VUA221M1ETR-0810
VUA221M1ETR-0810
    LELON(立隆电子)
    SMD,D8xL10mm
    贴片铝电解电容 SMD,D8xL10mm 220µF ±20% 25V 2000Hrs@125℃
VUA221M1ETR-0810 数据手册
Dwg. No. :H20-0433 承認字號 Issued Date: 2020/3/16 日鑫股份有限公司 Customer : 戶) (客 Part No. : (貴公司料號) SPECIFICATION FOR APPROVAL 承 認 書 Description : V-CHIP ALUMINUM ELECTROLYTIC CAPACITORS (零 件 名 稱) Lelon Series : VUA Series (立 隆 系 列) Lelon Part No.: VUA221M1ETR-0810 (立 隆 料 號) LELON ELECTRONICS CORP. 立隆電子工業股份有限公司 Headquarters 147, Sec. 1, Guoguang Rd,. Dali District, Taichung, Taiwan TEL: +886-4-24181856 FAX: +886-4-24181906 Manufacturing Sites □ Lelon Electronics Corp. 147, Sec. 1, Guoguang Rd,. Dali District, Taichung, Taiwan TEL: +886-4-24181856 FAX: +886-4-24181906 ■ Lelon Electronics (Huizhou) Co., Ltd. Taiyang Industrial Zone, Baihua Town, Huidong County, Huizhou City, Guangdong, China TEL: +86-752-8768222 FAX: +86-752-8768199 ■ Lelon Electronics (Suzhou) Co., Ltd. 1220, Zhongshan North Rd., Wujiang Economic and Technological Technological Development Zone Suzhou City, Jiangsu, China TEL: +86-512-63457588 FAX: +86-512-63457791 Approval Signatures 貴公司承認印 Approval 核 准 Check 確 認 Design 作 成 R&D R&D R&D MAR. 16. 2020 MAR. 16. 2020 MAR. 16. 2020 Jack Huang H. Y. Huang Z. X. Sun Please Return One Copy with Your Approval 承 認 後 請 寄 回 本 圖 一 份 RDD0346A, A4, 970102 LELON ELECTRONICS CORP. Ver. 02 Part Numbering System Product Code Guide – SMD Type VE series 10μF ±20% 16V Carrier Tape VE- 100 M 1C TR - 0405 □□□ □□□ □ □□ □□ □ □□□□ □ ① ② ③ ④ ⑤ ⑥ ⑦ ⑧ ⑨ Case size Lead Wire and Coating Type Supplement Code Series 4φ×5.3L Capacitanc Capacitanc Rated Package Terminal e e Tolerance Voltage Type Type Pb-free and PET coating case ① Series: Series is represented by a three-letter code. When the series name only has two letters, use a hyphen, “-“, to fill the third blank. ② Capacitance: Capacitance in μF is represented by a three-digit code. The first two digits are significant and the third digit indicates the number of zeros following the significant figure. “R” represents the decimal point for capacitance under 10μF. Example: Capacitance 0.1 0.47 1 4.7 10 47 100 470 1,000 4,700 10,000 Part number 0R1 R47 010 4R7 100 470 101 471 102 472 103 ③ Tolerance: J = -5% ~ +5% K = -10% ~ +10% M = -20% ~ +20% V = -10% ~ +20% ④ Rated voltage: Rated voltage in volts (V) is represented by a two-digit code Voltage (WV) 2.5 4 6.3 10 16 20 25 35 40 50 63 80 100 Code 0E 0G 0J 1A 1C 1D 1E 1V 1G 1H 1J 1K 2A Voltage (WV) 160 200 250 350 400 450 Code 2C 2D 2E 2V 2G 2W ⑤ Package: TR = Reel package T- = Tray package for case diameter 12.5 ~ 18mm ⑥ Terminal: - = No dummy terminal K = Anti-vibration structure (30G) A = For automotive application (10G) G = Anti-vibration structure (50G) ⑦ Case size: The first two digits indicate case diameter and the last two digits indicate case length in mm. φD×L 3×5.3 4×4.5 4×5.3 4×5.7 Code 0305 0404 0405 0406 φD×L 6.3×7.7 8×6.5 8×10 10×7.7 0810 1008 Code 0607 0806 φD×L 18×16.5 18×21.5 5×4.5 5×5.3 0504 0505 5×5.7 5×5.8 0506 6.3×4.5 0604 10×10(9.9) 10×12.5 12.5×13.5 12.5×16 1010 1013 1313 1316 0605 6.3×5.7 6.3×5.8 0606 16×16.5 16×21.5 1616 1621 6.3×5.3 Code 1816 1821 Note 1: When a case size is required and not shown in the table, please contact with us for further discussion. Note 2: The case size “5×5.8, 6.3×5.8” is for VZS series only. ⑧ Lead Wire and Coating Type: None = Pb free wire + PET coating case (Standard design) E = Sn-Bi wire + PET coating case B = Sn-Bi wire + Coating case K / L = Automotive control code * When a supplement code following a blank digit code of lead wire and case coating type (standard design), use a hyphen, “-“, to fill the blank digit. * When the automotive control code is required, please contact with