MP1184K44E4R8Q0
MP1184K44E4R8Q0
    SRD(圣融达)
    CAP_26.5X10MM_TM
    安规电容 CAP_26.5X10MM_TM 180nF ±10% 440V
MP1184K44E4R8Q0 数据手册
Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 440VAC Series) ■ 引用标准 Reference standards GB/T6346.14-2015/ UL60384-14/VDE0565-1/ CSA E60384-14 IEC60384-14 /EN60384-14 ■ 结构 Structure 介质:(金属化)聚丙烯膜 封装:阻燃环氧树脂,符合 UL94 V-0 外壳:阻燃 PBT 塑壳,符合 UL94 V-0 Dielectric: Metallized Polypropylene film Encapsulation: Flame retardant epoxy resin, conforming to UL94 V-0 Shell: Flame retardant PBT plastic shell, conforming to UL94 V-0 典型应用 Typical ■ Application 跨线、抑制突波、交流场合 EMI 滤波;电源开关等。如:灯具、电源等 Interlines, Surge suppression, Across-in-line as EMI filter; Power switch etc. Such as: Lamps, Power Sources etc. 特点 Features ■ 外观一致性好;有良好自愈性 抗湿性强;高耐温 长寿命,耐过电压优良 ■ 符合 RoHS 及 REACH 环保标准 ■ 电性能规范 Good appearance consistency; Good self-healing property; Good resistance to humidity; Can withstand high temperature; Long lifetime; Good ability to withstand surge voltage. Compliance with RoHs & REACH requirements. Performance Specifications 气候类别 Climate category 40/110/56 阻燃等级 Passive flammability class B 额定电压 Rated Voltage 440VAC 容量误差 Capacitance Tolerance K: ±10% 容量范围 0.0022μF~4.7μF Capacitance Range Test Condition: 耐电压 No breakdown or electric arcing Withstand Voltage Terminal to terminal:4.3UR(Vdc),5S Terminal to shell:2380VAC 60S 损耗角 ≤0.0020 10KHZ CR≤1.0μF Test Condition : Dissipation factor ≤0.0010 1KHZ CR>1.0μF 绝缘电阻或时间常数 CR≤0.33μF IR≥15000MΩ Insulation Resistance CR>0.33μF IR≥5000S 最大脉冲爬升速率 P=10mm dV / dt = 500V/μs P=15mm dV / dt = 400V/μs P=22.5mm dV / dt = 200V/μs P=27.5mm dV / dt = 150V/μs P=37.5mm dV / dt = 80V/μs Max. Pulse Rise Time (dV / dt) 20℃, 1KHz, 1Vrms 20℃ 1V Test Condition : 20℃ 100V 1 min Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 440VAC Series) ■ 电性能规范 Performance Specifications 稳态湿热 温度 Temp.:40±2℃ 无可见损伤,标志清晰 Steady-state Damp-heat Test 相对湿度 Humidity:93%RH no visible damage,clear mark 绝缘电阻 IR:≥ 额定值的 50% IR:≥ 50% of Rated value 持续时间 Duration Time:56 Days 容量变化(相对初始值): Capacitance change:△C/C≤±5% 损耗角增加 Dissipation factor: Rise ≤0.0080(10KHZ),CR≤1uF Rise ≤0.0050(1KHZ),CR>1uF 绝缘电阻 Insulation Resistance 耐久性试验 温度 Temp.: +110℃, Endurance Test 施加电压:1.25×额定电压(每小时增加 IR:≥ 50% of rated value 电压到 1000Vac,0.1 秒,1 次) 容量变化(相对初始值):△C/C≤±10% Test Voltage: Capacitance change: △C/C≤±10% 1.25 Times