12077411
12077411
    APTIV(安波福)
    Contacts
    端子 17~20AWG
12077411 数据手册
16 15 14 13 12 11 10 9 8 7 6 5 4 SYMBOL DEFINITION A DIMENSION WITHOUT AN INSPECTION REPORT SYMBOL DOES NOT REQUIRE INSPECTION. IT MAY BE CONTROLLED ON THE INDIVIDUAL COMPONENT DRAWING. M MISSING SYMBOLS TOTAL NO OF INSPECTIONS REQUIRED LAST NO. USED 4 6 9 2 DWG STATUS DATE STG REV N/P CHG ZONE 1 REVISION HISTORY DR APVD APVD 1 2 AUTH 14JA00 R 001 - - CLEARED REV COLUMN; ALL ACTIVE PARTSUPDATED PDM ATTRIBUTES 196648 CRW GGI LLD 17JL00 R 002 - REINSTATE 12077412 000010 JIB JIB JA 10 M 15OC04 R 03 - - ALL ACTIVE PARTS - ADDED TERMINAL ID NOTE 260003 RTV JVM MKM 24FE05 R 04 - - ALL ACTIVE PARTS - REVISED MAT'L SPEC & DRAWING NAME 265136 JS JS TM 18MY05 R 05 - - 12176389 - UPDATED PDM ATTRIBUTES 268280 JBD FKV WTM 30SE05 R 06 - - 12077411, 12077413, 12084201, 12129493 & 12176389 - UPDATED PDM ATTRIBUTES; 12077411 - ADDED 1.0 MM2 CABLE; ALL ACTIVE PARTS - ADDED NOTE# 6 272905 JTV AUG WTM 11JA08 R 07 - - ALL PARTS - 2X 5 +-0.15 TYP WAS 2X 5 +-0.01 TYP 403419 WHC WHC WTM L 18FE15 R 08 - - 33231919 - RELEASED AND 12176387-90 ADDED TARNISH NOTE 428904 NRM JVM DS 18SE15 R 09 - - 33231919 - DIM 19.95 0.4 WAS 19.95 +0.15 / -0.4 AND UPDATED PART AVAILABILITY 430685 LES LES MJD 22MY19 R 10 - - 12176387 - 3 WAS 5 ON SIZE (MM2) COLUMN 443374 LVD JIE JIE 10 L K 3 K 103 102 TYPE SAME AS TYPE 101 EXCEPT AS SHOWN TYPE SAME AS TYPE 101 EXCEPT AS SHOWN J J 2X 5 H H 2X U X 10 1 3.725 E 0.175 G 2 X 7 3.95 CABLE "ID" "PED" OPTIONAL FOR EXISTING TOOLS 2X 3 G SEE CHART 2X 4.58 F VIEW TO STAMP DIE ID "PXX" IN THIS AREA (0.6) CHARACTERS XX DESIGNATES DIE NUMBER LOCATION IS APPROXIMATE X-X VIEW TO F X-X INSULATION WINGS FOR (SEE CHART) MAX INSULATION DIA E E CORE WINGS FOR (SEE CHART) MM2 CABLE NOTES 2X 8 2X 5 1. UNLESS OTHERWISE SPECIFIED AND/OR INDICATED: 0.15 TYP DIMENSIONS ARE TO FACE OF VIEW SHOWN AND AUTOMATICALLY ROUNDED BY COMPUTER FOR INSPECTION (SEE MATH MODEL FOR PRECISE DIMENSIONS). FOR ALL OTHER DIMENSIONS NOT SHOWN BUT REQUIRED FOR TOOL BUILD, SEE MATH MODEL FOR PRECISE TOOL PATH DATA. D D 2. R 0.4 PERMISSIBLE ON ALL "SHARP" CORNERS. TYPE 101 3. RECOMMENDED MATING BLADE 2.8 X 0.81. 4. TERMINALS TO CRIMP AROUND AND RETAIN CAVITY SEAL 12015323 OR EQUIVALENT. 5. "PXX" INDICATES "P" PLUS LAST TWO DIGITS OF MAKE SERIES NUMBER P01, P02, P03, ETC. . C 6. DO NOT PROBE, TEST OR OTHERWISE CONTACT THE INTERIOR REGION (THE SPRING OR ANY MOVING PART) OF THIS TERMINAL. SEVERE DAMAGE CAN OCCUR, COMPROMISING THE PERFORMANCE OF THE ELECTRICAL INTERFACE. A LINE DRAWN THROUGH A PART NUMBER INDICATES THAT PHYSICAL PARTS ARE NOT AVAILABLE FOR ORDERING. CONNECTION SYSTEMS PART NUMBERS THAT DO NOT HAVE A LINE PRESENT INDICATE THAT PHYSICAL PARTS ARE AVAILABLE FOR ORDERING. CONTACT APTIV SALES TO ASSURE AVAILABILITY OF PARTS. DWG TYPE PART DRAWING WARREN, OH COPYRIGHT 1998 APTIV. ALL RIGHTS RESERVED. THIS DRAWING IS THE PROPERTY OF APTIV AND CONTAINS