SS32 THRU SS3200
Reverse Voltage - 20 to 200 Volts
Forward Current - 3.0 Ampere
SURFACE MOUNT SCHOTTKY BARRIER RECTIFIER
Features
DO-214AC/SMA
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Metal silicon junction,majority carrier conduction
Low power loss,high efficiency
0.110(2.80)
0.090(2.30)
0.067 (1.70)
0.051 (1.30)
Built-in strain relief,ideal for automated placement
High forward surge current capability
High temperature soldering guaranteed:
0.177(4.50)
0.150(3.80)
0.012(0.305)
0.006(0.152)
250 °C/10 seconds at terminals
0.097(2.45)
0.073(1.85)
0.061(1.55)
0.029(0.75)
0.008(0.20)
0.002(0.05)
Mechanical Data
0.209(5.30)
0.184(4.70)
Case: JEDEC DO-214AC/SMA molded plastic body
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denotes cathode end Mounting
Position: Any
Weight : 0.0018 ounce, 0.064 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
MDD
SS32
MDD
SS33
MDD
SS34
MDD
SS35
MDD
SS36
MDD
SS38
MDD
SS310
MDD
SS3150
MDD
SS3200
UNITS
VRR
RMM
21
30
40
28
40
50
35
50
60
42
60
80
56
80
100
70
100
150
105
150
200
140
200
V
V
V
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
VRMS
VDC
Maximum average forward rectified current
at TL(see fig.1)
I(AV)
3.0
A
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
IFSM
80
A
Maximum instantaneous forward voltage at 3.0A
VF
Maximum DC reverse current
at rated DCblocking voltage
IR
TA=25℃
TA=125℃
Typical junction capacitance (NOTE 1)
CJ
0.55
0.70
0.85
0.5
5
0.95
0.3
3.0
250
V
mA
180
pF
70
℃/W
Typical thermal resistance (NOTE 2)
RJA
Operating junction temperature range
TJ
-55 to +125
TSTG
-55 to +150
Storage temperature range
Note:1.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
2.P.C.B. mounted with 0.2x0.2”(5.0x5.0mm) copper pad areas
http://www.microdiode.com
Rev:2025A6
Page :1
SS32 THRU SS3200
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
3.5
3.0
2.4
1.8
1.2
0.6
Single phase half-wave 60 Hz
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
10 4
SS32 ~ SS36
SS38 ~ SS3200
10
1
10
T J =25°C
60
100
80
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Fig.4 Typical Junction Capacitance
T J = 2 5°C
10
1.0
SS32~ SS34
SS35~SS36
SS38~SS310
SS3150~SS3200
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
Junction Capacitance (pF)
500
200
100
SS32~SS34
SS35~SS3200
10
1.8
1
0.1
100
10
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.5- Typical Transient Thermal Impedance
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
Number of Cycles at 60Hz
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
T J =75°C
10 2
Lead Temperature (°C)
Peak Forward Surage Current (A)
T J =100°C
10 3
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
The curve above is for reference only.
Rev:2025A6
Page :2
SS32 THRU SS3200
Packing information
unit:mm
P0
Item
P1
Symbol
Tolerance
SMA
A
B
C
d
D
D1
D
D1
D2
E
F
P
P0
P1
T
W
W1
0.1
0.1
0.1
0.05
2.0
min
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
2.80
5.33
2.36
1.50
330.00
50.00
178.00
62.00
13.00
1.75
5.50
4.00
4.00
2.00
0.28
12.00
18.00
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
7" Reel outside diameter
7" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
Reel width
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
S MA
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(m/ m)
BOX
(p cs)
IN NER BOX
(m/m)
REEL DIA,
(m/m)
CARTON SIZ E
(m/m)
13"
5,000
4. 0
1 0,000
340* 350*40
330
370*370* 370
CARTON
(p cs)
80, 000
Suggested Pad Layout
Symbol
A
Unit (mm)
1.68
Unit (inch)
0.066
B
1.52
0.060
C
3.93
0.154
D
2.41
0.095
E
5.45
0.215
Important Notice and Disclaimer
Microdiode Electronics (Shenzhen) reserves the right to make changes to this document and its products and specifications
at any time without notice. Customers should obtain and confirm the latest product information and specifications before final
design,purchase or use.
Microdiode Electronics (Shenzhen) makes no warranty, representation or guarantee regarding the suitability of its products
for any particular purpose, not does Microdiode Electronics (Shenzhen) assume any liability for application assistance or
customer product design. Microdiode Electronics (Shenzhen) does not warrant or accept any liability with products which are
purchased or used for any unintended or unauthorized application.
No license is granted by implication or otherwise under any intellectual property rights of Microdiode Electronics (Shenzhen).
Microdiode Electronics (Shenzhen) products are not authorized for use as critical components in life support devices or
systems without express written approval of Microdiode Electronics (Shenzhen).
Rev:2025A6
Page :3
很抱歉,暂时无法提供与“SS3200”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.54329
- 100+0.46849
- 300+0.43109
- 1000+0.40302
- 5000+0.25656
- 10000+0.24535
- 国内价格
- 10+0.51341
- 100+0.44273
- 1000+0.38085
- 2000+0.37514
- 5000+0.24245
- 国内价格
- 10+0.54230
- 100+0.46750
- 300+0.42940
- 1000+0.40100
- 5000+0.25430
- 10000+0.24300
- 国内价格
- 1+0.20100
- 100+0.19620
- 1000+0.19270
- 国内价格
- 100+0.24239
- 1000+0.23368
- 国内价格
- 1+0.36570
- 500+0.24380
- 2500+0.21160
- 5000+0.19205
- 国内价格
- 7+0.71190
- 100+0.56950
- 300+0.49720
- 3000+0.43510
- 9000+0.40680
- 21000+0.38650