us for further discussion. ⑨ Supplement code (Optional): For special control purpose LELON ELECTRONICS CORP. Lelon P/N: VUA221M1ETR-0810 Page: 1 / 1 220 μF / 25 V – 8φ × 10L VUA CUSTOMER : 日鑫股份有限公司 CUSTOMER P/N: PRODUCT DIMENSIONS Unit: mm 8 10 ± 0.5 8.3 8.3 9.0 0.7~1.1 3.1 ± 0.2 φD L A B C W P Items Performance Rated Voltage VR 25 V Capacitance CR 220 µF (120 Hz, 20℃) -40℃ ~ +125℃ Category Temperature Range -20 % ~ +20 % Capacitance Tolerance Surge Voltage VS (120 Hz, 20℃) 28.8 VDC ILEAK ≦ 165 µA Leakage Current (20℃) Tan δ After 1 minutes ≦ 0.21 Z(-25℃) / Z(+20℃) Z(-40℃) / Z(+20℃) Low Temperature Characteristics at 120 Hz Ripple Current (A) and Frequency Multipliers Endurance and Shelf Life Test (120 Hz, 20℃) 130 mA Ripple Current (IAC, R /rms) (120 Hz, 125℃) 4 6 Frequency (Hz) 50 120 1k 10k up Multiplier 0.80 1.00 1.25 1.40 Items Endurance Shelf Life Test Test Time 2,000 Hrs at 125℃; VR 1,000 Hrs at 125℃ Cap. Change Within ±30 % of initial value Within ±30 % of initial value Tan δ Less than 300% of specified value Less than 300% of specified value Leakage Current Within specified value Within specified value Standards JIS C 5101-1, -18, IEC 60384-4 Remarks RoHS Compliance, Halogen-free Marking: Each capacitor shall be marked with the following information A 0 → January , 2020 The suffix of A. D. Month of manufacture Month 1 2 3 4 5 6 Code A B C D E F Month 7 8 9 10 11 12 Code G H I J K L Marking color: Black * Please refer to “Precautions and Guidelines for Aluminum Electrolytic Capacitors” section in Lelon's catalog for further details. Publication Date March 14, 2020 Approval Signatures: Revision Date Version No. RDD0366A, A4, 100309 1 Please return one copy with your approval Approved Checked Designed R&D R&D R&D MAR. 16. 2020 MAR. 16. 2020 MAR. 16. 2020 Jack Huang H.Y.Huang Z.X.Sun LELEON ELECTRONICS CORP. VUA-MK-07 Diagram of Dimensions: Unit: mm Fig. 1 Fig. 2 (*): For 3 ~ 6.3φ is 0.4 max. φD 6.3 6.3 8 8 10 12.5 12.5 16 18 L 5.7 ± 0.3 7.7 ± 0.3 6.5 ± 0.3 10 ± 0.5 10 ± 0.5 13.5 ± 0.5 16 ± 0.5 16.5 ± 0.5 16.5 ± 0.5 A 6.6 6.6 8.3 8.3 10.3 13.0 13.0 17.0 19.0 B 6.6 6.6 8.3 8.3 10.3 13.0 13.0 17.0 19.0 C 7.2 7.2 9.0 9.0 11.0 13.7 13.7 18.0 20.0 W 0.5 ~ 0.8 0.5 ~ 0.8 0.5 ~ 0.8 0.7 ~ 1.1 0.7 ~ 1.3 1.1 ~ 1.4 1.1 ~ 1.4 1.1 ~ 1.4 1.1 ~ 1.4 P ± 0.2 2.0 2.0 2.3 3.1 4.7 4.4 4.4 6.4 6.4 Fig. No. 1 1 1 1 1 2 2 2 2 Marking: Each capacitor shall be marked with the following information. φD = 6.3 mm φD = 8 ~ 10 mm φD ≧ 12.5 mm Description of Date Code: A 0 → January, 2020 The last digit of A. D. Month of manufacure Month Code Month Code Marking Color: Black Origin code: 1 A 2 B 3 C 4 D 5 E 6 F 7 G 8 H 9 I 10 J 11 K 12 L Huizhou: A0 , B0 , … , K0, L0 Suzhou: 0A , 0B , … , 0K , 0L LELON ELECTRONICS CORP. PAC-SMD Taping Specification for SMD Type 1. Carrier Tape Fig. 1-1 Fig. 1-2 Fig. 1-3 φD ×L A B 3~4 ×4.5 4.5 4 ×5.3 φd F P P1 P2 t1 4.5 5.5 8 4.8 4.5 4.5 5.5 8 5.8 4 ×5.7 4.5 4.5 5.5 8 6.3 5 ×4.5 5.5 5.5 5.5 12 4.8 5 ×5.3 5.5 5.5 5.5 12 5.9 5 ×5.7 ~ 5.8 5.5 5.5 5.5 12 6.3 6.3 ×4.5 6.8 6.8 7.5 12 6.3 ×5.3 6.8 6.8 6.3 ×5.7 / 5.8 6.8 6.8 7.5 12 6.3 ×7.7 6.8 6.8 6.3 ×8.7 6.8 6.8 6.3 ×9.5 6.8 6.8 11.5 16 8 ×6.5 8.7 8.7 7.5 12 9.4 9.4 11.5 16 10.7 10.7 10 ×10.5(G) 11.4 11.4 11.4 10 ×12.5 10.7 10.7 13.1 0.4 10 ×7.7 W W1 Unit: mm Fig. No. 1-1 12.0 4.8 5.9 6.3 16.0 8.3 9.3 0.5 8 ×9.5~10 8 ×10.5(G) t2 10.6 24.0 6.9 16.0 1-2 11.0 10 ×10 11.4 2.0 4.0 8.7 1.5 11.0 10 ×16.5 10.7 10.7 17.5 12.5 ×13.5 13.4 13.4 14.5 12.5 ×13.5(G) 13.7 13.7 12.5 ×16 13.4 13.4 12.5 ×16(G) 13.7 13.7 16 ×16.5 17.5 17.5 16 ×16.5(G) 17.5 17.5 16 ×21.5 17.5 17.5 18 ×16.5 19.5 19.5 18 ×16.5(G) 19.6 19.6 18 ×21.5 19.5 19.5 Tol. ± 0.2 ± 0.2 24.0 14.2 24 15.0 1.75 32.0 17.0 0.5 17.5 17.0 28 17.5 20.2 1-3 44.0 