DATA SHEET
WIRELESS COMPONENTS
Diplexer
DPX1608LL85R2455A
2.4 AND 5 GHZ
Product Specification – May 11, 2018 V.3
1608 Series
Product specification
WIRELESS COMPONENTS
2
5
Diplexer
FEATURES
Compact size design
RoHS compliant
ORDERING INFORMATION
APPLICATIONS
WLAN, 802.11a/b/g/n
ISM Band
PART NUMBER
All part numbers are identified by the series, packing type, material, size,
antenna type, working frequency and packing quantity.
DPX 1608 LL 85 R 2455A
(1)
(2)
(3) (4)
(5)
(6)
(1) PRODUCT
DPX = Diplexer
(2) SIZE
1608 = 1.6 × 0.8 mm
(3) MATERIALS
Material Code LL
(4) TYPE
85 = Type 85
(5) PACKING STYLE
R = Tape and Reel
(6) WORKING FREQUENCY
2455 = 2.4/5GHz
PHYCOMP CTC
CFL4111715852524K
12NC
411171585252
www.yageo.com
May. 11, 2018 V.3
WIRELESS COMPONENTS
3
5
Diplexer
SPECIFICATION
Table 1
VALUE
DESCRIPTION
Low Band
Pass Band
High Band
2400~2500MHz
4900~6000MHz
Insertion loss
0.7dB (Max) at 25°C
0.8dB (Max) at 25°C
Return-Loss
10.0dB(Min)
12.0dB(Min)
28dB(Min).@860~960MHz
23dB(Min).@1545~1605MHz
23dB(Min).@1710~1990GHz
20dB(Min).@4.8~5GHz
20dB(Min).@7.2~7.5GHz
Attenuation
28dB(Min).@2.17GHz
8dB(Min).@8.1GHz
15dB(Min).@8.82~9.8GHz
27dB(Min).@9.8~11.8GHz
Isolation
Middle Band to High Band: 20dB (Min). @4.9~5.95GHz
Operating Temperature
-40 ~ 85℃
Dimension
1.6 x 0.8 x0.6mm
DIMENSIONS
Table 2 Machinical Dimension
OUTLINES
DIMENSION
L (mm)
1.60±0.15
W (mm)
0.80±0.15
T (mm)
0.60±0.15
P1 (mm)
0.20±0.15
P2 (mm)
0.20±0.15
P3 (mm)
0.20±0.15
P4 (mm)
0.20±0.15
P5 (mm)
0.20±0.15
P6 (mm)
0.20±0.15
D1 (mm)
0.20±0.15
D2 (mm)
0.30±0.10
D3 (mm)
0.15±0.10
Fig. 1 Filter outlines
Table 3 Termination configuration
TERMINAL NAME
FUNCTION
P1
High band port
P2
Ground
P3
Low band port
P4
Ground
P5
Common port
P6
Ground
www.yageo.com
May. 11, 2018 V.3
WIRELESS COMPONENTS
4
5
Diplexer
Fig. 2 Reference design of evaluation board
ELECTRICAL PERFORMANCES
Measured on Agilent E5071C
Network Analyzer
Common port: Port 2 (Return
loss S22)
Low band port: Port 3 (Low band
insertion loss S32, and
attenuation at high band)
High band port: Port 1 (High
band insertion loss S12, and
attenuation at low band)
Fig. 3 Frequency Characteristics
www.yageo.com
May. 11, 2018 V.3
WIRELESS COMPONENTS
Diplexer
5
5
REVISION HISTORY
REVISION DATE
CHANGE NOTIFICATION
Version 3
May 11, 2018
Version 2
Aug. 18, 2014
Version 1
Aug. 05, 2014
DESCRIPTION
- Update termination function
- Update specification
- Update Attenuation
www.yageo.com
May. 11, 2018 V.3
很抱歉,暂时无法提供与“DPX1608LL80R2455A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 4000+0.721314000+0.09379
- 8000+0.686558000+0.08927
- 12000+0.6778612000+0.08814
- 20000+0.6517920000+0.08475
- 国内价格
- 10+0.35187
- 100+0.27411
- 300+0.23523
- 1000+0.20607
- 4000+0.18274
- 8000+0.17108
