山东晶导微电子股份有限公司
ES3KB
Jingdao Microelectronics co.LTD
Surface Mount Superfast Recovery Rectifier
Reverse Voltage –800 V
Forward Current –3 A
PINNING
PIN
DESCRIPTION
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
1
Cathode
2
Anode
MECHANICAL DATA
• Case : SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight : 0.1g / 0.003oz
Top View
Marking Code: ES3K
2
1
Simplified outline SMB and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES3KB
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
800
V
Maximum RMS voltage
V RMS
560
V
Maximum DC Blocking Voltage
V DC
800
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
3
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
100
A
Maximum Forward Voltage at 3 A
VF
1.70
V
IR
5
100
μA
Cj
50
pF
t rr
35
ns
RθJA
RθJC
60
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2018.08
SMB-E-ES3KB-3A800V
Page 1 of 3
山东晶导微电子股份有限公司
ES3KB
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
3.5
300
3.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =25°C
1.0
0.1
0.01
T J =25°C
100
0.001
1.0
1.5
100
Fig.5 Typical Junction Capacitance
10
0.5
80
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
2.0
2.5
Instaneous Forward Voltage (V)
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2018.08
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
ES3KB
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
E1
The recommended mounting pad size
Marking
Type number
2.2
(86)
2.4
(94)
ES3KB
Marking code
ES3K
2.8
(110)
2.4
(94)
mm
Unit :
(mil)
2018.08
JD80804
Page 3 of 3
很抱歉,暂时无法提供与“ES3KB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.30650
- 100+0.24225
- 600+0.21018
- 1200+0.20703
- 3000+0.18612
- 国内价格
- 10+0.33437
- 100+0.26428
- 300+0.22929
- 3000+0.20304
