山东晶导微电子股份有限公司
SSL54B
Jingdao Microelectronics co.LTD
Surface Mount Schottky Barrier Rectifier
Reverse Voltage - 40V
Forward Current - 5.0A
PINNING
PIN
FEATURES
• Metal silicon junction, majority carrier conduction
• For surface mounted applications
• Low power loss, high efficiency
• High forward surge current capability
• For use in low voltage, high frequency inverters,
free wheeling, and polarity protection applications
MECHANICAL DATA
• Case: SMB
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.1g / 0.0034oz
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: SSL54
Simplified outline SMB and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
SSL54B
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
40
V
Maximum RMS voltage
V RMS
28
V
Maximum DC Blocking Voltage
V DC
40
V
Maximum Average Forward Rectified Current
at T c = 100 °C
I F(AV)
5
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
150
A
Maximum Instantaneous Forward Voltage at 5A
VF
0.45
V
IR
1.0
50
mA
Cj
800
pF
RθJA
45
°C/W
Operating Junction Temperature Range
Tj
-55 ~ +150
°C
Storage Temperature Range
T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =100 °C
Typical Junction Capacitance
(1)
Typical Thermal Resistance
(2)
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2017.08
SMB-S-SSL54B-5A40V
Page 1 of 3
山东晶导微电子股份有限公司
SSL54B
Fig.2 Typical Reverse Characteristics
Average Forward Current (A)
6
5
4
3
2
1
50
75
100
125
150
Instaneous Reverse Current ( μA)
Fig.1 Forward Current Derating Curve
10 4
10 1
T J =25°C
10 0
80
1000
T J =25°C
Junction Capacitance ( pF)
1
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
50
0.1
1
10
100
Instaneous Forward Voltage (V)
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
150
125
100
75
50
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
500
1.8
175
25
100
Fig.4 Typical Junction Capacitance
10
100
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
Peak Forward Surage Current (A)
T J =75°C
10 2
Case Temperature (°C)
200
100
10
Number of Cycles at 60Hz
2017.08
T J =100°C
10 3
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
SSL54B
PACKAGE OUTLINE
SMB
Plastic surface mounted package; 2 leads
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
3.3
5.08
0.05
0.8
0.152
1.9
155
220
7.9
59
12
87
200
2.0
32
6
75
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
max
96
185
min
84
130
160
The recommended mounting pad size
E1
Marking
Type number
2.2
(86)
SSL54B
2.4
(94)
SSL54
2.8
(110)
2.4
(94)
Marking code
mm
Unit :
(mil)
2017.08
709127B0
Page 3 of 3
很抱歉,暂时无法提供与“SSL54B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.57959
- 20+0.52559
- 100+0.47159
- 500+0.41759
- 1000+0.39239
- 2000+0.37439
- 国内价格
- 5+0.61809
- 50+0.48590
- 150+0.41980
- 500+0.37023
- 3000+0.33059
- 6000+0.31072
- 国内价格
- 20+1.16620
- 100+0.69570
- 800+0.48700
- 3000+0.34790
- 6000+0.33050
- 30000+0.30610
