BK12022502-H
BK12022502-H
    BRIGHTKING(君耀)
    插件
    玻璃放电管(SPG)
BK12022502-H 数据手册
BK1-H SERIES Spark Gap (SPG) Data Sheet Features ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Approximately zero leaking current before clamping voltage Less decay at on/off state. High capability to withstand repeated lightning strikes. Low electrode capacitance(≤1.0pF) and high isolation(≥100MΩ). RoHS compliant. Bilateral symmetrical. Temperature, humidity and lightness insensitive. No dark effect. Operating temperature: -40℃ ~ +85℃ Storage temperature: -40℃ ~ +125℃ Meets MSL level 1, per J-STD-020 Safety certification: UL: E472693 Applications ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Power Supplies Motor sparks eliminating Relay switching spark absorbing Data line pulse guarding Electronic devices requiring UL497A and UL497B compliant Telephone/Fax/Modem High frequency signal transmitters/receivers Satellite antenna Radio amplifiers Alarm systems Cathode ray tubes in Monitors/TVs Dimensions Color code 1 Color code 2 Color code 3 L1 D L Revision:SPG-BK1-H SERIES-001(A2) d Symbol Dimension (mm) L 9.0±1.5 L1 28.0±3.0 D Φ4.1±0.5 d Φ0.5±0.05 L1 1/5 http://brightking.pulseelectronics.com BK1-H SERIES Electrical Characteristics Part Number Type ① ② DC Spark-over Voltage Minimum Insulation Resistance Maximum Capacitance (1KHz-6VMAX) Vs(V) Test Voltage(V) IROHM (MΩ) C(pf) Surge Current Capacity (8/20μs) AC Withstanding Voltage BK1XX05002 H 1000 500 100 1.0 3000A - BK1XX07502 H 1500 500 100 1.0 3000A - BK1XX09002 H 1800 500 100 1.0 3000A - BK1XX10002 H 2000 500 100 1.0 3000A - BK1XX12002 H 2400 500 100 1.0 3000A AC1200V, 3sec. BK1XX13502 H 2700 500 100 1.0 3000A AC1200V, 3sec. BK1XX15002 H 3000 500 100 1.0 3000A AC1500V, 3min. BK1XX18002 H 3600 500 100 1.0 3000A AC1800V, 3sec. BK1XX20002 H 4000 500 100 1.0 3000A AC1800V, 3sec. BK1XX22502 H 4500 500 100 1.0 3000A AC2000V, 1min. BK1XX25002 H 5000 500 100 1.0 3000A AC2000V, 1min. Note:① Vs±XX% ② Specific code by request. Color Code Part Number Type Color Code 1 Color Code 2 Color Code 3 BK1XX05002 H Brown Black Red BK1XX07502 H Brown Green Red BK1XX09002 H Brown Gray Red BK1XX10002 H Red Black Red BK1XX12002 H Red Yellow Red BK1XX13502 H Red Purple Red BK1XX15002 H Orange Black Red BK1XX18002 H Orange Blue Red BK1XX20002 H Yellow Black Red BK1XX22502 H Yellow Green Red BK1XX25002 H Green Black Red Revision:SPG-BK1-H SERIES-001(A2) 2/5 http://brightking.pulseelectronics.com BK1-H SERIES Test Methods and Results Items Test Method DC Spark-over Voltage Measure starting discharge voltage (Vs) by gradually increasing applied DC voltage. Test current is 0.5mA max. And the DC voltage ascends up within 500V/second. Insulation Resistance Measure the insulation resistance across the terminal at regular voltage. But the test voltage doesn’t over the DC spark-over voltage. Capacitance Measure the electrostatic capacitance by applying a voltage of less than 6V (at 1KHz) between terminals. Surge Current Capacity Charge a 1.2/50μs & 8/20μs, 2000A, and apply it to the sample. Do this 10 time. Or 3000A, 1 time. Standard Meet specified value. No crack and no failures Surge Life Apply a standard impulse current (8/20μs of 100A) for 300 times at 60 seconds intervals. Cold Resistance Measurement after -40℃/1000 HRS & normal temperature/2 HRS. Heat Resistance Measurement after 125℃/1000 HRS & normal temperature/2 HRS. Humidity Resistance Measurement after humidity 90~95℃(45℃) /1000 HRS & normal temperature/2 HRS. Temperature Cycle 10 times repetition of cycle -40℃/30min →normal, temp/2 min →125℃/30min, measurement after normal temp/2 HRS. Solder Ability Apply flux and immerse in molten solder 230±5℃ for 3sec up to the point of 1.5mm from body. Check for solder adhesion. Lead wire is evenly covered by solder. Solder Heat Measurement after lead wire is dipped up to the point of 1.5mm from body into 260±5℃ solder for 10sec. Conformed to rated spec. Pull Strength Apply 0.5kg load for 10sec. Flexural Strength Bend lead wire at the point of 2mm from body under 0.25 load and back to its original point. Repeat 1 time. Revision:SPG-BK1-H SERIES-001(A2) 3/5 Features are conformed to rated spec. Lead shall not pull out to snap. http://brightking.pulseelectronics.com BK1-H SERIES Recommended Soldering Conditions Flow Soldering Conditions Air Priheat Soldering Reflow Soldering Conditions Air Priheat Cooling Soldering Cooling 260℃ 260℃ 250 250 △T Temperature (℃) Temperature (℃) △T 200 150 150~180℃ 200 150 150~180℃ 100 100 50 50 0 0 60~120 sec 60~120 sec 3~4 sec 10 sec. or less 60 sec. or less 1) Time shown in the above figures is measured from the point when chip surface reaches temperature. 2) Temperature difference in high temperature part should be within 110℃. 3) After soldering, do not force cool, allow the parts to cool gradually. Hand Soldering Solder iron temperature: 350±5℃ Heating time: 3 seconds max. General attention to soldering ● High soldering temperatures and long soldering times can cause leaching of the termination, decrease in adherence strength, and the change of characteristic may occur. ● For soldering, please refer to the soldering curves above. However, please keep exposures to temperatures exceeding 200℃ to fewer than 50 seconds. ● Please use a mild flux (containing less than 0.2wt% CI). Also, if the flux is water soluble, be sure to wash thoroughly to remove any residue from the underside of components that could affect resistance. Cleaning When using ultrasonic cleaning, the board may resonate if the output power is too high. Since this vibration can cause cracking or a decrease in the adherence of the termination, we recommend that you use the conditions below. Frequency: 40kHz max. Output power: 20W/liter Cleaning time: 5 minutes max. Revision:SPG-BK1-H SERIES-001(A2) 4/5 http://brightking.pulseelectronics.com BK1-H SERIES Packaging Tape L D1 R D P Z t L1 S L2 T T S Symbol Dimension (mm) W 52.0±1.5 P 10.0±0.5 L1-L2 1.0max. T 6.0±1.0 Z 1.2max. R Terminals must not project from tape. t 3.2max. S 0.8max. D Φ4.6max. D1 Φ0.5±0.05 L 10.5max. A 75.0±5.0 B 114.0±5.0 C 250.0±5.0 W Inner Box B C A Revision:SPG-BK1-H SERIES-001(A2) Quantity: 1000PCS 5/5 http://brightking.pulseelectronics.com
BK12022502-H 价格&库存
很抱歉,暂时无法提供与“BK12022502-H”相匹配的价格&库存,您可以联系我们找货
BK12022502-H
  • 10+3.22910
  • 100+1.92620
  • 500+1.34840
  • 1000+0.96310
  • 2000+0.91490
  • 10000+0.84750
库存:1969
BK12022502-H
    • 5+1.58602
    • 50+1.25372
    • 150+1.11131
    库存:304
    BK12022502-H
    • 5+1.80371
    • 50+1.42593
    • 150+1.26404
    库存:962
