NO.
FUZETEC TECHNOLOGY CO., LTD.
PQ35-101E
Product Specification and Approval Sheet Version A2
Page
1/4
Surface Mountable PTC Resettable Fuse: FSMD0603 Series
1. Summary
(a) RoHS Compliant & Halogen Free
(b) Applications: All high-density boards
(c) Product Features: Small surface mountable, Solid state, Faster time to trip than
standard SMD devices, Lower resistance than standard SMD devices
(d) Operation Current: 0.01A~0.20A
(e) Maximum Voltage: 9V~60VDC
(f) Temperature Range : -40℃ to 85℃
2. Agency Recognition
UL:
C-UL:
TÜ V:
File No. E211981
File No. E211981
File No. R50090556
3. Electrical Characteristics (23℃)
Part
Hold
Trip
Rated
Max
Typical
Current
Current
Voltage
Current
Power
IH, A
IT, A
VMAX, VDC
IMAX, A
Pd, W
0.01
0.02
0.03
0.04
0.05
0.10
0.12
0.16
0.20
0.03
0.06
0.09
0.12
0.15
0.25
0.30
0.40
0.45
60
60
30
24
15
15
9
9
9
40
40
40
40
40
40
40
40
40
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
Number
FSMD001-0603-R
FSMD002-0603-R
FSMD003-0603-R
FSMD004-0603-R
FSMD005-0603-R
FSMD010-0603-R
FSMD012-0603-R
FSMD016-0603-R
FSMD020-0603-R
Max Time to Trip
Current
Resistance
Time
RMIN
R1MAX
A
Sec
Ohms
Ohms
0.20
0.20
0.20
0.20
0.50
0.70
0.80
1.00
2.00
1.00
1.00
1.00
1.00
0.10
0.10
0.10
0.10
0.10
15.00
12.00
6.00
4.00
3.80
0.90
1.10
1.00
0.55
100.00
70.00
50.00
40.00
30.00
8.00
5.80
4.20
3.50
IH=Hold current-maximum current at which the device will not trip at 23℃still air.
IT=Trip current-minimum current at which the device will always trip at 23℃ still air.
V MAX=Maximum voltage device can withstand without damage at it rated current.(I MAX)
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Typical power dissipated-type amount of power dissipated by the device when in the tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃ prior to tripping.
R1MAX=Maximum device resistance at 23℃ measured 1 hour after tripping or reflow soldering of 260℃ for 20 seconds.
Termination pad characteristics
Termination pad materials: Pure Tin
NOTE : Specification subject to change without notice.
2015/9/7
NO.
PQ35-101E
Page
2/4
4. FSMD Product Dimensions (Millimeters)
Part
Number
FSMD001-0603-R
FSMD002-0603-R
FSMD003-0603-R
FSMD004-0603-R
FSMD005-0603-R
FSMD010-0603-R
FSMD012-0603-R
FSMD016-0603-R
FSMD020-0603-R
A
B
C
E
D
Min
Max
Min
Max
Min
Max
Min
Max
Min
Max
1.40
1.40
1.40
1.40
1.40
1.40
1.40
1.40
1.40
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
1.80
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
0.45
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
1.00
0.35
0.35
0.35
0.35
0.35
0.35
0.35
0.35
0.35
0.85
0.85
0.75
0.75
0.75
0.75
0.75
0.75
0.75
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.10
0.50
0.50
0.50
0.50
0.50
0.50
0.50
0.50
0.50
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.08
0.40
0.40
0.40
0.40
0.40
0.40
0.40
0.40
0.40
5. Thermal Derating Curve
FSMD0603 Series
Percent of Rated Hold and Trip Current
200%
150%
100%
50%
0%
-40
-20
60
80
Ambient Temperature (℃)
2015/9/7
NO.
PQ35-101E
Page
3/4
6. Typical Time-To-Trip at 23℃
A=FSMD001-0603-R
A
B=FSMD002-0603-R
B
C
DE
F GHI
100
C=FSMD003-0603-R
D=FSMD004-0603-R
10
E=FSMD005-0603-R
G=FSMD012-0603-R
H=FSMD016-0603-R
I=FSMD020-0603-R
Time-to-Trip (s)
F=FSMD010-0603-R
1
0.1
0.01
0.001
0.01
0.1
1
10
Fault Current (A)
7. Material Specification
Terminal pad material: Pure Tin
Soldering characteristics: Meets EIA specification RS 186-9E, ANSI/J-std-002 Category 3
X=FSMD001-0603-R
8. Part Numbering and Marking System
Y=FSMD002-0603-R
Z=FSMD003-0603-R
Part Numbering System
Part Marking System
A=FSMD004-0603-R
B=FSMD005-0603-R
F S M D □ □ □ – 0603 - R
D
Current Rating
D=FSMD010-0603-R
Part Identification
Example
E=FSMD012-0603-R
F=FSMD016-0603-R
G=FSMD020-0603-R
Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible
甲、
electrical arcing and/or flame.
-PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent
condition and/or prolonged trip are not anticipated.
-Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device
performance.
2015/9/7
NO.
PQ35-101E
Page
4/4
9. Pad Layouts、Solder Reflow and Rework Recommendations
The dimension in the table below provide the recommended pad layout for each FSMD0603 device
Pad dimensions (millimeters)
A
Device
Nominal
FSMD0603 Series
0.80
B
Nominal
C
Nominal
0.60
0.80
Solder reflow
※ Due to “Lead Free” nature, Temperature and
Profile Feature
Average Ramp-Up Rate (Tsmax to Tp)
Preheat :
Temperature Min (Tsmin)
Temperature Max (Tsmax)
Time (tsmin to tsmax)
Pb-Free Assembly
3 ℃/second max.
Dwelling time for the soldering zone is higher
than those for Regular. This may cause
damage to other components.
150 ℃
200 ℃
60-180 seconds
Time maintained above:
Temperature(TL)
217 ℃
Time (tL)
60-150 seconds
Peak/Classification Temperature(Tp) : 260 ℃
Time within 5℃ of actual Peak :
20-40 seconds
Temperature (tp)
Ramp-Down Rate :
6 ℃/second max.
8 minutes max.
Time 25 ℃ to Peak Temperature :
Note 1: All temperatures refer to of the package,
measured on the package body surface.
1. Recommended max past thickness > 0.25mm.
2. Devices can be cleaned using standard
methods and aqueous solvent.
3. Rework use standard industry practices.
4. Storage Envorinment : < 30℃ / 60%RH
Caution:
1. If reflow temperatures exceed the
recommended profile, devices may not meet
the performance requirements.
2. Devices are not designed to be wave soldered
to the bottom side of the board.
Reflow Profile
2015/9/7
很抱歉,暂时无法提供与“FSMD010-0603-R”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.53158
- 100+0.42790
- 300+0.37606
- 1000+0.33718
- 4000+0.29387
- 8000+0.27832
- 国内价格
- 10+0.88440
- 100+0.82550
- 500+0.76650
- 1000+0.70760
- 2000+0.64860
- 4000+0.58960