Rated Voltage(Rise the voltage to 1000Vac for .01s once per hours ) 持续时间 Duration Time: 1000H ■ ■ 安规认证 Safety Certification 认证标志 额定电压 证书号码 引用标准 认证国家 Certification Rated Voltage Certificate No. Reference standard Certification Country UL/CUL 440VAC E319615 UL60384-14 VDE 440VAC 40025029 EN60384-14 德国 Germany ENEC 440VAC 40025029 EN60384-14 欧盟 Europe CQC 440VAC CQC09001032856 GB/T6346.14-2015 中国 China 产品编码说明 美国、加拿大 America / Canada Part No. Description: 15 位产品编码如下: The Part No. Is total 15 digits, details as follow: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 M 6 R 8 * * Digit 1-3 P 1 1 0 4 K 型号代码 Product Name Code 4 4 D MP1= Class X1 Capacitors Digit 4-6 标称容量 Rated Capacitance Value For example : 104= 10×104pF = 0.1F Digit 7 容量偏差 Capacitance Tolerance K=±10% Digit 8-9 额定电压 Rated Voltage Code 44=440VAC Digit 10-11 壳号 Plastic shell code Digit 12 塑壳颜色 Plastic Shell Color R = Grey Color with LOGO on the shell top Digit 13 线径代码 Line diameter code 6=0.6 8=0.8 Digit 14-15 成型或内部识别码 Forming Type or Internal Use Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 440VAC Series) ■ 料号明细及尺寸 Part No. List and Dimensions 容量 成品编码 等级 电压 尺寸 Dimension (mm) Part No. Class Voltage Capacitance (μF) MP1222K44B2R6** X1 440VAC 0.0022 10 5 11 7.5 0.6 MP1272K44B2R6** X1 440VAC 0.0027 10 5 11 7.5 0.6 MP1332K44B2R6** X1 440VAC 0.0033 10 5 11 7.5 0.6 MP1392K44B2R6** X1 440VAC 0.0039 10 5 11 7.5 0.6 MP1472K44B2R6** X1 440VAC 0.0047 10 5 11 7.5 0.6 MP1562K44B2R6** X1 440VAC 0.0056 10 5 11 7.5 0.6 MP1682K44B2R6** X1 440VAC 0.0068 10 5 11 7.5 0.6 MP1822K44B2R6** X1 440VAC 0.0082 10 5 11 7.5 0.6 MP1103K44B2R6** X1 440VAC 0.01 10 5 11 7.5 0.6 MP1123K44B3R6** X1 440VAC 0.012 10 6 12 7.5 0.6 MP1222K44C2R6** X1 440VAC 0.0022 13 5 11 10 0.6 MP1272K44C2R6** X1 440VAC 0.0027 13 5 11 10 0.6 MP1332K44C2R6** X1 440VAC 0.0033 13 5 11 10 0.6 MP1392K44C2R6** X1 440VAC 0.0039 13 5 11 10 0.6 MP1472K44C2R6** X1 440VAC 0.0047 13 5 11 10 0.6 MP1562K44C2R6** X1 440VAC 0.0056 13 5 11 10 0.6 MP1682K44C2R6** X1 440VAC 0.0068 13 5 11 10 0.6 MP1822K44C2R6** X1 440VAC 0.0082 13 5 11 10 0.6 MP1103K44C2R6** X1 440VAC 0.01 13 5 11 10 0.6 MP1123K44C2R6** X1 440VAC 0.012 13 5 11 10 0.6 MP1153K44C2R6** X1 440VAC 0.015 13 5 11 10 0.6 MP1183K44C2R6** X1 440VAC 0.018 13 5 11 10 0.6 MP1273K44C3R6** X1 440VAC 0.027 13 6 12 10 0.6 MP1223K44CDR6** X1 440VAC 0.023 