23.0 17.5 32 17.5 23.0 +0.1/-0 ± 0.1 ± 0.1 ± 0.1 ± 0.1 ± 0.1 ± 0.2 ± 0.3 ± 0.15 Note: Case size in mark of “G” are for “Anti-vibration”. Ver. 12 -1- LELON ELECTRONICS CORP. PAC-SMD 2. Reel Package Fig. 2-1 Fig. 2-2 Reel Polarity Pull out direction Case size 3 ~ 4φ 5φ 6.3φ 8φ×6.5 8φ×10 10φ 12.5φ 16 ~ 18φ W 14 14 18 18 26 26 34 46 A 380 380 380 380 380 380 380 380 t 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3.0 3. Packing specification Fig. 3-1 Carrier Tape Unit: pcs Ver. 12 Case size Q’ty / Reel Q’ty / Box 3φ 4φ 2,000 20,000 2,000 20,000 5φ 1,000 10,000 6.3φ 1,000 10,000 8φ×6.5 1,000 10,000 8φ×10L 500 5,000 10φ×7.7 ~ 10L 500 5,000 10φ×12.5L 400 4,000 12.5φ×13.5L 200 1,600 12.5φ×16L 200 1,600 16φ×16.5L 200 1,600 16φ×21.5L 100 800 18φ×16.5L 150 1,200 18φ×21.5L 100 800 Unit: mm 16 ~ 18φ Case size 3 ~ 4φ 5φ 6.3φ 8φ× 6.5 8φ× 10 10φ 12.5φ H 210 210 250 250 330 330 330 425 W, L 395 395 395 395 395 395 395 395 -2- LELON ELECTRONICS CORP. PAC-SMD Fig. 3-2 Label 4. Chip Tray Dimension and package quantity Case size W1 H H1 Q’ty / Tray Unit: mm Q’ty / Box 12.5φ×13.5L 284 21 18.5 120 600 12.5φ×16L 284 21 18.5 120 600 16φ×16.5L 284 28 24.0 80 400 16φ×21.5L 284 28 24.0 80 400 18φ×16.5L 284 28 24.0 60 300 18φ×21.5L 284 28 24.0 60 300 5. Sealing Tape Reel Strength 5.1 Peel angle: 165 to 180℃refered to the surface on which the tape is glued. 5.2 Peel speed: 300mm per minutes 5.3 The peel strength must be 0.1 ~ 0.7N under these conditions. 6. Packing Method 6.1 The leader length of the tape shall not be less than 400 mm including 10 or more embossed sections in which no parts are contained. 6.2 The winding core is provided with an over 160mm long empty section; punched carrier is only suitable for φD ≦ 5 mm. 7. Other: Specifications stated above is in accordance with JIS C 0806-3. Ver. 12 -3- LELON ELECTRONICS CORP. VUA-APR-12 Endurance characteristic: No. Item 1 Rotational Temperature Test 2 3 4 5 6 7 Conditions Capacitor is placed in an oven whose temperature follow specific regulation to change. The specific regulation is " +25℃ (3 min.) → -40℃ (30 min.) → +25℃ (3 min.) → +125℃ (30 min.) → +25℃ (3 min.) ", and it is called a cycle. The test totals 10 cycles, and then the capacitor shall be subjected to standard atmospheric conditions for 4 hours, after which measurements shall be made. High Temperature 1. Capacitors shall be placed in oven with Endurance Life application of rated voltage Test 1,000 +48 / -0 hours for φD ≦ 6.3 ~ 8 × 6.5 mm; 2,000 +72 / -0 hours for φD ≧ 8 × 10 ~ 18 mm at 125℃. 2. Then the capacitor shall be subjected to standard atmospheric conditions for 4 hours, after which measurements shall be made. High Temperature After 1,000 +48 / -0 Hours test at 125℃ without Unload Life Test rated voltage. And then the capacitor shall be subjected to standard atmospheric conditions for 4 hours, after which measurements shall be made. Humidity Test Low Temperature Test Vibration Test Surge Voltage Test Specification Capacitance change Tanδ Leakage Current Physical Within ± 10% of initial value Within specified value Within specified value No broken and undamaged Capacitance change Tanδ Leakage Current Physical Capacitance change Tanδ Leakage Current Physical Capacitors shall be exposed for 1,000 +48 / -0 hours Capacitance in an atmosphere of 90 ~ 95% R. H. at 60 ± change 3℃. Tanδ And then the capacitor shall be subjected to Leakage standard atmospheric conditions for 4 hours, after Current which measurements shall be made. Physical Capacitors are placed at -40 ± 3℃ for 96 ± 4 hours. Capacitance And then the capacitor shall be subjected to change standard atmospheric conditions for 4 hours, after Tanδ which measurements shall be made. Leakage Current Physical 1. Fix it at the point 4 mm or less from body. For Capacitance ones of 12.5 mm or more in diameter or 25 mm or change more length, use separate fixture. Tanδ 2. Direction and during of vibration: Leakage 3 orthogonal directions mutually each for 2 hours Current (total of 6 hours). Physical 3. Frequency: 10 to 55 Hz reciprocation for 1 minute. 