山东晶导微电子股份有限公司
Jingdao Microelectronics co.LTD
B0520WS THRU B0540WS
SCHOTTKY BARRIER RECTIFIERS
FEATURES
PINNING
• Low Forward Voltage Drop
PIN
DESCRIPTION
• Guard Ring Construction for Transient Protection
1
Cathode
• High Conductance
2
Anode
• Also Available in Lead Free Version
2
MECHANICAL DATA
▪Case: SOD-323
▪Terminals: Solderable per MIL-STD-750, Method 2026
▪A pprox. Weight: 5.48mg / 0.00019oz
1
Top View
Marking Code: SD,SE,SF
Simplified outline SOD-323 and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Symbols
B0520WS
B0530WS
B0540WS
Units
Peak Repetitive Reverse Voltage
V RRM
40
V
RMS reverse voltage reverse voltage (DC)
V RMS
14
21
28
V
Maximum DC Blocking Voltage
V DC
40
V
Parameter
Maximum Average Forward Current at Ta=25℃
Peak Forward Surge Current, 8.3ms single half
sine-wave superimposed on rated load (JEDEC method)
IO
0.5
A
I FSM
22
A
I F =0.1A
Maximum Instantaneous Forward Voltage
0.33
0.36
0.39
0.45
0.51
0.62
75
75
100
10
V R =30V
250
500
V R =40V
I F =0.5A
VF
I F =1A
V R =10V
V R =15V
Reverse current
V R =20V
IR
V
uA
RθJA
500
°C/W
Junction temperature
Tj
-55 ~ +125
°C
Storage temperature
T stg
-55 ~ +150
°C
Thermal Resistance, Junction to Ambient Air
2018.06
SOD323-S-B0520WS~B0540WS-0.5A40V
Page 1 of 3
山东晶导微电子股份有限公司
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
0.6
0.5
0.4
0.3
0.2
0.1
Single phase half-wave 60 Hz
resistive or inductive load
0.0
25
75
50
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 3
T J =100°C
10 2
T J =75°C
10 1
T J =25°C
10 0
Fig.3 TYPICAL FORWARD VOLTAGE
Peak Forward Surage Current (A)
60
80
100
Fig.4 Typical Junction Capacitance
100
Junction Capacitance ( pF)
1.0
T A=100℃
T A=25℃
0.1
0.01
0.2
0.3
0.4
70
40
30
0.5
0.1
INSTANTANEOUS FORWARD VOLTAGE, VOLTS
Fig.5 Maximum Non-Repetitive Peak
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
25
10
05
00
1
10
100
1
10
100
Reverse Voltage (V)
Fig.6 Typical Transient Thermal Impedance
2000
1000
100
10
0.01
Number of Cycles at 50Hz
2018.06
40
Percent of Rated Peak Reverse Voltage(%)
Transient Thermal Impedance( °C /W)
INSTANTANEOUS FORWARD CURRENT AMPERS
Case Temperature (°C)
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SOD-323
E
E
D
b
A
C
A1
∠ALL ROUND
L1
E1
SOD-323 mechanical data
A
C
D
E
E1
b
L1
A1
max
1.1
0.15
1.4
1.8
2.75
0.4
0.45
0.2
min
0.8
0.08
1.2
1.4
2.55
0.25
0.2
max
43
5.9
55
70
108
16
16
min
32
3.1
47
63
100
9.8
7.9
UNIT
mm
9°
8
mil
The recommended mounting pad size
1.4
(55)
1.2
(47)
Type number
Marking code
B0520WS
SD
B0530WS
SE
B0540WS
SF
1.2
(47)
1.2
(47)
Marking
Unit: mm
(mil)
2018.06
806252A6
Page 3 of 3
很抱歉,暂时无法提供与“B0520WS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.15768
- 200+0.12442
- 600+0.10595
- 国内价格
- 20+0.11774
- 300+0.08965
- 1200+0.08831
- 3000+0.07403
- 国内价格
- 1+0.33931
- 200+0.11310
- 1500+0.07053
- 3000+0.05602
- 国内价格
- 50+0.14454
- 600+0.09712
- 1200+0.09615
- 3000+0.09423
