山东晶导微电子股份有限公司
ES1K
Jingdao Microelectronics co.LTD
Surface Mount Superfast Recovery Rectifier
Reverse Voltage – 800 V
PINNING
Forward Current – 1 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Superfast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
DESCRIPTION
1
Cathode
2
Anode
2
1
Top View
Marking Code: ES1K
Simplified outline SMA and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
ES1K
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
800
V
Maximum RMS voltage
V RMS
560
V
Maximum DC Blocking Voltage
V DC
800
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Forward Voltage at 1 A
VF
1.7
V
IR
5
100
μA
Cj
15
pF
t rr
35
ns
RθJA
60
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 1.0 X 1.0" (2.54 X 2.54 cm) copper pad areas.
2018.11
SMA-E-ES1K-1A800V
Page 1 of 3
山东晶导微电子股份有限公司
ES1K
Average Forward Current (A)
1.2
1.0
0.8
0.6
0.4
0.2
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Junction Capacitance ( pF)
Fig.5 Typical Junction Capacitance
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.1
1.0
10
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
35
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
Number of Cycles
2018.11
100
100
山东晶导微电子股份有限公司
ES1K
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
b
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
b
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
0.2
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
0.05
max
87
181
106
205
12
63
59
7.9
min
75
157
91
185
6
51
35
2
UNIT
mm
mil
g
e
A
D
0.3
The recommended mounting pad size
1.8
(71)
ES1K
Marking code
ES1K
1.8
(71)
2.4
(94)
12
Marking
Type number
1.8
(71)
a
mm
Unit :
(mil)
2018.11
JD811104B6
Page 3 of 3
很抱歉,暂时无法提供与“ES1K”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.10930
- 500+0.08511
- 1500+0.07172
- 5000+0.06372
- 25000+0.05670
- 50000+0.05292
- 国内价格
- 20+0.33430
- 100+0.20720
- 500+0.13680
- 5000+0.09780
- 10000+0.09290
- 50000+0.08600
- 国内价格
- 5+0.05040
- 20+0.04950
- 100+0.04770