4. Total amplitude: 1.5 mm The capacitor shall be subjected to 1,000 cycles at Capacitance 15 ~ 35℃. Protective series resistor a 1KΩ each change consisting of a charge period of 30 ± 5 seconds, Tanδ followed by discharge period of approximately 5.5 Leakage minutes. Current Applying voltage: Physical Within ± 30% of initial value Less than 300% of specified value Within specified value No broken and undamaged Within ± 30% of initial value Less than 300% of specified value Within specified value No broken and undamaged Within ± 10% of initial value Less than 120% of specified value Within specified value No broken and undamaged Within ± 10% of initial value Within specified value Within specified value No broken and undamaged Within ± 10% of initial value Within specified value Within specified value No broken and undamaged Within ± 20% of initial value Less than 175% of specified value Within specified value No broken and undamaged Rated Voltage(V) 10 16 25 35 50 63 400 Surge Voltage(V) 11.5 18.4 28.8 40.3 57.5 72.5 440 LELON ELECTRONICS CORP. VUA-APR-12 No. Item 8 Solder Heat1. IR Reflow Resistance Test Conditions Specification Capacitance change Tanδ Leakage Current Physical Rated voltage (V) 10 ~ 35 Within ± 10% of initial value Within specified value Within specified value No broken and undamaged 10 ~ 63 3 ~ 6.3 8 ~ 18 Case size (φ) Temp. 150 ~ 180 (T1 ~ T2, ℃) Preheat Time (t1) 100 (max., secs) Temp. (T3, ℃) 217 230 217 230 Duration Time (t2) 90 60 60 40 (max., secs) Temp. (T4, ℃) 260 250 Peak Time (t3, secs) 5 Reflow cycles 9 Mechanical Characteristics Test 10 Solderability Test 11 Venting Test 2 or less 2. Solder iron method: Bit temperature: 350 ± 5℃ Application time of soldering Iron: 3 +1 / -0 sec * Please contact our representative if your condition is higher. * Please ensure that the capacitor became cold enough to the room temperature (5℃ ~ 35℃) before the second reflow. * Consult with us when performing reflow profile in IPC / JEDEC (J-STD-020) Bending Test: Apply pressure in the direction of the arrow at a rate of about 0.5 mm / s until bent width reaches 2 mm and hold for 60s. The board shall be the test board “B” as specified in JIS C 0051: 2002. If the land area differs, it shall be specified clearly in the next item. Without mechanical damage such as breaks. Electrical characteristics shall be satisfied. If there are electrodes on both surfaces, above requirements shall be satisfied on whichever surface it may be fixated on. After the lead wire fully immersed in the solder for 2 ± 0.5 secs at a temperature of 245 ± 5℃, the solderthe solder coating must be more than 95%. 1. Applicable to the capacitors with case size is 8×10 mm and larger. 2. Test condition: (1) AC test: The capacitor shall be connected across an applying 50 or 60 Hz AC which is 0.7 times of rated voltage or 250Vrms AC whichever is the lower. (2) DC test: Applying inverse DC rated voltage with current to the capacitor. Where case diameter: φD ≦ 22.4 mm: 1 A DC max. φD > 22.4 mm: 10 A DC max. Note: (1) When the pressure relief vent operated, the capacitor shall avoid any danger of fire or explosion of capacitor element(terminal and metal foil etc.) or cover. (2) When the pressure relief device does not open with the voltage applied over 30 minutes, the test is considered to be passed. LELON ELECTRONICS CORP. No. Item 12 Land