山东晶导微电子股份有限公司
US1A THRU US1M
Jingdao Microelectronics co.LTD
SURFACE MOUNT ULTRAFAST RECOVERY RECTIFIER
PINNING
Reverse Voltage - 50 to 1000 V
PIN
Forward Current - 1 A
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• High efficiency
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: US1A~US1M
Simplified outline SMA and symbol
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
US1A
US1B
US1D
US1G
US1J
US1K
US1M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Parameter
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
1
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
30
A
Maximum Instantaneous Forward Voltage at 1 A
VF
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Maximum Reverse Recovery Time (1)
Typical Thermal Resistance
(2)
Typical Junction Capacitance
(3)
Operating and Storage Temperature Range
1.0
1.3
5
100
IR
t rr
1.65
μA
75
50
V
ns
RθJA
75
°C/W
Cj
15
pF
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
(3)Measured at 1 MHz and applied reverse voltage of 4 V D.C
2016.11
SMA-U-US1A~US1M-1A1KV
Page 1 of 3
山东晶导微电子股份有限公司
US1A THRU US1M
Fig.2 Typical Reverse Characteristics
1.2
1.0
0.8
0.6
0.4
0.2
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
Peak Forward Surage Current (A)
Instaneous Forward Current (A)
10
T J =25°C
1.0
US1A~US1D
US1G
US1J~US1M
0.01
0.001
1.0
1.5
2.0
100
120
140
30
25
10
05
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
2.5
10
100
Number of Cycles
Fig.5- Typical Transient Thermal Impedance
100
Fig.6 Typical Junction Capacitance
Junction Capacitance ( pF)
Transient Thermal Impedance( °C /W)
80
35
10
100
T J=25°C
10
1
0.1
1
10
100
0.1
1.0
10
100
Reverse Voltage (V)
t, Pulse Duration(sec)
2016.11
60
40
Instaneous Forward Voltage (V)
1
0.01
40
Fig.4 Maximum Non-Repetitive Peak
Fig.3 Typical Forward Characteristics
0.1
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
US1A THRU US1M
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
a
0.3
12
Marking
Type number
2.4
(94)
mm
Unit :
(mil)
2016.11
US1A
US1A
US1B
US1B
US1D
US1D
US1G
US1G
US1J
US1J
US1K
US1K
US1M
US1M
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
JD611294B6
Page 3 of 3
很抱歉,暂时无法提供与“US1A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12345
- 500+0.10023
- 1500+0.08727
