = 10mA
IC = 50mA
IC = 100mA
60
80
100
60
30
300
VCE(sat)
collector-emitter saturation
voltage
IC = 10mA; IB = 1mA
200
mV
IC = 50mA; IB = 5mA
300
mV
VBE(sat)
base-emitter saturation voltage
IC = 10mA; IB = 1mA
650
850
mV
IC = 50mA; IB = 5mA
950
mV
Cobo
Output Capacitance
IE = Ie= 0; VCB= 5V;
f = 1MHz
4
pF
Cibo
Input Capacitance
IC = Ic = 0; VBE=500mV;
f =1MHz
8
pF
fT
transition frequency
IC =10mA; VCE =20V;
f =100MHz
300
MHz
F
noise figure
IC=100mA; VCE =5V;
RS =1kΩ;f =10Hz to15.7kHz
5
dB
35
ns
35
ns
200
ns
50
ns
Switching times (between 10% and 90% levels);
td
delay time
tr
rise time
ts
storage time
tf
fall time
Note
ICon=10mA; IBon =1mA;
IBoff = -1mA
Pulse test: tp≤300 ms; d≤0.02.
ht t p : //
www.lgesemi .c o m
MMBT3904
TYPICAL CHARACTERISTICS @ Ta=25℃ unless otherwise specified
PACKAGE OUTLINE
Device
Package
Shipping
MMBT3904
SOT-23
3000/Tape&Reel
ht t p : //
www.lgesemi .c o m
很抱歉,暂时无法提供与“MMBT3904 1AM”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.08682
- 600+0.06811
- 1200+0.06709
- 3000+0.05564
- 国内价格
- 50+0.11276
- 500+0.09234
- 3000+0.07874
- 6000+0.07193
- 24000+0.06599
- 51000+0.06275
