FRL-Series
Low Resistance Thick Chip Resistor
FRL 系列低阻厚膜片晶片电阻
■ 低阻厚膜晶片电阻(Low Resistance Thick Film Chip Resistor)
■ 应用(Application)
Entertainment:Stereo, TV tuners,Tape recorder
娱乐:立体声,电视调谐器,录音机
Appliance: Air conditioner, Refrigerator
电器:空调、冰箱
Computer & relative products : Main board, PDA
电脑及相关产品:主板、掌上电脑
Communication equipment: Cell phone, Fax machine
通讯设备:手机、传真机
Power equipment: Power supply , II Lumination equipment
电源设备:电源、二级照明设备
Measuring instrument: Electric meter, Navigation equipment
测量仪器:电表、导航设备
■ 特点(Features)
Small size and light weight
体积小,重量轻
Reliability, high quality
可靠性,高质量
Low Resistance & Suitable for Large Current Application
Ultra-low Value
低阻值, 适合大电流通过
- 超低阻值
■料号说明(Parts Number Explanation):
示例 Example:
FRL1206JR470TSW
F
R
L
公司名
产品别
功能别
FOJAN
1206
型别
F
R470
T
S
W
公差
字码
包装别
端电极
特殊型
R:Resistor
C:Normal
0402
B:±0.1%
±5%:E24
T: 7 inch reel
S:Sn
A:10ppm
C:Capacitor
P:Hi-Power
0603
C:±0.25%
3-digits+blank
Q:10 inch reel
C:Cu
E:15ppm
L:Inductor
L:Lowohmic
0805
D:±0.5%
102=1KΩ
R:13 inch reel
A:Au
X:25ppm
D:Diode
A:Array
1206
F:±1%
1R0=1Ω
B:Bulk
A:Audion
S:Surge
1210
J:±5%
±1%&Below:
H:Hi-Precision
2010
P:Jumper
E24+E96:
V:Hi-Voltage
1812
4-digits
Q:Auto-motive
2512
1001=1KΩ
R:Anti-sulfur
V:50ppm
W:100PPm
1R00=1Ω
M:Metal
D: LED
Company
code
1
Type code
Functional
code
FJ-JS-3004-V1.0 / 2024.1.24
Size code
Tolerance
code
Resistance code
Packaging
Termination
Special
code
code
code
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
■尺寸 (Dimension)
尺寸
dimension
单位(unit): mm
型别(Type)
L
W
H
T1
T2
0402
1.00±0.05
0.50±0.05
0.35±0.05
0.20±0.10
0.25±0.10
0603
1.60±0.10
0.80±0.10
0.45±0.10
0.25±0.15
0.25±0.15
0805
2.00±0.10
1.25±0.10
0.50±0.10
0.35±0.20
0.35±0.20
1206
3.10±0.10
1.60±0.10
0.55±0.10
0.45±0.20
0.40±0.20
1210
3.10±0.10
2.50±0.15
0.55±0.10
0.45±0.15
0.50±0.20
2010
5.00±0.10
2.50±0.15
0.55±0.10
0.45±0.15
0.50±0.20
1812
4.50±0.20
3.10±0.20
0.55±0.10
0.55±0.20
0.70±0.20
2512
6.35±0.10
3.10±0.15
0.55±0.10
0.60±0.20
0.90±0.20
■ 电阻结构(Construction)
NO.
结构
construction
主要材料
Major material
1
陶瓷基板
Ceramic substrate
三氧化二铝
2
银电极
Conductive layer
银
Ag
3
侧电极
Side conductive layer
镍铬合金
NiCr
4
阻体层
Resistive layer
氧化钌+玻璃
RuO2 + glass
5
内保护层
Inner protective layer
玻璃
Glass
6
外保护层
Outer Protective layer
环氧树脂
Epoxy
7
文字
Marking
环氧树脂
Epoxy
8
镍电极
Ni plating layer
镍
Ni
9
锡电极
Sn plating layer
锡
Matte Tin
Al2O3
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
■ 功率衰减曲线( Derating Curve)
■ 阻值范围(Resistance range)
阻值范围
Resistance Range
型别 Type
1%
5%
0402
0R1~1Ω
0R1~1Ω
0603
0R01~1Ω
0R01~1Ω
0805
0R01~1Ω
0R01~1Ω
1206
0R01~1Ω
0R01~1Ω
1210
0R01~1Ω
0R01~1Ω
2010
0R01~1Ω
0R01~1Ω
1812
0R01~1Ω
0R01~1Ω
2512
0R01~1Ω
0R01~1Ω
如有非标准品的需求,请联系我们的业务部门 For non-standard parts, please contact our sales dept.
