S2AB THRU S2MB
Reverse Voltage - 50 to 1000 Volts
Forward Current - 2.0 Ampere
SURFACE MOUNT GENERAL RECTIFIER
Features
DO-214AA/SMB
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
0.155(3.94)
0.130(3.30)
0.086 (2.20)
0.075 (1.80)
Idea for printed circuit board
Open Junction chip
Low reverse leakage
High forward surge current capability
High temperature soldering guaranteed
0.185(4.70)
0.160(4.06)
0.012(0.305)
0.006(0.152)
0.096(2.44)
0.084(2.13)
250℃/10 seconds at terminals
0.060(1.52)
0.030(0.76)
0.008(0.203)MAX.
Mechanical Data
0.220(5.59)
0.200(5.08)
Case: JEDEC DO-214AA/SMB molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Polarity symbol marking on body Mounting
Position : Any
Weight : 0.003ounce, 0.09grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 2.0A
Maximum DC reverse current
at rated DC blocking voltage
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
Typical thermal resistance (NOTE 2)
VRRM
VRMS
VDC
MDD
S2AB
MDD
S2BB
MDD
S2DB
MDD
S2GB
MDD
S2JB
MDD
S2KB
MDD
S2MB
UNITS
50
35
50
100
70
100
200
140
200
400
280
400
600
420
600
800
560
800
1000
700
1000
V
V
V
I(AV)
2.0
A
IFSM
60
A
VF
1.10
V
IR
5.0
100.0
μA
25.0
pF
60.0
20.0
℃/W
-55 to +150
CJ
RJA
RθJC
Operating junction and storage temperature range TJ,TSTG
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 2.0”x2.0”(5.0x5.0cm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
S2AB THRU S2MB
Typical Characterisitics
Fig.2 Typical Instaneous Reverse
Characteristics
Fig.1 Forward Current Derating Curve
100
Instaneous Reverse Current (μA)
2.5
Average Forward Current (A)
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz resistive
or inductive load
0.0
25
50
75
100
125
150
175
TJ=150°C
TJ=125°C
10
TJ=100°C
1.0
TJ=75°C
0.1
TJ=25°C
0.01
100
Junction Capacitance (pF)
10
1.0
TJ=25°C
0.4
0.6
0.8
1.0
1.2
800
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
Instaneous Forward Current (A)
400
Instaneous Reverse Voltage (V)
Case Temperature (°C)
0.1
200
1.4
1.6
1.8
TJ=25°C
10
1
0.1
1.0
10
100
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Peak Forward Surage Current (A)
100
80
60
40
8.3 ms Single Half Sine Wave (JEDEC
Method)
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
S2AB THRU S2MB
Packing information
unit:mm
P0
P1
d
Item
Symbol
Tolerance
SMB
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.41
2.42
1 5.0
330.00
50.00
13.00
1.75
5.55
8.00
4.00
2.00
0.30
12.00
12.30
E
F
B
A
W
P
D2
T
D1
C
W1
D
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMB
13"
3,000
4.0
6,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
48,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
A
B
C
D
E
Unit (mm)
2.8
2.4
4.6
2.2
7.0
Unit (inch)
0.110
0.094
0.181
0.086
0.276
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“S2MB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.12276
- 300+0.09514
- 1200+0.07979
- 3000+0.07114
- 国内价格
- 20+0.17449
- 300+0.13973
- 1200+0.12042
- 3000+0.09660
- 国内价格
- 20+0.19035
- 200+0.15244
- 600+0.13138
- 3000+0.10539
- 9000+0.09440
- 21000+0.08852
