ES2ABF THRU ES2JBF
Reverse Voltage - 50 to 600 Volts
Forward Current2.0 Ampere
SURFACE MOUNT SUPER FAST RECOVERY RECTIFIER
Features
SMBF
The plastic package carries Underwriters Laboratory
Flammability Classification 94V-0
For surface mounted applications
Low reverse leakage
Built-in strain relief,ideal for automated
placement High forward surge current capability
High temperature soldering guaranteed:
0.146(3.70)
0.138(3.50)
0.086 (2.20)
0.075 (1.90)
0.173(4.40)
0.165(4.20)
250°C/10 seconds at terminals
Glass passivated chip junction
0.051(1.30)
0.043(1.10)
0.010(0.26)
0.007(0.18)
0.048(1.20)
0.031(0.80)
Mechanical Data
0.216(5.50)
0.200(5.10)
Case : JEDEC SMBF Molded plastic body
Terminals : Solder plated, solderable per MIL-STD-750,Method 2026
Polarity : Polarity symbol marking on body
Mounting Position : Any
Weight : 0.002 ounce, 0.055 grams
Dimensions in inches and (millimeters)
Maximum Ratings And Electrical Characteristics
Ratings at 25 C ambient temperature unless otherwise specified.
Single phase half-wave 60Hz,resistive or inductive load,for capacitive load current derate by 20%.
Parameter
SYMBOLS
Marking Code
Maximum repetitive peak reverse voltage
Maximum RMS voltage
Maximum DC blocking voltage
Maximum average forward rectified current
at TL=55℃
Peak forward surge current
8.3ms single half sine-wave
superimposed onrated load (JEDEC Method)
Maximum instantaneous forward voltage at 3.0A
Maximum DC reverse current
at rated DCblocking voltage
Maximum reverse recovery time
TA=25℃
TA=125℃
(NOTE 1)
VRRM
VRMS
VDC
I(AV)
ES2ABF ES2BBF ES2CBF ES2DBF ES2EBF ES2GBF ES2JBF
MDD
E2AB
50
35
50
MDD
E2BB
MDD
E2CB
MDD
E2DB
MDD
E2EB
MDD
E2GB
100
70
100
150
105
150
200
140
200
300
210
300
400
280
400
IFSM
VF
IR
MDD
E2JB
600
420
600
UNITS
V
V
V
2.0
A
50
A
1
1.25
1.70
V
5.0
100.0
μA
trr
35
ns
CJ
45.0
pF
Typical thermal resistance (NOTE 3)
RJA
65.0
℃/W
Operating junction and storage temperature range
TJ,TSTG
-55 to +150
Typical junction capacitance (NOTE 2)
Note:1.Reverse recovery condition IF=0.5A,IR=1.0A,Irr=0.25A
2.Measured at 1MHz and applied reverse voltage of 4.0V D.C.
3.P.C.B. mounted with 0.5x0.5”(12.7x12.7mm) copper pad areas
http://www.microdiode.com
Rev:2024A2
Page :1
ES2ABF THRU ES2JBF
Forward Current - 2.0 Ampere
Ratings And Characteristic Curves
50 ohm
Noninductive
10 ohm
Noninductive
t rr
+0.5
D.U.T
PULSE
GENERATOR
Note 2
25Vdc
approx
1 ohm
OSCILLOSCOPE
Note 1
NonInductive
-1.0
Note:1. Rise Time = 7ns, max.
Input Impedance = 1megohm,22pF.
2. Ries Time =10ns, max.
Source Impedance = 50 ohms.
10ns/div
Set time Base for 10ns/div
Fig.3 Typical Reverse Characteristics
2.4
300
2.0
100
I R- Reverse Current ( μ A)
Average Forward Current (A)
Fig.2 Maximum Average Forward Current Rating
1.6
1.2
0.8
Single phase half wave resistive
or inductive P.C.B mounted on
0.5×0.5"(12.7×12.7mm ) pad areas.
0.4
T J =125°C
10
T J =75°C
1.0
T J =25°C
0.1
0.0
25
50
75
100
125
150
175
Lead Temperature (°C)
80
60
100
% of PIV.VOLTS
Fig.4 Typical Forward Characteristics
Fig.5 Typical Junction Capacitance
70
10
T J =25°C
Junction Capacitance ( pF)
Instaneous Forward Current (A)
40
ES2ABF~ES2DBF
ES2EBF/ ES2GBF
0.1
ES2JBF
0.01
0.001
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
60
50
40
30
T J =25°C
f = 1.0MHz
V sig = 50mV p-p
0.1
1
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.6 Maximum Non-Repetitive Peak
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
10
00
1
10
100
Number of Cycles
The curve above is for reference only.
Rev:2024A2
Page :2
ES2ABF THRU ES2JBF
Packing information
P0
unit:mm
P1
d
E
F
B
A
W
P
D2
T
D1
C
W1
D
Item
Symbol
Tolerance
SMBF
Carrier width
Carrier length
Carrier depth
Sprocket hole
13" Reel outside diameter
13" Reel inner diameter
Feed hole diameter
Sprocket hole position
Punch hole position
Punch hole pitch
Sprocket hole pitch
Embossment center
Overall tape thickness
Tape width
A
B
C
d
D
D1
D2
E
F
P
P0
P1
T
W
Reel width
W1
0.1
0.1
0.1
0.05
2.0
min
0.5
0.1
0.1
0.1
0.1
0.1
0.1
0.3
1.0
3.81
5.61
1.60
1 50
330.00
50.00
13.00
1.75
5.50
4.00
4.00
2.00
0.30
12.00
12.30
Note:Devices are packed in accor dance with EIA standar RS-481-A and specifications listed above.
Reel packing
PACKAGE
REEL SIZE
REEL
(pcs)
COMPONENT
SPACING
(mm)
BOX
(pcs)
INNER
BOX
(mm)
REEL
DIA,
(mm)
SMBF
13"
5,000
4.0
10,000
190*190*41
330
CARTON
SIZE
(mm)
365*365*360
CARTON
(pcs)
80,000
APPROX.
GROSS WEIGHT
(kg)
14.0
Suggested Pad Layout
Symbol
Unit (mm)
A
2.54
0.100
B
1.8
0.071
C
4.8
0.189
D
3.0
0.118
E
6.6
0.260
Unit (inch)
Rev:2024A2
Page :3
很抱歉,暂时无法提供与“ES2JBF”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.13274
- 10+0.11459
- 30+0.10466
- 100+0.09861
- 500+0.09342
- 1000+0.09062
- 国内价格
- 20+0.15649
- 100+0.14209
- 500+0.13249
- 1000+0.12289
- 5000+0.11137
- 10000+0.10657
