P1
TAI-TECH
Wire Wound Type Common Mode Filter
HDMI2012F2SF-SERIES
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
17/10/17
新 發 行
楊祥忠
林志鴻
張展耀
備
註
www.tai-tech.com.tw
P2
TAI-TECH
HDMI2012F2SF-SERIES
1.Features
1. High common mode impedance at high frequency effects excellent noise
suppression performance.
2. HDMI2012F2SF series realizes small size and low profile. 2.0x1.2x1.2 mm.
3. 100% Lead(Pb) & Halogen-Free and RoHS compliant.
Halogen
Pb
Halogen-free
Pb-free
2.Dimension
C
A
當破損面積<5%,產品列入允收品範圍
E
W
B
產品破損寬度
A(mm)
B(mm)
C(mm)
D1(mm)
D2(mm)
E(mm)
2012F2SF
2.0±0.2
1.2±0.2
1.2±0.2
0.50±0.1
0.51±0.1
0.15±0.1
D
D
Series
3.Part Numbering
HDMI 2012
A
B
F
2
S
F
C
D
E
F
670
T
04
G
H
I
A: Series
B: Dimension
C: Material
Ferrite
D: Number of Lines
2=2 lines
E: Type
S=One Circuit Type , N=Unshielded
F: Lead free
G: Impedance
670=67Ω
H: Packaging
I: Rated Current
T=Taping and Reel, B=Bulk
04=400mA
4.Specification
TAI-TECH
Part Number
Common mode
Impedance (Ω)
HDMI2012F2SF-670T04
Test
Frequency
(MHz)
DC
Resistance
(Ω) max.
Rated Current
(mA)
Rated Volt. Withstand
IR
(Vdc)
Volt. (Vdc) (Ω) min.
67 typ.
50 min.
100
0.30
400
50
125
10M
HDMI2012F2SF-900T04 90 typ.
65 min.
100
0.30
400
50
125
10M
HDMI2012F2SF-670
10000
IMPEDANCE(Ohm)
IMPEDANCE(Ohm)
1000
Common Mode
100
10
Normal Mode
1
HDMI2012F2SF-900
1000
100
Common Mode
10
Normal Mode
1
0.1
0.1
1
10
100
1000
10000
1
10
100
FREQUENCY(MHz)
FREQUENCY(MHz)
www.tai-tech.com.tw
1000
P3
TAI-TECH
5.Schematic Diagram
6. Materials
No.
Description
Specification
a.
Upper Plate
Ferrite
b.
Core
Ferrite Core
c
Termination
Tin Pb Free
d
Wire
Enameled Copper Wire
7.Reliability and Test Condition
Item
Performance
Operating temperature
-40~+125℃ (Including self - temperature rise)
Storage temperature
-40~+125℃ (on board)
Test Condition
Electrical Performance Test
Z(common mode)
DCR
Agilent-4291A+ Agilent -16197A
Refer to standard electrical characteristics list.
I.R.
Temperature Rise Test
Agilent-4338B
Agilent4339
Rated Current < 1A
∆T 20℃Max
Rated Current ≧ 1A ∆T 40℃Max
www.tai-tech.com.tw
1.Applied the allowed DC current.
2.Temperature measured by digital surface thermometer
P4
TAI-TECH
Reliability Test
Preconditioning: Run through IR reflow for 2 times.( IPC/JEDEC
J-STD-020DClassification Reflow Profiles)
Temperature:125±2℃
Life Test
Applied current:rated current
Duration:1000±12hrs
Measured at room temperature after placing for 24±2 hrs
Humidity:85±2﹪R.H,
Load Humidity
Temperature:85℃±2℃
Duration:1000hrs Min. with 100% rated current
Moisture Resistance
Appearance:No damage.
Inductance:within±10% of initial value
Impedance:within±15% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not
Profiles
1. Baked at50℃ for 25hrs, measured at room temperature after
placing for 4 hrs.
2. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
keep 3 hours, cool down to 25℃ in 2.5hrs.
3. Raise temperature to 65±2℃ 90-100%RH in 2.5hrs, and
2.5hrs,keep at 25℃ for 2 hrs then keep at -10℃ for 3 hrs
4. Keep at 25℃ 80-100%RH for 15min and vibrate at the
frequency of 10 to 55 Hz to 10 Hz, measure at
room temperature after placing for 1~2 hrs.
Reflow Profiles
Condition for 1 cycle
Step1:-40±2℃ 30±5min
Thermal
shock
Step2:25±2℃ ≦0.5min
Step3:125±2℃ 30±5min
Number of cycles: 500
Oscillation Frequency: 10~2K~10Hz for 20 minutes
Vibration
Equipment: Vibration checker
Total Amplitude:1.52mm±10%
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
www.tai-tech.com.tw
P5
TAI-TECH
Item
Performance
Bending
Shock
Solder ability
More than 95% of the terminal electrode should
be covered with solder。
Test Condition
Shall be mounted on a FR4 substrate of the
following dimensions: >=0805 inch(2012mm):40x100x1.2mm
=0805 inch(2012mm):1.2mm
0805:1kg ,
HDMI2012F2SF-900T04 价格&库存
很抱歉,暂时无法提供与“HDMI2012F2SF-900T04”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.27783
- 100+0.21976
- 400+0.19127
- 800+0.18840
- 2000+0.17174
- 国内价格
- 2000+0.22320
- 6000+0.21690
- 28000+0.21050
- 国内价格
- 10+0.32800
- 100+0.25610
- 300+0.22050
- 2000+0.19370
- 4000+0.17210
- 国内价格
- 10+0.33340
- 100+0.26082
- 300+0.22454
- 2000+0.19732