Pattern VUA-APR-12 Conditions Recommended pad pattern and size Case size 5φ 6.3φ 8φ×6.5L 8φ 13 Standards Satisfies Characteristic JIS C 5101-1, -18 G 1.4 1.9 2.1 3.0 Land size Y 3.0 3.5 4.0 3.5 Case size X 1.6 1.6 1.6 2.5 10φ 12.5φ 16φ 18φ G 4.0 4.0 6.0 6.0 Land size Y 4.0 6.0 7.0 8.0 X 2.5 3.2 3.2 3.2 LELON ELECTRONICS CORP. VUA-APR-12 Precautions and Guidelines for Aluminum Electrolytic Capacitors 1. Guidelines for Circuit Design (General / Application guidelines for using electrolytic capacitors) Selecting of a right capacitor is a key to a good circuit design. (1) Polarity Most of the aluminum electrolytic capacitors are polarized. Therefore, they must be installed with the correct polarity. Usage in the reverse polarity results into a short-circuit condition that may damage or even explode the capacitor. In addition, it may influence circuit functionality. A bi-polar electrolytic capacitor should be installed when polarity across a capacitor is unstable / reversible. It should be, however, noted that usage of both polar and bi-polar capacitors are limited to DC applications. They must NOT be used for AC application. (2) Operating Voltage Applied DC voltage must not exceed rated voltage of the capacitor. Applying higher voltage than its rated voltage across a capacitor terminals cause overheating due to higher leakage currents and capacitor dielectric/insulation deterioration that will ultimately affect a capacitor’s performance. The device, however, is capable of working under short-time transient voltages such as DC transients and peak AC ripples. Reverse voltages higher than 1 Volt within a specified temperature limit or AC voltages are not permissible. Overall, using capacitors at recommended operating voltages can prolong its lifespan. Note that the result of DC voltage overlapped with peak ripple voltage should not exceed rated voltage. (3) Ripple Current One of the key functions of any capacitor is removal of the ripple current i.e. the RMS value of AC flowing through a capacitor. But, a ripple current higher than rated ripple current will drop resultant capacitance, cause undue internal heating and thus reduces life span of the capacitor. In extreme cases, internal high temperature will cause the pressure relief vent to operate while destroying the device. Overall, it is important to note that an electrolytic capacitor must be used within a permissible range of ripple current. Indicators like temperature coefficient of allowable ripple current are generally used to determine life expectancy of the capacitor, but to avoid related complex calculations and for the sake of simplicity, we haven’t provided temperature coefficient in the catalogue. But it offers key indicators like maximum operating temperature for calculation of life expectancy at a given temperature. (4) Operating Temperature Capacitors should be used within a permissible range of operating temperatures. Using capacitor at a higher temperature than maximum rated temperature will considerably shorten its life. In the worst-case scenario, high temperature can cause pressure relief vent to operate and the device will get destroyed. Using capacitors at an ambient room temperature assure their longer life. (5) Leakage Current Leakage current flows through a capacitor when DC voltage is applied across it. Leakage current varies with changes in ambient temperature and applied DC voltage level and its time of application. Overvoltage situation, presence of moisture, and thermal stresses, especially occurring during the soldering process can enhance leakage current. Initial leakage current is usually higher and does not decrease until voltage is applied for a certain period of time. It is