SSL26F
SSL26F
    JINGDAO(晶导微电子)
    SMAF(DO-214AD)
    表面贴装肖特基势垒整流器反向电压-40至60V正向电流-2.0A
SSL26F 数据手册
山东晶导微电子股份有限公司 SSL24F THRU SSL26F Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 40 and 60 V Forward Current - 2.0A PINNING PIN Features • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: SSL24 /SSL26 Simplified outline SMAF and symbol MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, Method 2026 • Approx. Weight: 27mg / 0.00095oz Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Parameter Symbols SSL24F SSL26F Units Maximum Repetitive Peak Reverse Voltage V RRM 40 60 V Maximum RMS voltage V RMS 28 42 V Maximum DC Blocking Voltage V DC 40 60 V Maximum Average Forward Rectified Current at T c = 100 °C I F(AV) 2 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 50 A Maximum Instantaneous Forward Voltage at 2 A VF 0.45 0.52 V IR 0.5 10 0.3 5 mA Cj 290 130 pF Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =100 °C Typical Junction Capacitance (1) (2) RθJA 70 °C/W Operating Junction Temperature Range Tj -55 ~ +150 °C Storage Temperature Range T stg -55 ~ +150 °C Typical Thermal Resistance (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2016.01 SMAF-S-SSL24F/SSL26F-2A60V Page 1 of 3 山东晶导微电子股份有限公司 SSL24F THRU SSL26F Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =75°C 10 2 SSL24W SSL26W 10 1 T J =25°C 10 0 0 Case Temperature (°C) 80 500 Junction Capacitance ( pF) 10 1 SSL24W SSL26W 0.1 0.5 0 1.0 1.5 200 100 50 SSL24W SSL26W 20 10 2.0 0.1 40 30 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 10 100 Transient Thermal Impedance( °C /W) 50 1 1 10 100 Reverse Voltage (V) 60 10 100 T J =25°C 20 Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Peak Forward Surage Current (A) 60 Fig.4 Typical Junction Capacitance Instaneous Forward Voltage (V) Fig.6- Typical Transient Thermal Impedance 100 Number of Cycles at 60Hz 2016.01 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic Instaneous Forward Current (A) T J =100°C 10 3 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 SSL24F THRU SSL26F Jingdao Microelectronics co.LTD PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE g Top View mil Bottom View A C D E e g HE max 1.2 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 47 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm g pad e E A pad D E A V M 7° The recommended mounting pad size Marking Type number 2.2 (86) 1.6 (63) Marking code SSL24F SSL24 SSL26F SSL26 1.8 (71) 1.6 (63) ∠ mm Unit : (mil) 2016.01 XTH601155B5 Page 3 of 3
SSL26F 价格&库存
很抱歉,暂时无法提供与“SSL26F”相匹配的价格&库存,您可以联系我们找货
SSL26F
  • 10+0.32833
  • 100+0.26390
  • 600+0.23174
  • 1200+0.22826
  • 3000+0.19007
库存:3000
