SDxxC Series
Bi-directional TVS Diodes
SOD-323 Plastic-Encapsulate ESD Protection Diodes
DESCRIPTION
The SDxxC Series is designed for applications requiring transient overvoltage protection
capability. They are intended for use in voltage and ESD sensitive equipment such as computers,
printers, business machines, communication systems, medical equipment and other applications.
These devices are ideal for situations where board space is at a premium.
This series has been specifically designed to protect sensitive components which are connected
to power,data and transmission lines from overvoltage caused by ESD(electrostatic discharge),
CDE (Cable Discharge Events),and EFT (electrical fast transients).
Features
Pin Configuration
350 Watts Peak Pulse Power per (8/20μs)
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Protects one I/O line (bidirectional)
Low clamping voltage
Low leakage current
Working voltages : 3V, 5V, 8V, 12V, 15V, 18V,
20V,24V,36V
Circuit Diagram
1
Meets MSL 1 Requirements
Applications
Cell Phone Handsets and Accessories
Microprocessor based equipment
Personal Digital Assistants (PDA’s)
Notebooks, Desktops, and Servers
Portable Instrumentation
Networking and Telecom
Serial and Parallel Ports
Peripherals
2
Mechanical Characteristics
Package: SOD-323
Flammability Rating: UL 94V-0
Terminal: Matte tin plated.
High temperature soldering guaranted:
260℃/10s
Packaging: Tape and Reel
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
VESD
± 30
± 30
KV
Peak Pulse Power(tp=8/20us waveform)
PPP
350
W
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
The above data are for reference only.
http://www.microdiode.com
Rev:2024A3
Page :1
SDxxC Series
Electrical Characteristics (TA=25°C unless otherwise specified)
VRWM
(V)
VB
IT
VC@1A
VC
IR
(V)
(mA)
(V)
(V)
(max.)
(min.)
(max.)
2A
3.3
4
SD05C
2B
5
SD08C
2C
SD12C
PART
NUMBER
DEVICE
MARKING
SD03C
CT
(max.)
(max.)
(@A)
(µA)
(max.)
(pF)
1
7.5
16
450
6
1
9.8
18
17
10
300
8
8.5
1
13.4
24
15
2
120
2D
12
13.3
1
19
32
11
1
75
SD15C
2J
15
16.7
1
24
38
10
1
68
SD18C
2K
18
20.0
1
29
45
9
1
57
SD20C
2L
1
35
50
8
1
52
SD24C
2H
24
26.7
1
43
52
7
1
50
SD36C
2N
36
40
1
60
75
4.5
1
35
Rev:2024A3
Page :2
SDxxC Series
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A3
Page :3
SDxxC Series
Outlitne Drawing
SOD-323 Package Outline Dimensions
Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOD-323
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
178
3000
183×188×80
45,000
386×265×215
180,000
7'
Rev:2024A3
Page :4
很抱歉,暂时无法提供与“SD36C”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.23117
- 100+0.18662
- 600+0.16431
- 1200+0.16185
- 3000+0.12597
- 国内价格
- 10+0.25218
- 100+0.20359
- 300+0.17925
- 3000+0.13742
- 6000+0.12281
- 9000+0.11546
- 国内价格
- 20+0.49160
- 100+0.29320
- 800+0.20530
- 3000+0.14660
- 6000+0.13930
- 30000+0.12900
- 国内价格
- 1+0.15060
- 3000+0.13290