recommended to keep initial leakage current within specified levels. (6) Charge and Discharge Regular electrolytic capacitors are not suitable for rapid charging/discharging circuits. Such usage may either cause reduction in overall capacitance or damage due to overheating. Lelon provides special assistance for selecting appropriate capacitors for rapid charging/discharging circuits. (7) Surge Voltage The Surge voltage rating is referred as the maximum DC overvoltage that may be applied to an electrolytic capacitor for a short time interval of 30 seconds at infrequent time intervals not exceeding 5.5minutes with a limiting resistance of 1kΩ. Unless otherwise described on the catalogue or product specifications, please do not apply a voltage exceeding the capacitor’s voltage rating. The rated surge voltages corresponding to rated voltages of electrolytic capacitors are presented as follows: Rated Voltage(V) 4 6.3 Surge Voltage(V) 4.6 7.3 11.5 18.4 28.8 10 16 25 40.3 57.5 35 50 Rated Voltage(V) 63 80 100 160 200 250 315 Surge Voltage(V) 72.5 92 115 184 230 288 347 Rated Voltage(V) 350 400 420 450 500 525 Surge Voltage(V) 385 440 462 495 550 578 (8) Condition of Use The capacitors shall NOT be exposed to: (a) Fluids including water, saltwater spray, oil, fumes, highly humid or condensed climates, etc. (b) Ambient conditions containing hazardous gases/fumes like hydrogen sulfide, sulfurous acid, nitrous acid, chlorine or bromine gas, ammonia, etc. (c) Exposed to ozone, ultraviolet rays and radiation. (d) Severe vibrations or physical shocks that exceeds the specifications mentioned in this catalogue. (9) Circuit Design Consideration (a) Please ensure whether application, operating and mounting conditions satisfy the conditions specified in the catalog before installation of a capacitor. Please consult Lelon, if any of the conditions are beyond the conditions specified in the catalog. (b) Heat-generating components or heat sinks should not be placed closer to Aluminum electrolytic capacitors on the PCB to avoid their premature failure. A cooling system is recommended to improve their reliable working. (c) Electrical characteristics and performance of aluminum electrolytic capacitors are affected by variation of applied voltage, ripple current, ripple frequency and operating temperature. Therefore, these parameters shall not exceed specified values in the catalog. (d) Aluminum capacitors may be connected in the parallel fashion for increasing total capacitance and/or for achieving higher ripple current capability. But, such design may cause unequal current flow through each of the capacitors due to differences in their impedances. (e) When two or more capacitors are connected in series, voltage across each capacitor may differ and fall below the applied voltage. A resistor should be placed across each capacitor so as to match applied voltage with voltage across a capacitor. (f) Please consult Lelon while selecting a capacitor for highfrequency switching circuit or a circuit that undergoes rapid charging/ discharging (g) Standard outer sleeve of the capacitor is not a perfect electrical insulator therefore is unsuitable for the applications that requires perfect electrical insulation. Please consult Lelon, if your application requires perfect electrical insulation. (h) Tilting or twisting capacitor body is not recommended once it is soldered to the PCB. 2. Caution for Assembling Capacitors (1) Mounting (a) Aluminum electrolytic capacitors are not recommended to reuse in other circuits once they are mounted and powered in a circuit. LELON ELECTRONICS CORP. VUA-APR-12 (b) Aluminum electrolytic capacitors may hold static charge between its anode and cathode, which is