MMBD4148A/CA/CC/SE
SOT-23 Plastic-Encapsulate Diodes
MMBD4148A/CA/CC/SE
SWITCHING DIODE
SOT-23
FEATURES
Fast Switching Speed
For General Purpose Switching Applications
High Conductance
Marking:
MMBD4148A
MMBD4148CC
MMBD4148CA
MARKING:5H
MARKING:D6
5H
D6
MMBD4148SE
MARKING:D5
MARKING:D4
D5
D4
Solid dot = Green molding compound device,
D5
D6
5H
if none, the normal device
D4
Maximum Ratings and Electrical Characteristics, Single Diode @Ta=25℃
Symbo
Parameter
Limit
Unit
Non-Repetitive Peak Reverse Voltage
VRM
Peak Repetitive Peak Reverse Voltage
Working Peak Reverse Voltage
DC Blocking Voltage
VRRM
VRWM
VR
100
V
VR(RMS)
72
V
RMS Reverse Voltage
100
V
Forward Continuous Current
IFM
300
mA
Average Rectified Output Current
IO
200
mA
Non-Repetitive Peak Forward Surge Current @ 8.3ms
IFSM
2.0
A
Power Dissipation
Pd
350
mW
RθJA
357
℃/W
Junction Temperature
Tj
150
Storage Temperature
TSTG
-55~+150
Thermal Resistance Junction to Ambient
ELECTRICAL CHARACTERISTICS (Ta=25℃ unless otherwise specified)
Parameter
Reverse breakdown voltage
Forward voltage
Symbol
Min
Typ
Max
Unit
Conditions
V (BR) 1
100
V
IR=100μA
V (BR) 2
75
V
IR=5μA
VF
1
V
IF=10mA
IR1
5
μA
VR=75V
IR2
25
nA
VR=25V
Capacitance between terminals
CT
4
pF
VR=0V,f=1MHz
Reverse recovery time
trr
4
ns
Reverse current
IF=IR=10mA, VR=6V,
Irr=0.1XIR,RL=100Ω
The above data are for reference only.
https://www.microdiode.com
Rev:2024A1
Page :1
MMBD4148A/CA/CC/SE
Typical Characteristics
Forward
Characteristics
Reverse
1000
300
Characteristics
100
(nA)
(mA)
300
REVERSE CURRENT IR
FORWARD CURRENT
10
T=
a 2
5℃
T=
a 1
00
IF
30
3
1
Ta=100℃
100
30
10
Ta=25℃
3
0.3
0.1
0.0
0.4
0.8
FORWARD VOLTAGE
1.2
VF
1
1.6
40
REVERSE VOLTAGE
Capacitance Characteristics
1.4
(V)
VR
80
(V)
Power Derating Curve
400
Ta=25℃
(mW)
300
PD
1.3
POWER DISSIPATION
CAPACITANCE BETWEEN TERMINALS
CT (pF)
f=1MHz
1.2
1.1
1.0
200
100
10
REVERSE VOLTAGE
15
VR
(V)
50
75
AMBIENT TEMPERATURE
Rev:2024A1
125
100
Ta
150
Page :2
MMBD4148A/CA/CC/SE
Outlitne Drawing
SOT-23 Package Outline Dimensions
θ
A
A1
b
c
D
E
E1
e
L
L1
θ
L
L1
E
E1
Symbol
1
e
Suggested Pad Layout
0.037
0.95
0.037
0.95
Dimensions In Millimeters
Min
Typ
Max
0.90
1.40
0.10
0.00
0.30
0.50
0.20
0.08
2.80
2.90
3.10
1.20
1.60
2.80
2.25
1.80
1.90
2.00
0.10
0.50
0.55
10°
0.4
0°
Note:
1.Controlling dimension:in/millimeters.
2.General tolerance: ±0.05mm.
3.The pad layout is for reference purposes only.
0.079
2.0
0.035
0.9
0.031
0.8
inches
mm
PACKAGE SPECIFICATIONS
Package Reel Size
SOT-23
Reel DIA.
(mm)
Q'TY/Reel
(pcs)
Box Size
(mm)
QTY/Box
(pcs)
Carton Size
(mm)
Q'TY/Carton
(pcs)
330
3000
203×203×195
45000
438×438×220
180000
7'
Rev:2024A1
Page :3
很抱歉,暂时无法提供与“MMBD4148CA”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.12609
- 600+0.09401
- 1200+0.09260
- 3000+0.08441
- 国内价格
- 10+0.11388
- 100+0.09135
- 300+0.07889
- 3000+0.06841
- 6000+0.06192
- 9000+0.05836
- 国内价格
- 10+0.04650
- 100+0.04320
- 300+0.03780