APTIV CONFIDENTIAL INFORMATION. THE REPRODUCTION, DISTRIBUTION AND UTILIZATION OF THIS DOCUMENT OR ITS RELATED CAD MATH DATA, AS WELL AS COMMUNICATION OF ANY CONTENT TO OTHERS, WITHOUT EXPRESS AUTHORIZATION, IS PROHIBITED. STYLE DATE DR DISTR CODE VOLUME (CM3) B PART NO A 16 15 14 REV 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 30.56 0.406 X 32.54 0.406 X 32.54 0.406 X 32.54 MAT'L SIZE UNPLATED SPEC 13 12176390 12176389 33231919 12176388 12176387 12129493 12084201 12077413 12077412 12077411 12045639 12034454 12020648 PART NO 12 A8 A9 01 AA A8 A9 C8 E11 E11 E9 E11 D8 F8 H8 REV N/P AG PLATED COPPER ALLOY AG PLATED COPPER ALLOY AG PLATED COPPER ALLOY AG PLATED COPPER ALLOY AG PLATED COPPER ALLOY TIN PLATED COPPER ALLOY TIN PLATED COPPER ALLOY TIN PLATED COPPER ALLOY TIN PLATED COPPER ALLOY TIN PLATED COPPER ALLOY P1519027 425 TIN BRS EX HD SN PLTD P1519027 425 TIN BRS EX HD SN PLTD P1519027 425 TIN BRS EX HD SN PLTD MAT'L SPEC PLATED 11 10 0.35-0.5 0.8-1 1-2 2-3 3 2-3 0.35-0.5 3 1-2 0.5-0.8-1.0 3 1-2 0.5-0.8 SIZE (MM2) 0.35-0.5 2.03-3.12 2.48-3.05 2.45-3.80 3.49-3.65 2.45-3.80 1.84-2.51 3.49-3.65 2.48-3.05 2.03-3.12 3.49-3.65 2.48-3.05 2.03-3.12 DIA 21 19 15 13 12 13 21 12 15 19 12 15 19 ID 103 101 103 103 103 103 101 103 103 101 102 102 101 TYPE 2.4 0.2 3.2 0.4 3.7 0.4 4 0.4 4.6 0.4 4 0.4 2.4 0.2 4.6 0.4 3.7 0.4 3.2 0.4 4.6 0.4 3.7 0.4 3.2 0.4 E 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 19.95 +0.15-0.4 U UNLESS OTHERWISE SPECIFIED THIS DOCUMENT IS IN ACCORDANCE WITH ASME Y14.5M-1994 AS AMENDED BY THE GM GLOBAL DIMENSIONING AND TOLERANCING ADDENDUM-2001. SEPARATE PATTERNS OF FEATURES MAY BE GAGED SEPARATELY REGARDLESS OF DATUM REFERENCES. 8 7 APVD2 APVD3 B 29MY98 02JN98 16JL98 APVD4 APVD5 SUBSTANCES OF CONCERN AND RECYCLED CONTENT PER APTIV 10949001 MATERIAL SEE CHART ALL DIMENSIONS ARE IN MILLIMETERS 1 PROCESS SENSITIVE DIMENSION DRAWING NAME REFERENCE TAXI TERM F M/P 280 SEALED DIMENSIONS ENCLOSED IN INDICATE REFERENCE DIMENSIONS AND NO TOLERANCE LIMITS ARE ESTABLISHED CABLE 9 D JORGE IBARRA OSCAR OCHOA O. GALLEGOS APVD1 6 5 DIMENSIONAL RANGE (MM) CHART D 0 FROM 12 TO 12 TOLERANCE UNLESS OTHERWISE SPECIFIED 0.1 0.2 ANGULAR TOLERANCE 2 4 A DRAWING NUMBER THIRD ANGLE PROJECTION 12089195 DO NOT SCALE USE MATH DATA 3 SIZE SCALE FRAME NO SHEET NO STG A0 10:1 1 OF 1 1 OF 1 R 2 1 REV N/P 10 - Time: 10:53:52 7. FOR TERMINALS PACKAGED & STORED IN THE APPROVED MANNER, TARNISH ON SILVER PLATED SURFACES WILL NOT AFFECT THE PERFORMANCE OF THE PART. User: zj8qmm Part: 12089195-CUS01-S01/10 Date: 24-May-19 zj8qmm,05242019,10:53,672pass,nor C
12077411 价格&库存
很抱歉,暂时无法提供与“12077411”相匹配的价格&库存,您可以联系我们找货
    • 9200+0.515099200+0.06667
    库存:16000
    12077411
      • 1000+0.28896
      库存:1960
      12077411
        • 5+0.79458
        • 50+0.63896
        • 150+0.56115
        库存:254
        12077411
          • 1+0.67100
          • 1000+0.50380
          • 2300+0.35530
          库存:135162
