FUZETEC TECHNOLOGY CO., LTD.
NO.
PQ24-101E
Product Specification and Approval Sheet Version A8
Page
1/4
Radial Leaded PTC Resettable Fuse: FRV Series
1. Summary
(a) RoHS Compliant (Lead Free) Product
(b) Applications: Line Voltage Power Supply, Transformer and Appliances
(c) Product Features: Low hold current, Solid state, Radial leaded product ideal for up
to 265VAC/DC
(d) Operation Current: 0.05A~2.00A
(e) Maximum Operating Voltage: 240VAC/DC
(f) Maximum Interrupt Voltage: 265VAC/DC
(g) Temperature Range : FRV005-240F~FRV055-240F -40℃ to 85℃
FRV075-240F~FRV200-240F -20℃ to 85℃
2. Agency Recognition
UL:
C-UL:
TÜ V:
File No. E211981
File No. E211981
File No. R50087018
3. Electrical Characteristics (23℃)
Resistance
Hold
Trip
Max.Time
Max.
Rated
Max. Int.
Typ.
Current
Current
to Trip
Current
Voltage
Voltage
Power
RMIN
R1MAX
IH, A
IT, A
at 5XIH,S
IMAX, A
VMAX,
VI-MAX,
VAC/DC
VAC/DC
Pd, W
Ohms
Ohms
FRV005-240F
0.05
0.12
15.0
1.0
240
265
0.70
18.50
65.00
FRV008-240F
0.08
0.19
15.0
1.2
240
265
0.80
7.40
26.00
FRV012-240F
0.12
0.30
15.0
1.2
240
265
1.00
3.00
12.00
FRV016-240F
0.16
0.37
15.0
2.0
240
265
1.40
2.50
7.80
FRV025-240F
0.25
0.56
18.5
3.5
240
265
1.50
1.30
3.80
FRV033-240F
0.33
0.74
21.0
4.5
240
265
1.70
0.83
2.60
FRV040-240F
0.40
0.90
24.0
5.5
240
265
2.00
0.60
1.90
FRV055-240F
0.55
1.25
26.0
7.0
240
265
3.40
0.45
1.45
FRV075-240F
0.75
1.50
18.0
7.5
240
265
2.60
0.32
0.84
FRV100-240F
1.00
2.00
21.0
10.0
240
265
2.90
0.22
0.58
FRV125-240F
1.25
2.50
23.0
12.5
240
265
3.30
0.17
0.44
FRV150-240F
1.50
3.00
23.0
15.0
240
265
3.70
0.12
0.32
FRV200-240F
2.00
4.00
28.0
20.0
240
265
4.50
0.09
0.22
Part
Number
IH=Hold current-maximum current at which the device will not trip at 23℃ still air.
IT=Trip current-minimum current at which the device will always trip at 23℃ still air.
V MAX=Maximum voltage device can withstand without damage at its rated current.
I MAX= Maximum fault current device can withstand without damage at rated voltage (V MAX).
Pd=Typical power dissipated from device when in tripped state in 23℃ still air environment.
RMIN=Minimum device resistance at 23℃.
R1MAX=Maximum device resistance at 23℃, 1 hour after tripping.
Physical specifications:
Lead material: FRV005-240F~FRV016-240F Tin plated copper clad steel, 24AWG.
FRV025-240F~FRV040-240F Tin plated copper, 22AWG.
FRV055-240F~FRV200-240F Tin plated copper, 20AWG.
Soldering characteristics: MIL-STD-202, Method 208E.
Insulating coating:Flame retardant epoxy, meets UL-94V-0 requirement.
NOTE : Specification subject to change without notice.
2019/9/17
NO.
PQ24-101E
Page
2/4
4. Production Dimensions (millimeter)
Fig.1
Lead Size: 24AWG
Φ 0.51 mm Diameter
Part
Number
FRV005-240F
FRV008-240F
FRV012-240F
FRV016-240F
FRV025-240F
FRV033-240F
FRV040-240F
FRV055-240F
FRV075-240F
FRV100-240F
FRV125-240F
FRV150-240F
FRV200-240F
Fig.2
Lead Size: 22AWG
Φ 0.65 mm Diameter
Fig.3
Lead Size: 20AWG
Φ 0.81 mm Diameter
Fig.4
Lead Size: 20AWG
Φ 0.81 mm Diameter
A
B
C
D
E
F
Maximum
Maximum
Typical
Minimum
Maximum
Typical
8.3
8.3
8.3
9.9
9.6
11.4
11.5
14.0
11.5
18.7
21.2
23.4
24.9
10.7
10.7
10.7
12.5
17.4
16.5
19.5
21.7
23.4
24.4
27.4
30.9
33.8
5.1
5.1
5.1
5.1
5.1
5.1
5.1
5.1
5.1
10.2
10.2
10.2
10.2
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
7.6
3.8
3.8
3.8
3.8
3.8
3.8
3.8
4.1
4.8
5.1
5.3
5.3
6.1
1.6
1.6
1.6
1.6
1.8
1.8
1.8
1.9
1.9
1.9
1.9
1.9
1.9
Figure
1
1
1
1
2
2
2
3
3
4
4
4
3
2019/9/17
NO.
PQ24-101E
Page
3/4
5. Thermal Derating Curve
FRV Series
Precent of Rated Hold and Trip Current
200%
150%
100%
50%
A = FRV005-240F~
FRV055-240F
B = FRV075-240F ~
0%
-40
-20
60
80
FRV200-240F
Ambient Temperature (C)
6. Typical Time-To-Trip at 23℃
FRV Series
A B
CD
E
FG
HI
J KL M
1000
100
Time-to-trip (S)
A= FRV005-240F
B= FRV008-240F
C= FRV012-240F
D= FRV016-240F
E= FRV025-240F
F= FRV033-240F
G= FRV040-240F
H= FRV055-240F
I= FRV075-240F
J= FRV100-240F
K= FRV125-240F
L=FRV150-240F
M= FRV200-240F
10
1
0.1
0.01
0.1
1
10
100
Fault current (A)
2019/9/17
NO.
PQ24-101E
Page
4/4
7. Material Specification
Lead material:FRV005-240F~FRV016-240F Tin plated copper clad steel, 24AWG.
8. Part Numbering and Marking System
Part Numbering System
Part Marking System
FRV □ □ □ - □ □ □ F
F
RV □ □ F
RoHS Compliant / Lead Free
Voltage Rating
Current Rating
F
RV12F
91AB
Fuzetec Logo
Part Identification
Product Family
Example
Date Code/Lot Number
Note: Font on Marking may look slightly different due to fine turnings of each Marking printer.
Warning: - Each product should be carefully evaluated and tested for their suitability of application.
- Operation beyond the specified maximum rating or improper use may result in damage and possible
electrical arcing and/or flame.
- PPTC device are intended for occasional overcurrent protection. Application for repeated overcurrent
condition and/or prolonged trip are not anticipated.
- Avoid contact of PPTC device with chemical solvent, including some inert material such as silicone based
oil, lubricant and etc. Prolonged contact will damage the device performance.
- Additional protection mechanism are strongly recommended to be used in conjunction with the PPTC
device for protection against abnormal or failure conditions.
- Avoid use of PPTC device in a constrained space such as potting material, housing and containers
where have limited space to accommodate device thermal expansion and/or contraction.
2019/9/17
很抱歉,暂时无法提供与“FRV005-240F”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+2.00513
- 50+1.59138
- 150+1.41416