12.5 5 13 10 0.6 MP1333K44CGR6** X1 440VAC 0.033 12.5 6 15.5 10 0.6 MP1103K44D2R8** X1 440VAC 0.01 18 6 12 15 0.8 MP1123K44D2R8** X1 440VAC 0.012 18 6 12 15 0.8 MP1153K44D2R8** X1 440VAC 0.015 18 6 12 15 0.8 MP1183K44D2R8** X1 440VAC 0.018 18 6 12 15 0.8 MP1223K44D2R8** X1 440VAC 0.022 18 6 12 15 0.8 MP1273K44D2R8** X1 440VAC 0.027 18 6 12 15 0.8 MP1333K44D2R8** X1 440VAC 0.033 18 6 12 15 0.8 MP1393K44D2R8** X1 440VAC 0.039 18 6 12 15 0.8 MP1473K44DDR8** X1 440VAC 0.047 17.5 6 15.5 15 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 440VAC Series) 料号明细及尺寸 Part No. List and Dimensions 容量 成品编码 等级 电压 ■ 尺寸 Dimension (mm) Part No. Class Voltage Capacitance (μF) MP1563K44DDR8** X1 440VAC 0.056 17.5 6 15.5 15 0.8 MP1683K44DGR8** X1 440VAC 0.068 17.5 7 17.5 15 0.8 MP1823K44DGR8** X1 440VAC 0.082 17.5 7 17.5 15 0.8 MP1104K44DKR8** X1 440VAC 0.1 17.5 8 18.5 15 0.8 MP1124K44DNR8** X1 440VAC 0.12 17.5 9 19.5 15 0.8 MP1154K44DRR8** X1 440VAC 0.15 17.5 10 22.5 15 0.8 MP1184K44DRR8** X1 440VAC 0.18 17.5 10 22.5 15 0.8 MP1224K44DUR8** X1 440VAC 0.22 17.5 11 23.5 15 0.8 MP1393K44E2R8** X1 440VAC 0.039 26.5 7 16.5 22.5 0.8 MP1473K44E2R8** X1 440VAC 0.047 26.5 7 16.5 22.5 0.8 MP1563K44E2R8** X1 440VAC 0.056 26.5 7 16.5 22.5 0.8 MP1683K44E2R8** X1 440VAC 0.068 26.5 7 16.5 22.5 0.8 MP1823K44E2R8** X1 440VAC 0.082 26.5 7 16.5 22.5 0.8 MP1104K44E2R8** X1 440VAC 0.1 26.5 7 16.5 22.5 0.8 MP1124K44E2R8** X1 440VAC 0.12 26.5 7 16.5 22.5 0.8 MP1154K44E2R8** X1 440VAC 0.15 26.5 7 16.5 22.5 0.8 MP1184K44E3R8** X1 440VAC 0.18 26.5 8.5 17 22.5 0.8 MP1224K44E3R8** X1 440VAC 0.22 26.5 8.5 17 22.5 0.8 MP1274K44E4R8** X1 440VAC 0.27 26.5 10 19 22.5 0.8 MP1334K44E5R8** X1 440VAC 0.33 26.5 11 20 22.5 0.8 MP1394K44E6R8** X1 440VAC 0.39 26.5 12 21.5 22.5 0.8 MP1474K44E7R8** X1 440VAC 0.47 26.5 13 23 22.5 0.8 MP1154K44F1R8** X1 440VAC 0.15 31.5 10.8 19.5 27.5 0.8 MP1184K44F1R8** X1 440VAC 0.18 31.5 10.8 19.5 27.5 0.8 MP1224K44F1R8** X1 440VAC 0.22 31.5 10.8 19.5 27.5 0.8 MP1274K44F1R8** X1 440VAC 0.27 31.5 10.8 19.5 27.5 0.8 MP1334K44F1R8** X1 440VAC 0.33 31.5 10.8 19.5 27.5 0.8 MP1394K44F1R8** X1 440VAC 0.39 31.5 10.8 19.5 27.5 0.8 MP1474K44F2R8** X1 440VAC 0.47 31.5 13 21.5 27.5 0.8 MP1564K44F2R8** X1 440VAC 0.56 31.5 13 21.5 27.5 0.8 MP1684K44F3R8** X1 440VAC 0.68 31 14 25 27.5 0.8 MP1824K44F4R8** X1 440VAC 0.82 31.5 16 25.5 27.5 0.8 