SPECIFICATION FOR APPROVAL
超利維
Customer:
Customer P/N:
TE1-830293
Drawing No:
Quantity:
X
Pcs.
Date:
2018/03/15
MHCB10040-100M-AU
Chilisin P/N:
Automotive Grade Inductor
Halogen Free
RoHS Compliant
REACH Compliant
Lead Free Solders
AEC-Q200
奇力新電子股份有限公司
東莞奇力新電子有限公司
Chilisin Electronics Corp
No. 29, Alley 301, Tehhsin Rd.,
Hukou,Hsinchu 303, Taiwan
TEL:+886-3- 599-2646
FAX:+886-3- 599-9176
E-mail:sales@chilisin.com
http://www.chilisin.com
Chilisin Electronics (Dongguan) Co., Ltd.
No. 78, Puxing Rd., Yuliangwei Administration
Area, Qingxi Town, Dongguan City,
Guangdong,China
TEL:+86-769-8773-0251~3
FAX: +86-769-8773-0232
E-mail:cect@chilisin.com
奇力新電子(河南)有限公司
Chilisin Electronics (Henan) Co., Ltd.
XiuWu Xian, industry gathering area
JiaoZuo, Henan China
Postal Code:454350
TEL:+86-391-717-0682
FAX:+86-391-717-0666
Drawn by
吳韋邑 Wayne.Wu
蘇州奇益新電子有限公司
SUZHOU QI YIXIN Electronics Co., Ltd.
Co.No 179 chang jiang Road New
District.Suzhou.China
Postal Code:215129
TEL:+86-512-6841-2350
FAX:+86-512-6841-2356
Checked by
吳韋邑 Wayne.Wu
Approved by
鍾瑞民 jacky.chung
YG17100438
MHCB10040 Series Specification
AEC-Q200
1 Scope: This specification applies to Large current and Low Loss SMD Power INDUCTOR
2 Part Numbering:
3 Rating:
Operating Temperature:
- 40°C ~ 125°C
Storage Temperature: (on tape & reel): -20°C to +40°C; 75% RH max.
4 Marking:
Ex : MHCB10040-100M-AU
Marking : 100
Marking color : Black
5 Standard Testing Condition
Temperature
Humidity
Unless otherwise specified
Ordinary Temperature(15 to 35℃)
Ordinary Humidity(25 to 85% RH)
In case of doubt
20 to 30℃
50 to 80 %RH
AEC-Q200
6 Configuration and Dimensions:
Dimensions in mm
TYPE
MHCB10040
A
10.1±0.3
B
11.6 Max
C
3.8±0.2
D
3.0±0.5
F
2.5±0.5
7 Electrical Characteristics:
Part No.
MHCB10040-100M-AU
Inductance
(uH )
Tolerance
Test Freq.
Irms(A)
Typ
Isat(A)
Typ
RDC(mΩ)
Max(Typ)
Marking
10
100kHz,0.5V
7
10
30(27)
100
Note:
1.Operating temperature range -40℃~125℃
2.Isat for Inductance drop 30% from its value without current.
3.Irms for a 40℃ temperature rise from 25℃ ambient.
4.The part temperature (ambient + temp rise) should not exceed 125°C under worst case operating conditions.
Circuit design 125°C under worst case operating conditions. Component placement, PWB trace size
and thickness, airflow and other cooling provisions all affect the part temperature. Part temperature
should be verified in the end application.
5.Absolute maximum voltage 30VDC
8 MHCB10040 Series
8.1 Construction:
8.2 Material List:
AEC-Q200
AEC-Q200
9 PACKAGING
9.1 Packaging -Cover tape
The force for tearing off cover tape is 10 to 130 grams in the arrow direction.
9.2 Packaging Quantity
TYPE
PCS/REEL
MHCB10040
500
9.3 Reel Dimensions
Dimensions in mm
TYPE
A
B
C
D
MHCB10040
330
100
13
24.4
AEC-Q200
9 PACKAGING
9.4 Tape Dimensions in mm
TYPE
A0
B0
K0
D
E
W
P
P0
P2
MHCB10040
10.6
11.7
4.25
1.55
1.75
24
16
4
2
10 Recommended Pattern
Dimensions in mm
TYPE
A(mm)
MHCB10040
4.0
B(mm)
C(mm)
9.5
3.5
11 Note:
1. Please make sure that your product has been evaluated and confirmed against your specifications
when our product is mounted to your product.
2. Do not knock nor drop.
3. All the items and parameters in this product specification have been prescribed on the premise that
our product is used for the purpose,under the condition and in the environment agreed upon between
you and us. You are requested not to use our product deviating from such agreement.
4. Please keep the distance between transformer/coil and other components (refer to the standard IEC 950)
5. The moisture sensitivity level (MSL) of products is classified as level 1.
12 Graph:
AEC-Q200
很抱歉,暂时无法提供与“MHCB10040-100M-AU”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+3.36000
- 20+3.04500
- 100+2.73000
- 500+2.41500
- 1000+2.26800
- 2000+2.16300