■电气特性(Electrical characteristics)
型别
Type
额定功率
(Power
Rating at
70℃)
绝缘耐压
Dielectric
Withstandin
g Voltage
额定电流
Rated
Current
of
Jumper
最大电流
Max
Current of
Jumper
0402
1/16W
100V
0.79A
1.97A
0603
1/10W
100V
2.23A
5.59A
0805
1/8W
300V
2.5A
6.25A
1206
1/4W
500V
3.53A
8.83A
1210
1/2W
500V
5A
12.50A
1812
3/4W
500V
6.12A
15.30A
2010
3/4W
500V
6.12A
15.30A
2512
1W
500V
7.07A
17.67A
T.C.R.
(PPM/℃)
0.02Ω~0.06(含):
阻值范围
Resistance Range
0R1~1Ω
±1200PPM/℃
0.06Ω~0.2(含):
±600PPM/℃
0R01~1Ω
0.2Ω~0.5(含):
±300PPM/℃
>0.5Ω:±200PPM/℃
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
备注(remark): 额定电流计算公式(The rated current is calculated by the following formula):
I=
P /R
I:额定电流(Rated Current) (V)
P:额定功率(Rated Power ) (W)
R:电阻阻值(Resistance
) (ohm)
如果计算出的电流超过此型别的最大工作电流,则此型别的最大工作电流为此电阻的额定电流。
In case the value calculated by the formula exceed the maximum working current as above table 8, the maximum working
current shall be regarded as rated current.
■ 性能(Performance Specifications)
内容
Item
测试方法
Test Methods
测试条件
Test Conditions
规格
Specification
TCR=(R-R0 )/(t-t0)R0 ×106
(ppm)
R0 电阻在室温下的阻值(resistance at
0.02Ω~0.06(含):
±1200PPM/℃
0.06Ω~0.2(含):
温度系数
Temperature
Coefficient
room temperature)
JIS C 5201 4.8
R 电阻在 125 或-55℃下的阻值(resistance
±600PPM/℃
0.2Ω~0.5(含):
at 125℃ or -55℃)
t0 室温(room temperature)
t 测试温度(test temperature 125℃
±300PPM/℃
>0.5Ω:
±200PPM/℃
or -55℃)
加载 2.5 倍的额定电压,时间 5 秒后测
量试验前后的阻值变化率。
短时间过负荷
Short-time overload
JIS C 5201 4.13
Applied 2.5 times of rated voltage for 5
±(1.00% +0.05Ω)
second. Measure the variation of
resistance.
沾助焊剂后浸入锡炉,锡炉温度 245±5℃
焊锡性 Solderability
JIS C 5201 4.17
,时间 3±0.5 秒。
Dip the terminal in a flux and then dip into a
>95%面积上锡
(>95% coverage)
soldering bath at 245±5℃ ,for 3±0.5sec.
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
内容
Item
测试方法
Test Methods
测试条件
Test Conditions
规格
Specification
沾助焊剂后浸入锡炉,锡炉温度 260±5℃
,时间 10±0.5 秒, 测量试验前后的阻值
抗焊锡热
Resist to soldering
heat
变化率。
JIS C 5201 4.18
±(1.00% +0.05Ω)
soldering bath at 260±5℃, for 10±0.5sec.
resistance.
