SR05LC
Ultra Low Capacitance ESD Protection Diodes Array
SOT-143 Plastic-Encapsulate Diodes
DESCRIPTION
SR05LC provides a typical line to line capacitance of 0.6pF and low insertion loss up to 3GHz
providing greater signal integrity making it ideally suited for USB 2.0 applications, such as Digital TVs,
DVD players, Computing, set-top boxes and MDDI applications in mobile computing devices.
This device has been specifically designed to protect sensitive components which are connected to
high-speed data and transmission lines from overvoltage caused by ESD (electrostatic discharge),
CDE (Cable Discharge Events), and EFT (electrical fast transients).
Features
Protects two I/O lines and one Vcc line
Transient protection for asymmetrical data lines to
IEC61000-4-2 (ESD) ±30kV (air), ±30kV (contact)
IEC61000-4-4 (EFT) 40A (5/50ns)
Low capacitance
Low leakage current
Low clamping voltage
No insertion to 3.0 GHz
5V operating voltage
Response time < 1ns
Solid-state silicon avalanche technology
Meets MSL 1 Requirements
Schematic & Pin Configuration
4
3
1
2
SOT-143 (Top View)
Circuit Diagram
Pin 4
Pin 2
Pin 3
Pin 1
Applications
xDSLI
USB 1.1/2.0/OTG
IEEE 1394 Firewire Ports
Notebooks & Handhelds
Projection TV & Monitors
Set-top box
Flat Panel Displays
http://www.microdiode.com
Mechanical Characteristics
Package: SOT-143
Flammability Rating: UL 94V-0
Terminal: Matte tin plated.
High temperature soldering guaranted:
260℃/10s
Marking: SL3 or R05
Packaging: Tape and Reel
Rev:2024A1
Page :1
SR05LC
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power(8/20us )
PPP
125
W
Peak Pulse Current(8/20us)
IPP
5
A
VESD
± 30
± 30
KV
Operating Temperature
TOPT
−55 to +150
°C
Storage Temperature
TSTG
−55 to +150
°C
TL
260(10 sec.)
°C
ESD per IEC 61000−4−2 (Air)
ESD per IEC 61000−4−2 (Contact)
Lead Solder Temperature – Maximum (10 Second
Duration)
Electrical Characteristics (TA=25°C unless otherwise specified)
Symbol
Parameter
Test Condition
VRWM
Reverse Working Voltage
Any I/O pin to GND
VBR
Reverse Breakdown
Voltage
IR
Reverse Leakage Current
IT = 1mA
Any I/O pin to GND
VRWM = 5V
Any I/O pin to GND
VF
Diode Forward Voltage
IF = 15mA
VC1
Clamping Voltage 1
VC2
Clamping Voltage 2
IPP
Peak Pulse Current
CJ1
Junction Capacitance 1
CJ2
Junction Capacitance 2
Note: I/O pins are pin2,3.
Min
Typ
Max
Units
5.0
V
6.0
V
1
μA
1.2
V
IPP = 1A, tp = 8/20μs
Any I/O pin to GND
15.5
V
IPP = 5A, tp = 8/20μs
Any I/O pin to GND
25
V
5
A
0.45
0.6
pF
0.9
1.2
pF
tp = 8/20μs
Any I/O pin to GND
VR = 0V, f = 1MHz
Between I/O pins
VR = 0V, f = 1MHz
Any I/O pin to GND
0.85
The above data are for reference only.
Rev:2024A1
Page :2
SR05LC
ELECTRICAL CHARACTERISTICS CURVE
The curve above is for reference only.
Rev:2024A1
Page :3
SR05LC
Outlitne Drawing
SOT-143 Package Outline Dimensions
S ymbol
A
A1
A2
b
b1
c
D
d
E
E1
e
e1
L
L1
θ
D imensions In Millimeters
Min.
Max.
0.900
1.150
0.000
0.100
0.900
1.050
0.300
0.500
0.750
0.900
0.080
0.150
2.800
3.000
0.200 TYP .
1.200
1.400
2.250
2.550
0.950 TYP .
1.800
2.000
0.550 RE F.
0.300
0.500
0°
8°
D imensions In Inches
Min.
Max.
0.035
0.045
0.000
0.004
0.035
0.041
0.012
0.020
0.030
0.035
0.003
0.006
0.110
0.118
0.008 TYP .
0.047
0.055
0.089
0.100
0.037 TYP .
0.071
0.079
0.022 RE F.
0.012
0.020
0°
8°
Suggested Pad Layout
Note:
1. Controlling dimension:in/millimeters.
2. General tolerance: ±0.05mm.
3. The pad layout is for reference purposes only.
Rev:2024A1
Page :4
SR05LC
Tape and Reel Information
SOT-143 Embossed Carrier Tape
Packaging Description:
SOT-143 parts are shipped in tape. The
carrier tape is made from a dissipative (carbon
filled) polycarbonate resin. The cover tape is a
multilayer film (Heat Activated Adhesive in nature)
primarily composed of polyester film,adhesive
laye,sealant, and anti-static sprayed agent.These
reeled parts In standard option are shipped with
3,000 units per 7" or 17.8cm diameter reel. The
reels are clear in color and is made of polystyrene
plastic (anti-static coated).
SOT-143
SOT-143 Tape Leader and Trailer
SOT-143 Reel
3000 pcs
7 Inch
45,000 pcs
203×203×195
180,000 pcs
438×438×220
Rev:2024A1
Page :5
很抱歉,暂时无法提供与“SR05LC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.53331
- 100+0.42164
- 600+0.32393
- 1200+0.31907
- 3000+0.28136
- 国内价格
- 5+0.58180
- 50+0.45998
- 150+0.39906
- 500+0.35338
- 3000+0.30694
- 6000+0.28869
- 国内价格
- 20+1.13270
- 100+0.67570
- 800+0.47300
- 3000+0.33790
- 6000+0.32100
- 30000+0.29730
