MF254V-11-05-1000-H70
    XFCN(台湾兴飞)
    插件,P=2.54mm
    排母 间距2.54mm 5Pin(1x5) 圆孔 直插
MF254V-11-05-1000-H70 数据手册
Technical Data Materlal: Pin(outer sleeve):Brass,machined CuZn38Pb2 Plating(outer sleeve): Tin Plated:2μm/80μm"NI,5μm/200μ"Sn Gold Plated:2μm"/80μm"Ni,0.8μ" gold Plating(Contact ):2μm/80μ"NI,gold or Tin plated Insuiator:PPS UL94V-0 Cllp(Contact 6 Flnger):Beryllium copper,heat teated Electrical: Current rating:3Amps/contact max. Contact resistance:≤4mΩ/contact Insuiation resistance:≥1000MΩ at V=100V Operaing voitage:60VAC/DC Mechanical: Average Insertion force with steel pin of ∅0.432:<250g Average withdrawal force with steel pin of ∅0.432:>70g Mechanical lige cycle:min 200 Operaling temperature:-40°C to+105°C Soldering temperature:+255°C P.C.B LAYOUT 2.54mm Machined Female Header MF254V-11-xx-1000-H70
MF254V-11-05-1000-H70 价格&库存
很抱歉,暂时无法提供与“MF254V-11-05-1000-H70”相匹配的价格&库存,您可以联系我们找货
  • 1+0.64200
库存:401
  • 1+0.90220
  • 50+0.78190
  • 100+0.75190
  • 500+0.72170
  • 1000+0.70980
库存:1000
    • 5+1.32498
    • 50+1.05462
    • 150+0.93870
    • 500+0.70405
    • 2500+0.63961
    • 5000+0.60103
    库存:6746
