79L05
SOT-89 Plastic-Encapsulate Voltage Regulators
79L05
SOT-89-3L
Three-terminal positive voltage regulator
FEATURES
z
z
z
1. GND
Maximum output current
IOM: 0.1A
Output voltage
V O: -5V
Continuous total dissipation
PD: 0.6 W (Ta= 25 ℃ )
2. IN
3. OUT
ABSOLUTE MAXIMUM RATINGS (Operating temperature range applies unless otherwise specified)
Symbol
Value
Unit
Vi
-35
V
Thermal Resistance from Junction to Ambient
RθJA
208.3
℃/W
Operating Junction Temperature Range
TOPR
0~+150
Storage Temperature Range
TSTG
-65 ~+150
Parameter
Input Voltage
ELECTRICAL CHARACTERISTICS AT SPECIFIED VIRTUAL JUNCTION TEMPERATURE (Vi=-10V,Io=40mA,Ci=0.33uF,,Co=0.1uF, unless otherwise specified )
Parameter
er
mbol
Test conditions
25℃
Output Voltage
-7V≤Vl≤-20V, Io=1mA~40mA
Vo
Io=1mA~70mA
Load Regulation
ΔVo
Line Regulation
ΔVo
Quiescent Current
Iq
0-125℃
MLQ
T\S
Max
Unit
-4.80
-5.0
-5.2
V
-4.75
-5.0
-5.25
V
-4.75
-5.0
-5.25
V
Io=1mA~100mA
25℃
mV
Io=1mA~40mA
25℃
10
30
mV
-7V≤Vl≤-20V
25℃
15
150
mV
-8V≤Vl≤-20V
25℃
12
100
mV
25℃
6
mA
ΔIq
I
-8V ≤Vl≤-20V
0-125℃
1.5
mA
ΔIq
I
1mA ≤Vl≤40mA
0-125℃
0.1
mA
Output Noise Voltage
VN
10Hz≤f≤100KHz
25℃
Ripple Rejection
RR
-8V≤Vl≤-18V,f=120Hz
Dropout Voltage
Vd
Quiescent Current Change
* Pulse test.
TYPICAL APPLICATION
0-125℃
41
25℃
-Vi
Ci
0.33μF
2
3
40
μV/Vo
49
dB
1.7
V
-Vo
79L05
1
C0
0.1μF
Note: Bypass capacitors are recommended for optimum stability and transient response and should be located as close as
Possible to the regulators.
The above data are for reference only.
https://www.microdiode.com
Rev:2024A1
Page :1
79L05
Typical Characteristics
Output Characteristics
Dropout Characteristics
-7
-5.5
IO=0mA
(V)
-5.0
VO
-5
-4
OUTPUT VOLTAGE
(V)
OUTPUT VOLTAGE VO
TJ=25℃
TJ=25℃
-6
-3
-2
-1
IO=0mA
-4.5
-4.0
IO=-40mA,-70mA,-100mA
-3.5
-3.0
-2.5
-2.0
-10
-15
INPUT VOLTAGE
-20
VIN
-25
-1.5
-4.0
-30
-4.5
(V)
-5.0
-5.5
-6.0
INPUT VOLTAGE
VIN
-6.5
Current Cut-off Grid Voltage
Quiescent Current vs Input Voltage
-3.0
-7
IO=0mA
TJ=25℃
-6
(V)
(mA)
VIN=-10V
TJ=25℃
-2.5
-2.0
Pulsed
-5
OUTPUT VOLTAGE
QUIESCENT CURRENT
VO
IQ
-7.0
(V)
-1.5
-1.0
-0.5
0.0
-4
-3
-2
-1
-10
-15
INPUT VOLTAGE
-20
VIN
-25
(V)
100
150
OUTPUT CURRENT
Output Voltage vs Junction Temperature
IO
200
250
(mA)
Power Derating Curve
800
-8
Vin=-10V
IO=5mA
-6
(mW)
600
-5
PD
700
500
POWER DISSIPATION
OUTPUT VOLTAGE VO
(V)
-7
-4
-3
-2
-1
-0
50
75
100
TJ
125
150
400
300
200
100
50
75
Rev:2024A1
100
TJ
125
150
Page :2
79L05
Outlitne Drawing
SOT-89-3L Package Outline Dimensions
Symbol
A
b
b1
c
D
D1
E
E1
e
e1
L
Dimensions In Millimeters
Max
Min
1.400
1.600
0.320
0.520
0.400
0.580
0.350
0.440
4.400
4.600
1.550 REF.
2.300
2.600
3.940
4.250
1.500 TYP.
3.000 TYP.
0.900
1.200
Dimensions In Inches
Min
Max
0.055
0.063
0.013
0.020
0.016
0.023
0.014
0.017
0.173
0.181
0.061 REF.
0.091
0.102
0.155
0.167
0.060 TYP.
0.118 TYP.
0.035
0.047
SOT-89-3L Suggested Pad Layout
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-89-3L
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
330
1000
203×203×195
40000
438×438×220
7'
Rev:2024A1
G.W.(Kg)
180000
Page :3
很抱歉,暂时无法提供与“79L05”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.36720
- 100+0.34320
- 500+0.31920
- 2000+0.28320
- 5000+0.27120
- 10000+0.26400
