MF254V-11-08-1000-H70
    XFCN(台湾兴飞)
    插件,P=2.54mm
    排母 间距2.54mm 8Pin(1x8) 圆孔 直插
MF254V-11-08-1000-H70 数据手册
Technical Data Materlal: Pin(outer sleeve):Brass,machined CuZn38Pb2 Plating(outer sleeve): Tin Plated:2μm/80μm"NI,5μm/200μ"Sn Gold Plated:2μm"/80μm"Ni,0.8μ" gold Plating(Contact ):2μm/80μ"NI,gold or Tin plated Insuiator:PPS UL94V-0 Cllp(Contact 6 Flnger):Beryllium copper,heat teated Electrical: Current rating:3Amps/contact max. Contact resistance:≤4mΩ/contact Insuiation resistance:≥1000MΩ at V=100V Operaing voitage:60VAC/DC Mechanical: Average Insertion force with steel pin of ∅0.432:<250g Average withdrawal force with steel pin of ∅0.432:>70g Mechanical lige cycle:min 200 Operaling temperature:-40°C to+105°C Soldering temperature:+255°C P.C.B LAYOUT 2.54mm Machined Female Header MF254V-11-xx-1000-H70
1. 物料型号:MF254V-11-xx-1000-H70 2. 器件简介:2.54mm Machined Female Header 3. 引脚分配:文档中未明确列出引脚分配,但提到了Pin(outer sleeve): Brass, machined CuZn38Pb2 4. 参数特性: - 电气特性:电流额定值3Amps/contact max. 接触电阻≤4mΩ/contact - 绝缘电阻:≥1000MΩ at V=100V - 操作电压:60VAC/DC - 机械特性:平均插入力<250g,平均拔出力>70g,机械寿命至少200次 - 操作温度:-40°C到+105°C - 焊接温度:+255°C 5. 功能详解:文档中未提供详细的功能解释,但提到了电气和机械特性 6. 应用信息:文档中未明确列出应用信息 7. 封装信息:绝缘体材料为PPS UL94V-0,接触材料为铍铜,热处理,电镀材料包括锡、镍和金
MF254V-11-08-1000-H70 价格&库存
很抱歉,暂时无法提供与“MF254V-11-08-1000-H70”相匹配的价格&库存,您可以联系我们找货
  • 5+1.72016
  • 50+1.35631
  • 150+1.20033
库存:211
  • 1+1.44900
  • 50+1.25580
  • 100+1.20750
  • 500+1.15920
  • 1000+1.13990
库存:1000
    • 5+1.64550
    • 50+1.46452
    • 150+1.38695
    • 500+1.18267
    • 2500+1.13958
    • 5000+1.11373
    库存:4077
