S10AC THRU S10MC
Reverse Voltage - 50 to 1000 Volts
Forward Current - 10.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.108 (2.75)
Low reverse leakage
Built-in strain relief,ideal for automated placement
High forward surge current capability
0.280(7.11)
0.260(6.60)
High temperature soldering guaranteed:
250 °C/10 seconds at terminals
0.012(0.305)
0.006(0.152)
0.103(2.62)
0.079(2.06)
Mechanical Data
0.063(1.60)
0.035(0.90)
0.008(0.203)MAX.
0.320(8.13)
0.305(7.60)
Case: JEDEC DO-214AB/SMC molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body
Mounting Position: Any
Weight : 0.0077 ounce, 0.22 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 10.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
VRRM
VRMS
VDC
MDD
S10AC
MDD
S10BC
MDD
S10DC
MDD
S10GC
MDD
S10JC
MDD
S10KC
MDD
S10MC
UNITS
50
35
50
100
70
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
100
I(AV)
10.0
A
IFSM
200
A
VF
1.0
V
IR
CJ
RθJA
TJ,TSTG
5
100
100
10
-55 to +150
μA
pF
℃/W
Note:1.Measured at 1 MHz and applied reverse voltage of 4 V D.C
2.P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
http://www.microdiode.com
Rev:2024A2
Page :1
S10AC THRU S10MC
Typical Characterisitics
Fig.1 Forward Current Derating Curve
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current(μ A)
14
Average Forward Current (A)
12
10
8.0
6.0
4.0
2.0
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
175
100
TJ=125°C
10
1.0
TJ=25°C
0.1
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
10
TJ=25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
100
1.0
TJ=25°C
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
1.8
10
1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.6 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
240
200
160
120
80
40
00
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
S10AC THRU S10MC
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
BOX
(pcs)
6000
CARTON
SIZE
(mm)
365*365*340
CARTON
(pcs)
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“S10MC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.64820
- 100+0.54151
- 600+0.44817
- 1200+0.44145
- 3000+0.29606
- 国内价格
- 5+0.70530
- 50+0.58540
- 150+0.52750
- 500+0.48410
- 3000+0.31980
- 6000+0.30240
- 国内价格
- 500+0.28589
- 1000+0.26103
- 国内价格
- 1+0.52910
- 200+0.34210
- 1500+0.29700
- 3000+0.26400
- 国内价格
- 5+0.70713
- 50+0.59074
- 150+0.53261
- 500+0.48892
- 3000+0.32298
- 6000+0.30548
- 国内价格
- 3+0.61370
- 100+0.49090
- 300+0.42860
- 3000+0.37500
- 9000+0.35070
- 21000+0.33320
