山东晶导微电子有限公司
ES5AC THRU ES5JC
Jingdao Microelectronics
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 50 to 600 V
Forward Current –5 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
2
1
MECHANICAL DATA
• Case : SMC
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight : 0.22g / 0.0077oz
Top View
Marking Code: ES5A~ES5J
Simplified outline SMC and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
Parameter
ES5AC ES5BC ES5CC
ES5DC
ES5EC ES5GC
ES5JC
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
150
200
300
400
600
V
Maximum RMS voltage
V RMS
35
70
105
140
210
280
420
V
Maximum DC Blocking Voltage
V DC
50
100
150
200
300
400
600
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
5
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
120
A
Maximum Forward Voltage at 5 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
1.25
1
1.68
V
IR
5
100
μA
Cj
50
pF
t rr
35
ns
RθJA
RθJC
35
13
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.04
SMC-E-ES5AC~ES5JC-3A600V
Page 1 of 3
山东晶导微电子有限公司
ES5AC THRU ES5JC
Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram
50 ohm
Noninductive
t rr
10 ohm
Noninductive
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
NonInductive
OSCILLOSCOPE
Note 1
-1.0
Note:1.Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
7.0
300
6.0
100
I R - Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
5.0
4.0
3.0
2.0
1.0
Single phase half-wave 60 Hz
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
Case Temperature (°C)
Junction Capacitance ( pF)
Instaneous Forward Current (A)
T J =25°C
1.0
ES5AC~ES5DC
ES5EC/ES5GC
ES5JC
0.01
T J =25°C
100
0.001
0.5
1.0
1.5
100
Fig.5 Typical Junction Capacitance
10
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
0.1
60
2.0
2.5
Instaneous Forward Voltage (V)
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
140
120
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2017.04
www.sdjingdao.com
Page 2 of 3
山东晶导微电子有限公司
ES5AC THRU ES5JC
PACKAGE OUTLINE
SMC
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
SMC mechanical data
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
Marking
The recommended mounting pad size
3.8
(150)
4.1
(160)
4.3
(170)
4.1
(160)
Type number
Marking code
ES5AC
ES5A
ES5BC
ES5B
ES5CC
ES5C
ES5DC
ES5D
ES5EC
ES5E
ES5GC
ES5G
ES5JC
ES5J
mm
Unit :
(mil)
2017.04
JD704229B5
Page 3 of 3
很抱歉,暂时无法提供与“ES5GC”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.40878
- 100+0.32735
- 300+0.28674
- 3000+0.25618
- 国内价格
- 1+0.22500
- 100+0.21000
- 300+0.19500
- 500+0.18000
- 2000+0.17250
- 5000+0.16800
- 国内价格
- 10+0.37472
- 100+0.30007
- 600+0.26285
- 1200+0.25891
- 3000+0.23483
- 国内价格
- 20+0.71330
- 100+0.42550
- 800+0.29790
- 3000+0.21270
- 6000+0.20220
- 30000+0.18720
