SS32F THRU SS3200F
Reverse Voltage - 20 to 200 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
SMAF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.106(2.70)
0.094(2.40)
0.063 (1.60)
0.051 (1.30)
0.146(3.70)
0.130(3.30)
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
0.047(1.20)
0.035(0.90)
260 °C/10 seconds at terminals
0.008(0.20)
0.005(0.12)
0.047(1.20)
0.031(0.80)
0.193(4.90)
0.173(4.40)
Mechanical Data
Case: JEDEC SMAF molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end
Mounting Position: Any
Weight : 0.00095 ounce, 0.027 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
SYMBOLS
VRRM
VRMS
VDC
MDD
SS32F
MDD
SS33F
MDD
SS34F
MDD
SS35F
MDD
SS36F
MDD
SS38F
MDD
SS310F
MDD
SS3150F
MDD
SS3200F
UNITS
30
21
40
28
50
35
60
42
80
56
100
70
150
105
200
140
V
V
40
50
60
80
100
150
200
V
Maximum average forward rectified current
I(AV)
3.0
A
Peak forward surge current 8.3ms single half sinewave
superimposed onrated load (JEDEC Method)
IFSM
80
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
TA=25℃
at rated DC blocking voltage
TA=100℃
Typical junction capacitance (NOTE 1)
0.55
IR
CJ
250
0.70
0.85
0.5
5.0
180
Typical thermal resistance (NOTE 2)
RJA
RθJC
70
18
Operating junction temperature range
TJ
TSTG
-55 to +125
-55 to +150
Storage temperature range
0.95
V
0.3
3.0
mA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A3
Page :1
SS32F THRU SS3200F
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Fig.1 Forward Current Derating Curve
3.5
10
4
10
3
10
2
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
3.0
TJ=100°C
TJ=75°C
SS32F/SS36F
10
SS38F-SS320F
1
TJ=25°C
Case Temperature (°C)
60
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
TTJJ==225
5°°CC
1000
500
Junction Capacitance (pF)
Instaneous Forward Current (A)
10
1.0
SS32F/SS345F
SS36F
SS38F/SS312F
SS315F/SS320F
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
SS32AF~SS345AF
SS36AF~SS320AF
10
1.8
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
100
Fig.5- Typical Transient Thermal Impedance
100
00
10
1
Reverse Voltage (V)
Instaneous Forward Voltage (V)
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2024A3
Page :2
SS32F THRU SS3200F
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
SMAF
E
F
B
A
Carrier width
Carrier length
Carrier depth
Sprocket hole
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
W
P
D2
T
D1
C
W1
D
2.80
4.75
1.42
1.50
178.00
54.40
13.00
1.75
5.05
4.00
4.00
2.00
0.30
8.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
SMAF
REEL SIZE
7"
REEL
(pcs)
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER
BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
CARTON
(pcs)
APPROX.
GROSS WEIGHT
(kg)
3,000
4.0
6,000
210*208*203
178
400*265*400
120,000
10.0
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
1.8
0.071
B
C
1.6
3.8
0.150
D
2.2
0.087
E
5.4
0.213
0.063
Rev:2024A3
Page :3
很抱歉,暂时无法提供与“SS34F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.26126
- 300+0.21156
- 1200+0.18394
- 3000+0.14008
- 国内价格
- 20+0.27646
- 200+0.22388
- 600+0.19465
- 3000+0.14823
- 9000+0.13305
- 21000+0.12487
- 国内价格
- 20+0.27490
- 200+0.22200
- 600+0.19290
- 3000+0.14680
- 9000+0.13180
- 21000+0.12370
- 国内价格
- 1+0.64680
- 200+0.21450
- 1500+0.13420
- 3000+0.10681
- 国内价格
- 500+0.14294
- 1000+0.12430
