78L06
SOT-89 Plastic-Encapsulate Voltage Regulators
78L06
SOT-89-3L
Three-terminal positive voltage regulator
FEATURES
z
z
z
1. OUT
Maximum output current
IOM: 0.1A
Output voltage
V O: 6V
Continuous total dissipation
PD: 0.6 W (Ta= 25 ℃ )
2. GND
3. IN
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Symbol
Value
Unit
Vi
30
V
Thermal Resistance from Junction to Ambient
RθJA
166.7
℃/W
Operating Junction Temperature Range
TOPR
-40~+125
Storage Temperature Range
TSTG
-65 ~+150
Parameter
Input Voltage
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=11V,Io=40mA,Ci=0.33uF,,Co=0.1uF, unless otherwise specified )
Parameter
Symbol
Test conditions
25℃
Output voltage
8V≤V l≤20V, Io=1mA-40mA
Vo
0-125℃
Io=1mA-70mA
Load Regulation
△Vo
Line regulation
△Vo
Quiescent Current
Quiescent Current Change
Output Noise Voltage
Typ
Max
Unit
5.75
6.0
6.25
V
5.7
6.0
6.3
V
5.7
6.0
6.3
V
Io=1mA-100mA
25℃
16
80
mV
Io=1mA-40mA
25℃
9
40
mV
8V≤V l≤20V
25℃
35
175
mV
9V≤V l≤20V
25℃
29
125
mV
25℃
3.9
6.0
mA
Iq
△Iq
9V≤V l≤20V
0-125℃
1.5
mA
△Iq
1mA≤I O≤40mA
0-125℃
0.1
mA
VN
10Hz≤f≤100KHz
25℃
Ripple Rejection
RR
Dropout Voltage
Vd
* Pulse test.
TYPICAL APPLICATION
Min
0-125℃
9V≤V l≤19V,f=120Hz
40
25℃
Vi
3
1
46
μV/Vo
48
dB
1.7
V
Vo
78L06
Ci
0.33μF
2
C0
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
The above data are for reference only.
http://www.microdiode.com
Rev:2024A1
Page :1
78L06
Typical Characteristics
Dropout Characteristics
Output Characteristics
6.5
8
TJ=25℃
IO=0mA
6.0
(V)
I
O
VO
=4
0m
A
5.5
5.0
A
=1
00
m
=0
m
I
O
A
4.0
=7
0m
2
4.5
I
4
A
OUTPUT VOLTAGE
OUTPUT VOLTAGE VO
6
O
(V)
TJ=25℃
I
O
3.5
3.0
10
15
INPUT VOLTAGE
VIN
25
30
5
6
9
10
(V)
7
IO=0mA
VIN=11V
TJ=25℃
TJ=25℃
6
Pulsed
(V)
4
VO
IQ
(mA)
8
VIN
Current Cut-off Grid Voltage
Quiescent Current
5
3
OUTPUT VOLTAGE
QUIESCENT CURRENT
7
INPUT VOLTAGE
(V)
2
1
5
4
3
2
10
15
INPUT VOLTAGE
VIN
25
1
0.00
30
0.05
0.10
0.15
OUTPUT CURRENT
(V)
Output Voltage vs Junction Temperature
0.20
IO
0.25
0.30
100
125
(A)
Power Derating Curve
800
6.50
Vin=11V
IO=5mA
700
600
PD
6.00
500
POWER DISSIPATION
OUTPUT VOLTAGE VO
(V)
(mW)
6.25
5.75
5.50
5.25
400
300
200
100
5.00
-25
50
75
TJ
100
125
50
Rev:2024A1
75
T J (℃ )
Page :2
78L06
Outlitne Drawing
SOT-89-3L Package Outline Dimensions
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
SOT-89-3L Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-89-3L
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
330
1000
203×203×195
40000
438×438×220
7'
Rev:2024A1
G.W.(Kg)
180000
Page :3
很抱歉,暂时无法提供与“78L06”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.42638
- 100+0.34551
- 200+0.30612
- 400+0.30153
- 1000+0.25159
- 国内价格
- 10+0.16200
- 100+0.12960
- 300+0.11880
