SS58C
SS58C
    JINGDAO(晶导微电子)
    SMC(DO-214AB)
    表面贴装肖特基势垒整流器反向电压-20至200 V正向电流-5.0A
SS58C 数据手册
山东晶导微电子股份有限公司 SS52C THRU SS520C Jingdao Microelectronics co.LTD Surface Mount Schottky Barrier Rectifier Reverse Voltage - 20 to 200V Forward Current - 5.0A PINNING PIN FEATURES • Metal silicon junction, majority carrier conduction • For surface mounted applications • Low power loss, high efficiency • High forward surge current capability • For use in low voltage, high frequency inverters, free wheeling, and polarity protection applications DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: SS52 ~ SS520 Simplified outline SMC and symbol MECHANICAL DATA • Case: SMC • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 0.22g / 0.0077oz Absolute Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified.Single phase, half wave, 60Hz resistive or inductive load, for capacitive load, derate by 20 % Symbols Parameter SS52C SS54C SS56C SS58C SS510C SS512C SS515C SS520C Units Maximum Repetitive Peak Reverse Voltage V RRM 20 40 60 80 100 120 150 200 V Maximum RMS voltage V RMS 14 28 42 56 70 84 105 140 V Maximum DC Blocking Voltage V DC 20 40 60 80 100 120 150 200 V Maximum Average Forward Rectified Current I F(AV) Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM Max Instantaneous Forward Voltage at 5 A Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =100°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range VF 175 0.55 0.70 1.0 50 IR Cj A 5.0 A 0.85 V mA 400 600 150 pF RθJA 35 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2017.12 SMC-S-SS52C~SS520C-5A200V Page 1 of 3 山东晶导微电子股份有限公司 SS52C THRU SS520C Jingdao Microelectronics co.LTD Fig.2 Typical Reverse Characteristics Average Forward Current (A) 6.0 5.0 4.0 3.0 2.0 1.0 0.0 25 50 75 100 125 150 Instaneous Reverse Current ( μA) Fig.1 Forward Current Derating Curve 10 4 T J =100°C 10 3 10 1 T J =25°C 10 0 0 Case Temperature (°C) 60 80 100 Fig.4 Typical Junction Capacitance T J =25°C Junction Capacitance ( pF) 20 10 1 SS52C/SS54C SS56C/SS58C SS510C/SS520C 0.1 0 0.5 1.0 1.5 100 SS52C/SS54C SS54F/SS520F SS56C~SS520C 20 10 0.1 1 10 100 Reverse Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance SS52C~SS58C 175 SS510C~SS520C 150 125 100 75 50 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 500 Instaneous Forward Voltage (V) 180 25 1000 2.0 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) Peak Forward Surage Current (A) 40 20 Percent of Rated Peak Reverse Voltage(%) Fig.3 Typical Forward Characteristic 100 10 Number of Cycles at 60Hz 2017.12 T J =75°C 10 2 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 3 山东晶导微电子股份有限公司 SS52C THRU SS520C Jingdao Microelectronics co.LTD PACKAGE OUTLINE SMC Plastic surface mounted package; 2 leads E A A1 A C b D L E1 VM A SMC mechanical data A E D E1 A1 C L b max 2.62 7.0 6.2 8.0 0.21 0.31 1.6 3.25 min 2.00 6.5 5.6 7.6 0.05 0.15 0.9 2.75 max 103 276 244 315 8.3 12 63 128 min 79 256 220 299 2.0 5.9 35 108 UNIT mm mil Marking The recommended mounting pad size Type number 3.8 (150) 4.1 (160) 4.3 (170) 4.1 (160) mm Unit : (mil) 2017.12 712297B0 Marking code SS52C SS52 SS54C SS54 SS56C SS56 SS58C SS58 SS510C SS510 SS512C SS512 SS515C SS515 SS520C SS520 Page 3 of 3
SS58C
物料型号:SS52C至SS520C
器件简介:这些是金属硅结、多数载流子导电的表面安装肖特基势垒整流器,具有低功耗、高效率、高正向浪涌电流能力,适用于低电压、高频率逆变器、自由轮和极性保护应用。
引脚分配:有两个引脚,1号引脚为阴极,2号引脚为阳极。
参数特性:包括最大重复峰值反向电压(VRRM)、最大RMS电压(VRMS)、最大直流阻断电压(Voc)、最大平均正向整流电流(IF(AV))、正向浪涌电流(IFSM)、最大瞬态正向电压(VF)、最大直流反向电流(IR)、典型结电容(C1)和典型热阻(ROJA)。
功能详解:提供了正向电流降额曲线、典型反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流等图表。
应用信息:适用于低电压、高频率逆变器、自由轮和极性保护等应用。
封装信息:塑料表面安装封装,2个引脚,提供了详细的机械数据和推荐的安装垫尺寸。
SS58C 价格&库存
很抱歉,暂时无法提供与“SS58C”相匹配的价格&库存,您可以联系我们找货
SS58C
  • 20+0.72300
  • 100+0.43120
  • 800+0.30190
  • 3000+0.21560
  • 6000+0.20480
  • 30000+0.18980
库存:4381
SS58C
    • 1+0.43170
    库存:10
    SS58C
    • 5+0.16350
    • 20+0.16050
    • 100+0.15450
    库存:2402