电阻本体上加载绝缘耐压 60±5 秒后,测
量绝缘阻抗。
绝缘电阻
Insulation resistance
JIS C 5201 4.6
Applied the dielectric withstanding
>10GΩ
voltage on the center of body for
60±5seconds. Then measure insulation
resistance.
电阻本体上加载绝缘耐压 60±5 秒。
绝缘耐压
Dielectric withstanding
voltage
JIS C 5201 4.7
无击穿、飞弧及可见机械性
损伤
No evidence of flashover,
mechanical damage arcing
for60±5seconds.
or insulation breakdown
电阻焊接在测试板上进行弯折,弯折保持
时间 20±1 秒,1206(含) 以下的尺寸弯
曲 5+0.2/0 mm; 1206 以上的尺寸弯曲
2+0.2/0 mm; 量测试验前后阻值变化率
Specimen shall be mounted on test
端子弯曲
Terminal bending
JIS C 5201 4.33
board, then bend the board and
±(1.00% +0.05Ω)
maintained for 20±1s. the distance of
bending is 5+0.2/0 mm for resistors
which size no larger than 1206 or
2+0.2/0 mm which size larger than
1206. Measure the variation of
resistance.
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
内容
Item
测试方法
Test Methods
测试条件
Test Conditions
规格
Specification
电阻放入温度循环机中,T1 温度:-55±
3℃;T2 温度:155±3℃./125±3℃,放
置 30 分钟,共 300 个循环。量测试验前
温度快速变化
Rapid temperature
后阻值变化率.
JIS C 5201 4.19
Put specimen in a chamber which
±(1.00% +0.05Ω)
temperature can be T1: -55±3℃;
changes
T2: 155±3℃/125±3℃, 30min,
repeated 300 cycles. Measure the
variation of resistance.
电阻放入恒温恒湿箱,温度 40±2℃
,湿度 90~95 %RH;通电额定电压 1.5 小
时,断电 0.5 小时;重复通断电至试验时
间 1000 +48/-0 小时. 量测试验前后阻值
变化率.
耐湿特性
Humidity
JIS C 5201 4.24
Put the specimen in a chamber at 40±2℃
±(2.00% +0.05Ω)
temperature and 90~95% relative
humidity, then applied rated voltage
for1.5H and rested for 0.5H repeatedly
till total test time is 1000+48/-0 H.
Measure the variation of resistance.
电阻放入恒温箱中,温度 70±2℃,ON
TIME:1.5H,OFF TIME:0.5H,通电额定电
压 1000 +24/-0 小时,量测试验前后阻值变化
率.
负荷寿命
Load life
JIS C 5201 4.25.1
Put the specimen in a chamber at 70±2℃
±(2.00% +0.05Ω)
temperature, ON TIME:1.5H,OFF
TIME:0.5H, and applied rated voltage for
1000 +24/-0H. Measure the variation of
resistance.
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
25°C~65°C,90~100%RH, 2.5 小时;
65°C 90~100%RH, 3 小时;
65°C~25°C,80~100%RH,2.5 小时,10 个
循环,试验结束 24±4 小时后进行测试.
温湿循环
Moisture resistance
MIL-STD-202 METHOD
106
25°C~65°C,90~100%RH, 2.5H; 65°C
±(2.00% +0.05Ω)
90~100%RH, 3H; 65°C~25°C
80~100%RH, 2.5H, 10 cycles,
Measurement at 24±4 hours after test
conclusion.