recommended to be discharged through a 1kΩ resistor before re-use. (c) A long storage of capacitors may result into its insulation deterioration. This can lead to a high leakage current when voltage is applied that may damage the capacitor. Capacitors following a long storage period must undergo voltage treatment/re-forming. Capacitors are charged by applying rated DC voltage through a resistor of 1kΩ in series at least for an hour. It is recommended to increase applied voltage gradually using a voltage regulator unit once capacitors are assembled on the board. The charging should be followed by discharging through a 1KΩ resistor. (d) Please check capacitor rated voltage before mounting. (e) Please check capacitor polarity before mounting. (f) Please don’t drop capacitor on the floor / hard object. (g) Please don’t deform the capacitor during installation. (h) Please confirm whether the lead spacing of the capacitors match with its pad spacing / footprint on PCB prior to installation. (i) Please avoid excessive mechanical shocks to capacitor during the auto-insertion process, inspection or centering operations. (j) Please don’t place any wiring or circuit over the capacitor’s pressure relief vent. The pressure relief vent may fail to open if adequate clearance space is not provided. Following table shows minimum clearance space required for different case diameters. Case Diameter φ6.3 ~φ16 φ18 ~ φ35 φ40 or above Clearance (min) 2 mm 3 mm 5 mm (2) Soldering (a) Please confirm that soldering conditions, especially temperature and contact time are within our specifications. Dip or flow soldering temperature should be limited at 260 ± 5℃ for 10 ± 1 sec while manual soldering using soldering iron should be limited at 350 ± 5℃ for 3 +1/-0 seconds. Please do not dip capacitor body into molten solder. A capacitor’s life will be negatively affected if these conditions are violated. (b) Storage of capacitors in high humidity conditions is likely to affect the solder-ability of lead wires and terminals. ○ (a) ╳ (b) 3. Maintenance Inspection Periodical inspection of aluminum capacitors is absolutely necessary, especially when they are used with industrial equipment. The following items should be checked: (1) Appearance: Bloated, vent operated, leaked, etc. (2) Electrical characteristic: Capacitance, Tanδ, leakage current, and other specified items listed in specification. Lelon recommend replacing the capacitors if any of the abovementioned items fail to meet specifications. (c) Reflow soldering should NOLY be used for SMD type capacitors. The temperature and duration shall not exceed the specified temperature and duration in the specification. If the temperature or duration is higher than the value specified, please consult Lelon before usage. (d) Standard aluminum electrolytic capacitors are not designed to withstand multiple reflow processes. Please consult Lelon if repeated reflowing is unavoidable. (e) Incorrect mounting on PCB with improper external strength applied on its lead wires or capacitor body after soldering may damage a capacitor’s internal structure, cause short circuit, or lead to high leakage current issues. Do not bend or twist the capacitor body after soldering. Referring to the drawings below only case (i) is recommended. (i) Correct soldering (ii) Hole-to-hole spacing on PCB differs from the lead space of lead wires. (iii) Lead wires are bent after soldering. (iv) Capacitor body doesn’t stand vertical on PCB after soldering. (3) Cleaning Circuit Boards after Soldering (a) Following chemicals are not recommended for cleaning: Solvent containing halogen ions, Alkaline solvent, Xylene, Acetone, Terpene, petro-based solvent. (b) Recommended cleaning