SS14F
SS14F
    MDD(辰达半导体)
    SMAF
    肖特基二极管 VR=40V IF=1A VF=0.55V IR=500uA
SS14F 数据手册
SS12F THRU SS1200F Reverse Voltage - 20 to 200 Volts Forward Current - 1.0 Ampere SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER Features SMAF  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications  Metal silicon junction,majority carrier conduction  Low power loss,high efficiency 0.106(2.70) 0.094(2.40) 0.063 (1.60) 0.051 (1.30)  Built-in strain relief,ideal for automated placement 0.146(3.70) 0.130(3.30)  High forward surge current capability  High temperature soldering guaranteed: 260 °C/10 seconds at terminals 0.047(1.20) 0.035(0.90) 0.008(0.20) 0.005(0.12) 0.047(1.20) 0.031(0.80) Mechanical Data 0.193(4.90) 0.173(4.40) Case: JEDEC SMAF molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Color band denotes cathode end Mounting Position: Any Weight : 0.00095ounce, 0.027grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage VRRM Maximum RMS voltage Maximum DC blocking voltage VRMS Maximum average forward rectified current at TL(see fig.1) Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 1.0A Maximum DC reverse current at rated DC blocking voltage TA=25℃ TA=100℃ Typical junction capacitance (NOTE 1) VDC MDD SS13F MDD SS14F MDD SS15F MDD SS16F MDD SS18F MDD SS110F MDD SS1150F MDD SS1200F UNITS 20 14 20 30 21 30 40 28 40 50 35 50 60 42 60 80 56 80 100 70 100 150 105 150 200 140 200 V V V I(AV) 1.0 A IFSM 25 A VF 0.55 CJ RJA Operating junction temperature range TJ TSTG 0.70 0.3 10.0 IR Typical thermal resistance (NOTE 2) Storage temperature range MDD SS12F 110 0.85 0.90 V 0.2 5.0 80 0.1 2.0 mA pF ℃/W 95.0 -55 to +125 -55to +150 ℃ -55to +150 ℃ Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 SS12F THRU SS1200F Reverse Voltage - 20 to 200 Volts Forward Current - 1.0 Ampere Typical Characterisitics Fig.2 Typical Reverse Characteristics Fig.1 Forward Current Derating Curve Instaneous Reverse Current ( μA) 1.0 Average Forward Current (A) 0.8 Single Phase Half Wave 60Hz Resistive or inductive Load 0.6 0.4 SS12F-SS14F SS16F-SS1200F 0.2 0 0 25 50 75 100 125 150 10 4 10 3 10 2 TJ=100°C TJ=75°C 101 TJ=25°C 0 10 0 175 Case Temperature (°C) 20 40 60 80 100 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Fig.4 Typical Junction Capacitance 500 20 TJ=25°C 200 1.0 Junction Capacitance (pF) Instaneous Forward Current (A) 10 SS12F/SS14F SS16F SS18F/SS112F SS115F/SS120F 0.1 0 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 100 50 SS12F/SS14F 20 SS16F-SS120F 10 1.8 0.1 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 25 1000 20 15 10 05 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 Number of Cycles at 60Hz 100 Transient Thermal Impedance(°C/W) Peak Forward Surage Current (A) 100 Reverse Voltage (V) Instaneous Forward Voltage (V) 00 10 1 100 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 SS12F THRU SS1200F Reverse Voltage - 20 to 200 Volts Forward Current - 1.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance A B C d D D1 D2 E F P P0 P1 T W W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 SMAF E F B A Carrier width Carrier length Carrier depth Sprocket hole 7" Reel outside diameter 7" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width Reel width W P D2 T D1 C W1 D 2.80 4.75 1.42 1.50 178.00 54.40 13.00 1.75 5.05 4.00 4.00 2.00 0.30 8.00 12.30 Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE SMAF REEL SIZE 7" REEL (pcs) COMPONENT SPACING (m/m) BOX (pcs) INNER BOX (m/m) REEL DIA, (m/m) CARTON SIZE (m/m) CARTON (pcs) APPROX. GROSS WEIGHT (kg) 3,000 4.0 6,000 210*208*203 178 400*265*400 120,000 10.0 Suggested Pad Layout Symbol http://www.microdiode.com Unit (mm) Unit (inch) A 1.8 0.071 B C 1.6 3.8 0.150 D 2.2 0.087 E 5.4 0.213 0.063 Rev:2024A2 Page :3
SS14F 价格&库存
很抱歉,暂时无法提供与“SS14F”相匹配的价格&库存,您可以联系我们找货
SS14F
  • 1000+0.06215
  • 3000+0.05345
库存:3675
SS14F
  • 50+0.10652
  • 600+0.08514
  • 1200+0.08386
  • 3000+0.06821
库存:6685
SS14F
  • 1+0.06560
  • 3000+0.05220
库存:8872
SS14F
  • 20+0.09053
库存:20
SS14F
  • 5+0.04890
  • 50+0.04650
  • 150+0.04430
库存:612