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
■ 包装规格(Tapping Specification)
-卷盘尺寸(Reel dimension)
Type
Size
Unit
A
B
C
F
W
0402
7”
10K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
0402
13”
40K/50K Reel
mm
330±2.0
100.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
0603
0805
1206
1210
7”
5K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
10”
10K/Reel
mm
254±2.0
100.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
13”
20K/Reel
mm
330±2.0
100.0±1.0
13.5±0.5
11.4±0.1
9.00±0.3
7”
4K/Reel
mm
178±2.0
60.0±1.0
13.5±0.5
15.4±1.0
13.0±0.3
0603
0805
1206
0603
0805
1206
1812
2010
2512
-包装尺寸(packing dimension)
Unit: mm
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
Dimensions
A
B
D
F
P0
P1
P2
W
0402
0.65±0.10
1.15±0.10
1.50± 0.1
0. 0
3.50±0.05
4.00±0.10
2.00±0.10
2.00±0.05
8.00±0.20
0603
1.10±0.10
1.90±0.10
1.50± 0.1
0. 0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
0805
1.65±0.20
2.40±0.20
1.50± 0.1
0. 0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
1206
1.90±0.20
3.50±0.20
1.50± 0.1
0. 0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
1210
2.80±0.20
3.50±0.20
1.50± 0.1
0. 0
3.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
8.00±0.20
1812
3.30±0.20
4.60±0.20
1.50± 0.1
0. 0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
2010
2.90±0.10
5.30±0.10
1.50± 0.1
0. 0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
2512
3.40±0.10
6.60±0.10
1.50± 0.1
0. 0
5.50±0.05
4.00±0.10
4.00±0.10
2.00±0.05
12.0±0.10
■ 上胶带剥离力测试(Peel force of top cover tape)
上胶带以 200mm/分钟的速度,沿 165~180 度角的方向进行剥离,如下图所示。纸带的剥离力范围为
10g~70g; 载带的剥离力范围为 30~100g。
The top cover tape is pulled at a speed of 200 mm/min with the angle between the tape during peel and the
direction of unreeling maintained at 165 to 180 degree as following picture. The peel force of paper carrier
tape shall be 0.1N to 0.7N(10 to 70 g), the peel force of plastic carrier tape shall be 0.3N to 1N (30 to 100 g)
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
■ 焊接 (soldering)
- 建议回流焊曲线(Recommend reflow soldering profile)
-建议波峰焊曲线(Recommend wave soldering profile)
-手工焊温度(hand soldering temperature)
烙鐵温度 350±10℃ 3 秒之內,避免烙铁接触电阻本体
The iron temperature is 350±10℃, hand soldering time less than 3S. Avoid solder iron tip
direct touch the components body
www.fojan.cn
FRL-Series
FRL 系列低阻厚膜晶片电阻
■ 厚膜电阻器使用说明(Chip Resistor Instructions for use)
- 本产品在以下特殊环境下应用,性能可能会收到影响(Application of the products in a special
environment can deteriorate product performance):
1. 高温;
High temperature
2. 有海风或腐蚀性气体,包括氯气,硫化氢,氨气,二氧化硫,二氧化氮等;
Near the sea ,or corrosive gas, such as Cl2,H2S,NH3,SO2,and NO2,etc;
3. 各种类型的液体,包括水,油,化学品,有机溶剂的使用;
Unverified liquids, such as water,oil,chenical or organic solvent;
4. 在用树脂或其他涂层材料密封产品的情况下使用;
Unverified resin or paint to cover products;
5. 焊接后使用不洁焊剂或使用水或水溶性清洁剂清洗产品
Products should be washed with soluble cheaner even if non cleaning flux.
- 储存 / 搬运条件(STORAGE / CARRY CONDITIONS)
6. 储存温度 25±5℃
Temperature:25±5℃
7. 湿度 30~70%RH
Humidity:30~70%RH
8. 储存期限:先进先出,2 年
Storage life:2years FIFO
9. 存放和搬运时,请保持盒子的正确方向。严禁跌落在箱体上,否则可能损坏产品电极或本体
Please hold
box correct orientation when storing and carrying.It is strictly prohibited to fall on the
box.otherwise the product electrode or body may be damaged.
www.fojan.cn
很抱歉,暂时无法提供与“FRL0603FR500TS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 100+0.03560
- 1000+0.03020
- 5000+0.02540
- 10000+0.02400
- 50000+0.02230
- 国内价格
- 100+0.03571
- 1000+0.03028
- 5000+0.02555
- 10000+0.02422
- 50000+0.02248
- 国内价格
- 100+0.03273
- 1000+0.02775
- 2000+0.02733
- 5000+0.02341
- 国内价格
- 1+0.08063
- 500+0.02684
- 5000+0.01793
