山东晶导微电子股份有限公司
RS2A THRU RS2M
Jingdao Microelectronics co.LTD
Surface Mount Fast Recovery Rectifiers
Reverse Voltage - 50 to 1000 V
PINNING
Forward Current - 2 A
PIN
FEATURES
• For surface mounted applications
• Low profile package
• Glass Passivated Chip Junction
• Easy to pick and place
• Fast reverse recovery time
• Lead free in comply with EU RoHS 2011/65/EU directives
DESCRIPTION
1
Cathode
2
Anode
1
2
Top View
Marking Code: RS2A-RS2M
MECHANICAL DATA
• Case: SMA
• Terminals: Solderable per MIL-STD-750, Method 2026
• A pprox. Weight: 0.055g / 0.002oz
Simplified outline SMA and symbol
Absolute Maximum Ratings and Characteristics
Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load.
For capacitive load, derate current by 20%.
Symbols
RS2A
RS2B
RS2D
RS2G
RS2J
RS2K
RS2M
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
50
100
200
400
600
800
1000
V
Maximum RMS voltage
V RMS
35
70
140
280
420
560
700
V
Maximum DC Blocking Voltage
V DC
50
100
200
400
600
800
1000
V
Maximum Average Forward Rectified Current
at T c = 125 °C
I F(AV)
2
A
Peak Forward Surge Current 8.3 ms Single Half
Sine Wave Superimposed on Rated Load
I FSM
50
A
Maximum Forward Voltage at 2 A
VF
1.3
V
IR
5
100
μA
Cj
22
pF
Parameter
Maximum DC Reverse Current
T a = 25 °C
at Rated DC Blocking Voltage
T a =125 °C
Typical Junction Capacitance
at V R =4V, f=1MHz
Maximum Reverse Recovery Time
(1)
Typical Thermal Resistance (2)
Operating and Storage Temperature Range
t rr
150
250
500
ns
RθJA
RθJC
65
°C/W
T j , T stg
-55 ~ +150
°C
(1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A .
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
2016.11
SMA-F-RS2A~RS2M-2A1KV
Page 1 of 3
山东晶导微电子股份有限公司
RS2A THRU RS2M
Fig.2 Typical Reverse Characteristics
3.0
2.5
2.0
1.5
1.0
0.5
Single phase half-wave 60 Hz
0.0
25
50
75
100
125
150
175
Instaneous Reverse Current(μ A)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
100
T J =125°C
10
1.0
T J =25°C
0.1
00
T J =25°C
1.0
0.1
pulse with 300μs
1% duty cycle
0.01
0.0
40
60
80
100
120
140
Fig.4 Typical Junction Capacitance
Junction Capacitance ( pF)
Instaneous Forward Current (A)
Fig.3 Typical Instaneous Forward
Characteristics
10
percent of Rated Peak Reverse Voltage (%)
Case Temperature (°C)
T J =25°C
100
10
T J=25°C
f = 1.0MHz
V sig = 50mV p-p
1
0.5
1.0
1.5
2.0
2.5
Instaneous Forward Voltage (V)
0.1
1.0
10
100
Reverse Voltage (V)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
60
50
40
30
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles
2016.11
www.sdjingdao.com
Page 2 of 3
山东晶导微电子股份有限公司
RS2A THRU RS2M
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
A
A
SMA
c
a
VM
e
A
HE
g
e
E
A
D
E
HE
c
e
g
max
2.2
4.5
2.7
5.2
0.31
1.6
1.5
min
1.9
4.0
2.3
4.7
0.15
1.3
0.9
max
87
181
106
205
12
63
59
min
75
157
91
185
6
51
35
UNIT
mm
mil
The recommended mounting pad size
2.4
(94)
mm
Unit :
(mil)
2016.11
a
0.3
12
Marking
Type number
Marking code
RS2A
RS2A
RS2B
RS2B
RS2D
RS2D
RS2G
RS2G
RS2J
RS2J
RS2K
RS2K
RS2M
RS2M
1.8
(71)
1.8
(71)
1.8
(71)
g
e
A
D
JD611296B0
Page 3 of 3
很抱歉,暂时无法提供与“RS2J”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.20650
- 100+0.12800
- 500+0.08450
- 5000+0.06040
- 10000+0.05740
- 50000+0.05310
- 国内价格
- 50+0.07344
- 500+0.05703
- 1500+0.04785
- 5000+0.03921
- 25000+0.03446
- 50000+0.03197
- 100000+0.03154
- 200000+0.03122
- 国内价格
- 50+0.07649
- 500+0.07200
- 2000+0.06300
- 5000+0.05850
- 15000+0.05400
- 30000+0.05175
