NO.
FUZETEC TECHNOLOGY CO., LTD.
PQ15-101E
Product Specification and Approval Sheet Version A0
Page
1/3
Radial Leaded PTC Resettable Fuse: FRT Series
1. Summary
(a) RoHS Compliant (Lead Free) Product
(b) Applications: IEEE 1394 FireWire, Computers & Consumer electronics
(c) Product Features: Fast trip time, Lower Trip-to-hold Ratio, Radial-leaded product
ideal for up to 36VDC
(d) Operation Current: 0.50A~2.50A
(e) Maximum Voltage: 36VDC
(f) Temperature Range : -40℃ to 85℃
2. Agency Recognition
UL:
C-UL:
TÜ V:
File No. E211981
File No. E211981
File No. R50004084
3. Electrical Characteristics (23℃)
Part
Trip
Max.Time
Max.
Rated
Typ.
Current
Current
To Trip
Current
Voltage
Power
RMIN
R1MAX
IH, A
IT, A
at 5XIH,S
IMAX, A
VMAX, VDC
Pd, W
Ohms
Ohms
0.50
0.75
0.90
1.20
1.35
1.60
1.90
2.20
2.50
1.10
1.50
1.80
2.30
2.50
2.75
3.00
3.50
4.00
5.0
4.0
3.5
3.5
4.5
4.5
3.5
6.5
8.0
40
40
40
40
40
40
40
40
40
36
36
36
36
36
36
36
36
36
0.67
0.71
0.74
0.78
0.84
0.86
0.90
0.95
0.99
0.140
0.115
0.090
0.074
0.059
0.041
0.045
0.025
0.020
0.448
0.368
0.288
0.180
0.143
0.131
0.092
0.080
0.064
Number
FRT050-33F
FRT075-33F
FRT090-33F
FRT120-33F
FRT135-33F
FRT160-33F
FRT190-33F
FRT220-33F
FRT250-33F
Resistance
Hold
IH=Hold current-maximum current at which the device will not trip at 23℃ still air.
IT=Trip current-minimum current at which the device will always trip at 23℃ still air.
V MAX=Maximum voltage device can withstand without damage at its rated current.
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Typical power dissipated from device when in tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃.
R1MAX=Maximum device resistance at 23℃, 1 hour after tripping .
Physical specifications:
Lead material: Tin plated copper, 24 AWG.
Soldering characteristics:MIL-STD-202, Method 208E.
Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement.
NOTE : Specification subject to change without notice.
2014/9/1
NO.
PQ15-101E
Page
2/3
4. Production Dimensions (millimeter)
Lead Size :24AWG
Φ 0.51 mm Diameter
Part
A
B
C
D
E
F
Number
Maximum
Maximum
Typical
Minimum
Maximum
Typical
FRT050-33F
FRT075-33F
FRT090-33F
FRT120-33F
FRT135-33F
FRT160-33F
FRT190-33F
FRT220-33F
FRT250-33F
7.4
7.4
7.4
7.4
7.4
7.4
9.0
10.0
10.0
12.2
12.2
12.2
12.2
14.2
14.0
13.5
17.0
19.5
5.1
5.1
5.1
5.1
5.1
5.1
5.1
5.1
5.1
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
3.0
3.0
3.0
3.0
3.0
3.0
3.0
3.0
3.0
1.1
1.1
1.1
1.1
1.1
1.1
1.1
1.1
1.1
5. Thermal Derating Curve
Percent of Rated Hold and Trip Current
FRT Series
200%
150%
100%
50%
0%
-40
-20
60
80
Ambient Temperature (℃)
2014/9/1
NO.
PQ15-101E
Page
3/3
6. Typical Time-To-Trip at 23℃
A B C DE FGH I
A= FRT050-33F
B= FRT075-33F
C= FRT090-33F
D= FRT120-33F
E= FRT135-33F
F= FRT160-33F
1000
Time-to-trip (S)
100
G= FRT190-33F
H= FRT220-33F
I = FRT250-33F
10
1
0.1
0.01
0.1
1
10
100
Fault current (A)
7. Material Specification
Soldering characteristics: MIL-STD-202, Method 208E.
8. Part Numbering and Marking System
Part Numbering System
Part Marking System
FRT □ □ □ ─ □ □ F
RoHS Compliant / Lead Free
F
RT135F
31AB
F
RT □ □ □ F
Voltage Rating
Fuzetec Logo
Part Identification
Product Family
Current Rating
Example
Date Code/Lot Number
Note: Font on Marking may look slightly different due to fine turnings of each Marking printer.
Warning: -Operation beyond the specified maximum ratings or improper use may result in damage and possible
electrical arcing and/or flame.
-PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent
condition and/or prolonged trip are not anticipated.
- Avoid contact of PPTC device with chemical solvent. Prolonged contact will damage the device
performance.
2014/9/1
很抱歉,暂时无法提供与“FRT190-33F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.79501
- 100+0.74201
- 300+0.68901
- 500+0.63600
- 2000+0.60950
- 5000+0.59360
- 国内价格
- 5+1.81527
- 50+1.43500
- 150+1.27192