conditions: Fatty-alcohol - Pine Alpha ST-100S, Clean Through-750H and IPA (isopropyl alcohol) are examples of the most acceptable cleaning agents. Temperature of the cleaning agent must not exceed 60℃. Flux content in the cleaning agents should be limited to 2 Wt. %. Overall length of cleaning process (e.g., immersion, ultrasonic or other) shall be within 5 minutes (5 ~ 7mm height within 3 minutes). CFC substitute cleaning agents such as AK225AES can also be used for cleaning. In this case, its temperature shall not exceed 40 C and cleaning process (e.g., immersion, ultrasonic or other) shall be completed within 2 ~ 3 minutes. After cleaning capacitors should be dried with hot air for at least 10 minutes along with the PCB. Temperature of hot air shall not exceed maximum category temperature of the capacitor. Insufficient drying may cause appearance defects, sleeve shrinkage, and bottom-plate bulging. However, usage of this CFC substitute must completely regulated for protection of environment. ╳ (c) ╳ (d) 4. Storage (1) The most suitable conditions for aluminum capacitor storage are 5 ℃ ~ 35℃ and indoor relative humidity less than 75%. High temperature and/or humidity storage is detrimental to the capacitors. (2) Capacitors shall not be stored in wet or damp atmospheres containing water, brine, fumes or oil. (3) Capacitors storage area shall neither be exposed to hazardous gases such as hydrogen sulfide, sulfurous acid, nitrous acid, chlorine, ammonium, etc. nor to acidic or alkaline solutions. (4) Capacitors shall not be exposed to ozone, ultraviolet rays or radiation. LELON ELECTRONICS CORP. 5. Estimation of life time Lr  L0  2 T0 max Tr max 10 Lr: Estimated lifetime (hours) L0: Base lifetime specified at maximum operating temperature with applied the DC voltage and the ripple current (hours) T0 max: The core temperature that rated ripple current applied at maximum operating temperature. Tr max: The core temperature that applied actual ripple current at ambient temperature. 6. Disposal Please consult with a local industrial waste disposal specialist when disposing of aluminum electrolytic capacitors. VUA-APR-12 7. Environmental Consideration Lelon already have received ISO 14000 certificate. Cadmium (Cd), Lead (Pb), Mercury (Hg), Hexavalent Chromium (Cr+6), PBB, PBDE, DEHP, BBP, DBP and DIBP have never been using in capacitor. If you need “Halogen-free” products, please consult with us. 8. AEC-Q200 Compliance Automotive Electronics Counsel (AEC) has established various electronic component qualification/reliability standards in order to serve automotive electronics industry. AEC-Q200 standard is dedicated for passive components like capacitors, inductors, etc. and is widely adopted domestically as well as internationally. Lelon offers compliant product designs and support services to satisfy customers’ product requirements, including the AEC-Q200 required criteria of the reliability tests. Lelon’s capacitors are professionally designed to outperform all requirements of AEC-Q200. For further details, please refer to IEC 60384-4- Fixed capacitors for use in electronic equipment – Part 4: Sectional specification – Aluminium electrolytic capacitors with solid (MnO2) and non-solid electrolyte (Established in January 1995, Revised in March 2007), and EIAJ RCR-2367B- Guideline of notabilia for fixed aluminium electrolytic capacitors for use in electronic equipment [Technical Standardization Committee on Passive Components (Established in March 1995, Revised in March 2002)].
VUA221M1ETR-0810 价格&库存
很抱歉,暂时无法提供与“VUA221M1ETR-0810”相匹配的价格&库存,您可以联系我们找货
VUA221M1ETR-0810
  • 5+0.77762
  • 20+0.70517
  • 100+0.63272
  • 500+0.56028
  • 1000+0.52647
  • 2000+0.50232
