M1 THRU M7
Reverse Voltage - 50 to 1000 Volts
Forward Current - 1.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
Idea for printed circuit board
0.110(2.80)
0.090(2.30)
0.067 (1.70)
0.051 (1.30)
Glass passivated Junction chip
Low reverse leakage
High forward surge current capability
0.177(4.50)
0.150(3.80)
High temperature soldering guaranteed
0.012(0.305)
0.006(0.152)
250 C/10 seconds at terminals
0.097(2.45)
0.073(1.85)
Mechanical Data
0.061(1.55)
0.008(0.20)
0.002(0.05)
0.029(0.75)
0.209(5.30)
Case : JEDEC DO-214AC/SMA Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.0019ounce, 0.055 grams
0.184(4.70)
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRRM
VRMS
VDC
MDD
M1
MDD
M2
MDD
M3
MDD
M4
MDD
M5
MDD
M6
MDD
M7
UNITS
50
35
50
100
70
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
100
Maximum average forward rectified current
I(AV)
1
A
Peak forward surge current 8.3ms single
half sine-wave superimposed onrated load
IFSM
30
A
Maximum instantaneous forward voltage at 1.0A
VF
1.1
V
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
Operating junction and storage temperature range
IR
5
50
15
CJ
RθJA
75
TJ,TSTG
-55 to +150
uA
pF
℃/W
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0x2.0”(2.54x2.54cm) copper pad areas
http://www.microdiode.com
Rev:2025A5
Page :1
M1 THRU M7
Ratings And Characteristic Curves
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
1.2
Average Forward Current (A)
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
175
Instaneous Reverse Current (μA)
100
TJ=150°C
10
TJ=125°C
TJ=100°C
1.0
TJ=75°C
0.1
TJ=25°C
0.01
Junction Capacitance (pF)
25°
TJ=
0.8
0.9
J
T=
10
C
0°C
C
5°
12
TJ=
Instaneous Forward Current (A)
0.5
0.2
0.6
0.7
1.0
TJ=25°C
10
1
1.1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
35
100
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
1
Number of Cycles
100
Transient Thermal Impedance(°C/W)
Peak Forward Surage Current (A)
800
100
1.0
00
600
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
0.1
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2025A5
Page :2
M1 THRU M7
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMA
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
E
F
W
B
A
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
SMA
13"
REEL
(pcs)
5,000
COMPONENT
SPACING
(m/m)
BOX
(pcs)
INNER BOX
(m/m)
REEL
DIA,
(m/m)
CARTON
SIZE
(m/m)
4.0
10,000
340*350*40
330
370*370*370
CARTON
(pcs)
80,000
Suggested Pad Layout
Symbol
Unit (mm)
Unit (inch)
A
0.066
B
1.68
1.52
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
0.060
Important Notice and Disclaimer
Microdiode Semiconductor(Shenzhen) reserves the right to make changes to this document and its products and specifications at
any time without notice. Customers should obtain and confirm the latest product information and specifications before final design,
purchase or use.
Microdiode Semiconductor(Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products for
any particular purpose, not does Microdiode Semiconductor(Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Semiconductor(Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Semiconductor(Shenzhen).
Microdiode Semiconductor(Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Semiconductor(Shenzhen).
Rev:2025A5
Page :3
很抱歉,暂时无法提供与“M1”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.06511
- 1000+0.03870
- 2000+0.03812
- 5000+0.03467
- 国内价格
- 10+0.07104
- 100+0.05573
- 300+0.04725
- 1000+0.04222
- 5000+0.03783
- 10000+0.03542
- 国内价格
- 1000+0.03605
- 2000+0.02921