MP1105K44F5R8** X1 440VAC 1.0 31.5 16 30 27.5 0.8 说明 Note: “**”表示内部特征码 “**”=Internal use. W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 Metallized Polypropylene Film Interference Suppression Capacitors 金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 440VAC Series) ■ 料号明细及尺寸 Part No. List and Dimensions 容量 成品编码 等级 电压 尺寸 Dimension (mm) Part No. Class Voltage Capacitance (μF) MP1125K44F6R8** X1 440VAC 1.2 31 18 33 27.5 0.8 MP1155K44F6R8** X1 440VAC 1.5 31 18 33 27.5 0.8 MP1334K44S0R1** X1 440VAC 0.33 41 11 22 37.5 1.0 MP1394K44S0R1** X1 440VAC 0.39 41 11 22 37.5 1.0 MP1474K44S0R1** X1 440VAC 0.47 41 11 22 37.5 1.0 MP1564K44S0R1** X1 440VAC 0.56 41 11 22 37.5 1.0 MP1684K44S0R1** X1 440VAC 0.68 41 11 22 37.5 1.0 MP1824K44S1R1** X1 440VAC 0.82 41 12 26 37.5 1.0 MP1105K44S1R1** X1 440VAC 1.0 41 12 26 37.5 1.0 MP1125K44S2R1** X1 440VAC 1.2 41 14 28 37.5 1.0 MP1155K44S3R1** X1 440VAC 1.5 41 16 30 37.5 1.0 MP1185K44S4R1** X1 440VAC 1.8 41 17 32 37.5 1.0 MP1205K44S5R1** X1 440VAC 2.0 41 18.5 33.5 37.5 1.0 MP1225K44S5R1** X1 440VAC 2.2 41 18.5 33.5 37.5 1.0 MP1255K44S6R1** X1 440VAC 2.5 41 22 37 37.5 1.0 MP1275K44S6R1** X1 440VAC 2.7 41 22 37 37.5 1.0 MP1305K44S7R1** X1 440VAC 3.0 41 26 41 37.5 1.0 MP1335K44S7R1** X1 440VAC 3.3 41 26 41 37.5 1.0 MP1355K44S7R1** X1 440VAC 3.5 41 26 41 37.5 1.0 MP1395K44S7R1** X1 440VAC 3.9 41 26 41 37.5 1.0 MP1405K44S8R1** X1 440VAC 4.0 41 28 43 37.5 1.0 MP1455K44S9R1** X1 440VAC 4.5 42 30 45 37.5 1.0 MP1475K44S9R1** X1 440VAC 4.7 42 30 45 37.5 1.0 说明 Note: “**”表示内部特征码 W±0.5 T±0.5 H±0.5 P±0.5 Φd±0.05 “**”=Internal use. Note: We can customize the capacitors according to customers special requirements.
MP1184K44E4R8Q0
物料型号:金属化聚丙烯膜抑制电磁电源干扰用电容器 (MP1-Class X1 440VAC Series)
器件简介:该电容器采用金属化聚丙烯膜作为介质,封装在阻燃环氧树脂中,外壳为阻燃PBT塑壳,符合UL94 V-0标准。
引脚分配:文档中未明确提供引脚分配信息。
参数特性: - 额定电压:440VAC - 容量误差:K级±10% - 容量范围:0.0022 F~4.7 F - 耐电压:端对端4.3UR(Vdc), 5秒;端对外壳2380VAC 60秒,无击穿或电弧 - 损耗角:≤0.0020(10KHz)至≤0.0010(1KHz,CR>1.0 F) - 绝缘电阻:CR≤0.33 F时IR≥15000MΩ;CR>0.33 F时IR≥5000S - 最大脉冲爬升速率:根据电容器尺寸不同,爬升速率在500V/us至80V/us之间
功能详解: - 典型应用包括跨线、抑制突波、交流场合EMI滤波和电源开关等,如灯具、电源等。 - 特点包括良好的外观一致性、自愈性、抗湿性强、耐高温度、长寿命和耐过电压。
应用信息:适用于需要电磁干扰抑制的电源应用,如灯具和电源设备。
封装信息:电容器的封装包括阻燃环氧树脂和阻燃PBT塑壳,具体尺寸和颜色根据产品编码有所不同。
MP1184K44E4R8Q0 价格&库存
很抱歉,暂时无法提供与“MP1184K44E4R8Q0”相匹配的价格&库存,您可以联系我们找货
MP1184K44E4R8Q0
  • 5+0.52000
  • 20+0.51000
  • 100+0.49000
