(6'=3.3C
7UDQVLHQW9oOWDJH 6XSSUeVVRUVfor ESD protection
62'3ODVWLF(QFDSVXODWH(6'3URWHFWLRQDLRGHV
DESCRIPTION
The ESD5Z3.3C is designed to protect voltage sensitive components from ESD and transient voltage
events. Excellent clamping capability, low leakage, and fast response time, make these parts ideal for
ESD protection on designs where board space is at a premium.This device has been specifically
designed to protect sensitive components which are connected to data and transmission lines from
overvoltage caused by ESD (electrostatic discharge), CDE (Cable Discharge Events),and EFT
(electrical fast transients).
Features
IEC61000-4-2 ( ESD) ± 30KV (Air)
± 30KV(contact)
IEC61000-4-4 ( EFT) 40A (5/50ns)
Peak power dissipation: 60W (8/20us)
Protects one directional I/O line
Low clamping voltage
Working voltages : 3.3V
Low leakage current
3in Configuration
&LUFXLW'LDJUDP
2
1
0DUNLQJ
Applications
High Speed Line :USB1.0/2.0, VGA, DVI, SDI,
Serial and Parallel Ports
Notebooks, Desktops, and Servers Cellular
handsets and accessories
Portable Instrumentation
Projection TV
Peripherals
Mechanical Characteristics
Package: SOD-523
Flammability Rating: UL 94V-0
Terminals: Gold plated, solderable per
MIL-STD-750, method 2026
Packaging: Tape and Reel
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 30
± 30
KV
Peak Pulse Power (8/20μs)
PPP
60
W
Operating Temperature
TOPT
−40 to +150
°C
Storage Temperature
TSTG
−40 to +150
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
The above data above is for reference only.
http://www.microdiode.com
Rev:2024A2
Page :1
(6'=3.3C
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Parameter
Test Condition
Min
Typ
Max
Units
3.3
V
IR
Reverse Working
Voltage
Reverse Breakdown
Voltage
Reverse Leakage
Current
VRWM = 3.3V
1.0
μA
VC
Clamping Voltage
IPP = 1A, tp = 8/20μs
6.5
V
VC
Clamping Voltage
IPPmax = 5A , tp = 8/20μs
12.0
V
VCTLP
TLP Clamping
Voltage
IPP = 16A
IEC61000-4-2 Level 4 equivalent
(±8kV Contact, ±15kV Air)
CJ
Junction
Capacitance
VR = 0V, f = 1MHz
VRWM
VBR
IT = 1mA
3.6
V
9
V
16.5
pF
The above data are for reference only.
Rev:2024A2
Page :2
(6'=3.3C
ELECTRICAL CHARACTERISTICS CURVE
Rev:2024A2
Page :3
(6'=3.3C
Outlitne Drawing
SOD-523 Package Outline Dimensions
6\PERO
A
A1
b
c
D
E
E1
E2
L
Κ
'LPHQVLRQV,Q0LOOLPHWHUV
0LQ
0D[
0.510
0.770
0.500
0.700
0.250
0.350
0.080
0.150
0.750
0.850
1.100
1.300
1.500
1.700
0.200 REF
0.010
0.070
7° REF
'LPHQVLRQV,Q,QFKHV
0D[
0LQ
0.020
0.031
0.020
0.028
0.010
0.014
0.003
0.006
0.030
0.033
0.043
0.051
0.059
0.067
0.008 REF
0.001
0.003
7° REF
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-523
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
178
3000
183×188×80
7'
QTY/Box
(pcs)
18,000
Carton Size
(mm)
Q'TY/Carton
(pcs)
386×265×215
108,000
Rev:2024A2
Page :4
很抱歉,暂时无法提供与“ESD5Z3.3C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.16233
- 200+0.12798
- 600+0.10887
- 3000+0.08576
- 9000+0.07582
- 21000+0.07053
- 国内价格
- 1+0.36750
- 200+0.12180
- 1500+0.07655
- 3000+0.06080
- 国内价格
- 20+0.14880
- 300+0.11731
- 1200+0.09979
