S2AG THRU S2MG
Surface Mount General Purpose Silicon Rectifiers
Reverse Voltage - 50 to 1000 V
Forward Current - 2 A
PINNING
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
2
Top View
Marking Code: S2A-S2M
Simplified outline SMA and symbol
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Symbols
S2AG
S2BG
S2DG
S2GG
S2JG
S2KG
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
70
A
Maximum Instantaneous Forward Voltage at 2 A
VF
1.1
V
IR
5
100
μA
Cj
25
pF
RθJA
65
°C/W
T j , T stg
-55 ~ +150
°C
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
Typical Thermal Resistance
(1)
(2)
Operating and Storage Temperature Range
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
REV.08
1 of 3
S2MG
Units
S2AG THRU S2MG
Fig.2 Typical Instaneous Reverse
Characteristics
Instaneous Reverse Current ( μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
2.5
2.0
1.5
1.0
0.5
0.0
25
50
75
100
125
150
175
100
T J =150°C
T J =125°C
10
T J =100°C
1.0
T J =75°C
0.1
T J =25°C
0.01
Junction Capacitance ( pF)
Instaneous Forward Current (A)
10
1.0
800
100
T J =25°C
10
T J =25°C
0.1
0.4
1
0.6
0.8
1.0
1.2
1.4
1.6
1.8
0.1
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
100
80
60
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
1.0
10
Reverse Voltage (V)
Instaneous Forward Voltage (V)
Peak Forward Surage Current (A)
600
Fig.4 Typical Junction Capacitance
Fig.3 Typical Forward Characteristic
100
Number of Cycles
REV.08
400
200
Instaneous Reverse Voltage (V)
Case Temperature (°C)
2 of 3
100
S2AG THRU S2MG
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
g
e
A
D
The recommended mounting pad size
a
0.3
12
Marking
Type number
2.4
(94)
mm
Unit :
(mil)
REV.08
S2AG
S2A
1.8
(71)
1.8
(71)
1.8
(71)
Marking code
3 of 3
S2BG
S2B
S2DG
S2D
S2GG
S2G
S2JG
S2J
S2KG
S2K
S2MG
S2M
很抱歉,暂时无法提供与“S2AG”相匹配的价格&库存,您可以联系我们找货
