RS3AC THRU RS3MC
Reverse Voltage - 50 to 1000 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT FAST RECOVERY RECTIFIER
Features
DO-214AB/SMC
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
Open Junction chip
0.245(6.22)
0.220(5.59)
0.126 (3.20)
0.114 (2.90)
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed:
0.280(7.11)
0.260(6.60)
0.012(0.305)
0.006(0.152)
250℃/ 10 seconds at terminals
Glass passivated chip junction
0.103(2.62)
0.079(2.06)
0.060(1.52)
0.030(0.76)
Mechanical Data
0.008(0.203)MAX.
0.320(8.13)
0.305(7.75)
Case : JEDEC DO-214AB/SMC Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0077 ounce, 0.22 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
RS3AC
Parameter
SYMBOLS
Marking Code
RS3BC
RS3DC
RS3GC
RS3JC
RS3KC RS3MC
MDD
MDD
MDD
MDD
MDD
MDD
MDD
RS3AC RS3BC RS3DC RS3GC RS3JC RS3KC RS3MC
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
UNITS
V
V
V
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
Maximum average forward rectified current
I(AV)
3.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
90
A
Maximum instantaneous forward voltage at 3.0A
VF
1.30
V
Maximum DC reverse current
at rated DCblocking voltage
IR
5.0
100.0
μA
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
Typical junction capacitance (NOTE 2)
Typical thermal resistance (NOTE 3)
VRMS
VDC
trr
CJ
RJA
RθJC
Operating junction and storage temperature range TJ,TSTG
150
250
500
ns
40.0
pF
45.0
15.0
℃/W
-55 to +150
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
RS3AC THRU RS3MC
Ratings And Characteristic Curves
Fig.2 Typical Reverse Characteristics
Fig.1 Maximum Average Forward Current Rating
4.0
Instaneous Reverse Current(μ A)
100
Average Forward Current (A)
3.5
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
TJ=125°C
10
1.0
TJ=25°C
0.1
175
00
Case Temperature (°C)
60
80
100
120
140
percent of Rated Peak Reverse Voltage (%)
Fig.3 Typical Instaneous Forward
Fig.4 Typical Junction Capacitance
Characteristics
10
TJ=25°C
TJ=25°C
Junction Capacitance (pF)
Instaneous Forward Current (A)
100
1.0
0.1
pulse with 300μ
s
0.0
0.5
1.0
1.5
2.0
TJ=25°C
f = 1.0MHz
Vsig = 50mVp-p
1% duty cycle
0.01
10
1
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
120
100
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
RS3AC THRU RS3MC
Packing information
P0
unit:mm
P1
d
Item
Symbol
Tolerance
SMC
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
6.15
8.41
2.42
1.50
330.00
50.00
13.00
1.75
7.50
8.00
4.00
2.00
0.25
16.00
16.50
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
SMC
13"
3,000
4.0
INNER
BOX
(mm)
REEL
DIA,
(mm)
190*190*41
330
BOX
(pcs)
6000
CARTON
SIZE
(mm)
365*365*340
CARTON
(pcs)
42000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
4.3
0.170
B
0.160
C
4.1
7.9
0.311
D
3.8
0.150
E
12
0.472
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“RS3GC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.24000
- 100+0.22400
- 300+0.20800
- 500+0.19200
- 2000+0.18400
- 5000+0.17920
- 国内价格
- 5+0.38217
- 50+0.31271
- 150+0.27804
- 500+0.25205
- 3000+0.20712
- 6000+0.19664
