S3MC
S3MC
    MDD(辰达半导体)
    SMC(DO-214AB)
    VR=1000V IF=3A VF=1.1V IR=5uA
S3MC 数据手册
S3AC THRU S3MC Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Ampere SURFACE MOUNT GENERAL RECTIFIER Features DO-214AB/SMC  The plastic package carries Underwriters Laboratory Flammability Classification 94V-0  For surface mounted applications 0.245(6.22) 0.220(5.59) 0.126 (3.20) 0.108 (2.75)  Low reverse leakage  Built-in strain relief,ideal for automated placement  High forward surge current capability 0.280(7.11) 0.260(6.60)  High temperature soldering guaranteed: 250 °C/10 seconds at terminals 0.012(0.305) 0.006(0.152) 0.103(2.62) 0.079(2.06) Mechanical Data 0.063(1.60) 0.035(0.90) 0.008(0.203)MAX. 0.320(8.13) 0.305(7.60) Case: JEDEC DO-214AB/SMC molded plastic body Terminals: Solderable per MIL-STD-750,Method 2026 Polarity: Polarity symbol marking on body Mounting Position: Any Weight : 0.0077 ounce, 0.22grams Dimensions in inches and (millimeters) Maximum Ratings And Electrical Characteristics Ratings at 25 C ambient temperature unless otherwise specified. Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%. Parameter SYMBOLS Marking Code Maximum repetitive peak reverse voltage Maximum RMS voltage Maximum DC blocking voltage Maximum average forward rectified current Peak forward surge current 8.3ms single half sine-wave superimposed onrated load (JEDEC Method) Maximum instantaneous forward voltage at 3.0A Maximum DC reverse current at rated DCblocking voltage TA=25℃ TA=125℃ Typical junction capacitance (NOTE 1) Typical thermal resistance (NOTE 2) VRRM VRMS VDC MDD S3AC MDD S3BC MDD S3DC MDD S3GC MDD S3JC MDD S3KC MDD S3MC UNITS 50 35 50 100 70 100 200 140 200 400 280 400 600 420 600 800 560 800 1000 700 1000 V V V I(AV) 3.0 A IFSM 90 A VF 1.0 V IR 5 100 μA 40 pF 40 16 ℃/W CJ RJA RθJC Operating junction and storage temperature range TJ,TSTG -55 to +150 ℃ Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C. 2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas http://www.microdiode.com Rev:2024A2 Page :1 S3AC THRU S3MC Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Ampere Typical Characterisitics Fig.1 Forward Current Derating Curve Instaneous Reverse Current(μ A) Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.0 1.0 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 175 100 TJ=125°C 10 1.0 TJ=25°C 0.1 00 Case Temperature (°C) 20 40 60 80 100 Fig.4 Typical Junction Capacitance 10 TJ=25°C Junction Capacitance (pF) Instaneous Forward Current (A) 140 percent of Rated Peak Reverse Voltage (%) Fig.3 Typical Forward Characteristic 1.0 0.1 120 TJ=25°C 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 100 10 1 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 144 Peak Forward Surage Current (A) 126 108 90 72 54 36 18 00 8.3 ms Single Half Sine Wave (JEDEC Method) 1 10 100 Number of Cycles The curve above is for reference only. http://www.microdiode.com Rev:2024A2 Page :2 S3AC THRU S3MC Reverse Voltage - 50 to 1000 Volts Forward Current - 3.0 Ampere Packing information unit:mm P0 P1 d Item Symbol Tolerance SMC Carrier width Carrier length Carrier depth Sprocket hole 13" Reel outside diameter 13" Reel inner diameter Feed hole diameter Sprocket hole position Punch hole position Punch hole pitch Sprocket hole pitch Embossment center Overall tape thickness Tape width A B C d D D1 D2 E F P P0 P1 T W Reel width W1 0.1 0.1 0.1 0.05 2.0 min 0.5 0.1 0.1 0.1 0.1 0.1 0.1 0.3 1.0 6.15 8.41 2.42 1.50 330.00 50.00 13.00 1.75 7.50 8.00 4.00 2.00 0.25 16.00 16.50 E F B A W P D2 T D1 C W1 D Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above. Reel packing PACKAGE REEL SIZE REEL (pcs) COMPONENT SPACING (mm) SMC 13" 3,000 4.0 INNER BOX (mm) REEL DIA, (mm) 190*190*41 330 BOX (pcs) 6000 CARTON SIZE (mm) 365*365*340 CARTON (pcs) 42000 APPROX. GROSS WEIGHT (kg) 14.0 Suggested Pad Layout http://www.microdiode.com Symbol Unit (mm) A 4.3 0.170 B 0.160 C 4.1 7.9 0.311 D 3.8 0.150 E 12 0.472 Unit (inch) Rev:2024A2 Page :3
很抱歉,暂时无法提供与“S3MC”相匹配的价格&库存,您可以联系我们找货
S3MC
    • 10+0.43996
    • 100+0.35581
    • 600+0.31373
    • 1200+0.30902
    • 3000+0.23869
    库存:3614
    S3MC
      • 1+0.13144
      • 10+0.12084
      • 30+0.11872
      • 100+0.11236
      库存:4
      S3MC
      • 1+0.40480
      • 200+0.26070
      • 1500+0.22770
      • 3000+0.20130
      库存:7936
      S3MC
      • 10+0.47970
      • 100+0.38500
      • 300+0.33920
      • 3000+0.25790
      • 6000+0.23060
      • 9000+0.21700
      库存:8453
