1mm Contact Pitch, Board-to-Cable, Board-to-FPC,
Board-to-Micro-coaxial Cable Connectors
DF19 Series
Small configuration and board space
8.2
7.2
Cable
1.5
1.65
DF19G-*P-1H(54)
Plug
DF19A-2830 / 3032 / 36SCFA
1.65
(1.7)
8.2
7.2
DF19G-*P-1H(54)
DF19G-*S-1F(05)
DF19G-*S-1F-GND(05)
PCB
Horizontal mounting
(1.7)
1.5±0.1
Discrete wire
FPC
DF19G-*S-1C(05)
(7.7)
Industry and market accepted as “De facto” standard for LCD panel
connections (panels under 12 inches).
High-performance connectors for LVDS high-speed differential
signals.
Plug
(7.7)
■Overview
DF19-*P-1V(56)
Receptacle
(0.78)
■Features
Micro-coaxial cable
1. Small configuration and board space
Thin design accepts discrete wire, thin micro-coaxial cable
(Ø1.5mm, Ø1.6mm max.) and FPC 1.7mm maximum thick.
2. Common use of receptacle
1.3±0.2
DF19G-*S-1SD(05)
+DF19G-*S-1SD-GND
(7.7)
Apr.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
FPC
PCB
DF19-*P-1V(56)
The same receptacle will accept plugs terminated with discrete wire,
FPC or micro-coaxial cable.
Vertical mounting
3. Uniform external dimensions
The plug assembly external dimensions remain the same when is
terminated with discrete wire, FPC or micro-coaxial cable.
Top-board mounting
Discrete wire
4. Variety of mounting styles
Device design engineers have a choice of mounting styles : topboard, offset, reverse mount offset and vertical.
5. Ground connection
Offset mounting
Metal grounding plates connect with the common ground line.
FPC
6. Glow wire compliance (Compliant with IEC60695-2-11)
■Applications
LCD connections in small consumer devices : digital cameras,
notebook computers, PDA’s. Any device requiring high-density
interconnection for consistent high speed transmission data rates.
DF19
Reverse, offset mounting
Micro-coaxial cable
Micro-coaxial cable
FPC
Vertical mounting
Twisted
pair cable
Notebook PC
DF19
DF19
DF19
B253
DF19 Series●1mm Contact Pitch, Board-to-Cable, Board-to-FPC, Board-to-Micro-coaxial Cable Connectors
■Product Specifications
Current rating 28 AWG : 1A
30 AWG : 0.9A
Operating temperature range -35ç to 85ç Note 1 Storage temperature range -10ç to 60ç Note 2
32 AWG : 0.8A
-35ç to 85ç Note 2
36 AWG : 0.5A
Rating
FPC
Operating humidity range
: 0.5A
Storage humidity range
-20% to 80%
-40% to 70%
Micro-coaxial cable 40 AWG : 0.3A
Voltage rating 100V AC
Item
Specification
1.Insulation resistance
500Mø min.
100 V DC
2.Withstanding voltage
No flashover or insulation breakdown.
300 V AC / one minute
3.Contact resistance
30mø max. (50mø max. for FPC)
100 mA
4.Insertion-Extraction force
(per contact)
Min. 0.2N, Max. 3N
Measured with a steel pin Ø0.2±0.005
5.Vibration
No electrical discontinuity of 1μs or more.
Frequency : 10 to 55 Hz, single amplitude of 0.75mm,
2 hours in each of the 3 directions.
6.Humidity
(Steady state)
Contact resistance : 30mø max. (50mø max. for FPC)
Insulation resistance : 500Mø min.
96 hours at temperature of 40±2ç and
humidity of 90% to 95%
7.Temperature cycle
Temperature : –55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç
Time (Minutes) : –30 ➝ +10
➝ +30 ➝ +10 5 cycles
8.Durability
(insertion/ withdrawal) Contact resistance : 30mø max. (50mø max. for FPC)
30 cycles
9.Resistance to
soldering heat
Re-flow soldering : At the recommended temperature profile
Manual soldering : Soldering iron temperature 300ç, 3 seconds
No deformation of the insulator parts affecting performance.
Note1 : Includes temperature rise caused by current flow.
Note2 : The term “storage” refers to connectors stored for long period of time prior to mounting and use. Operating Temperature
Range and Humidity range covers non-conducting condition of installed connectors in storage, shipment or during
transportation.
■Materials / Finish
Product
Receptacle
Plug
Crimp contact
Plug for PPC
Grounding plate for PPC
Plug for micro-coaxial cable
Grounding plate for micro-coaxial cable
B254
Conditions
Component
Material
Finish/Color
Remarks
Insulator
Polyamide
Black or Beige
UL94V-0
Contacts
Phosphor bronze
Gold plated
Grounding plate
Phosphor bronze
Tin plated or Tin-copper plated
Insulator
Polyamide
Beige
Tin-lead plated
Stainless steel
Tin-copper plated
Contact
Phosphor bronze
Gold Plated
Insulator
Polyamide
Beige
UL94V-0
Contact
Phosphor bronze
Gold plated
Grounding plate
Stainless steel
Tin-copper plated
Insulator
LCP
Beige
UL94V-0
Contact
Phosphor bronze
Gold plated
Grounding plate
Phosphor bronze
Tin plated
Grounding plate
Phosphor bronze
Tin plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
● Connector
DF19 # - * P - 1 H
1
2
3
4
5
6
DF19 # - * S - 1 F - GND
1
2
3
4
: DF19
1 Series Name
2 Configuration
■Receptacle
G : Top-board mounting (1.65mm high)
K : Offset mounting (1.0mm high)
L : Offset mounting (1.1mm high)
KR : Reverse offset mounting version of
DF19K (1.0mm high)
6
7
3 Number of contacts : 8,14,20,30 (Note 1)
4 Connector type
S : Plug
P : Receptacle
5 Contact pitch : 1mm
6 Mounting type/Termination type
H
: Horizontal SMT
V
: Vertical SMT
C
: Plug – discrete wire (crimp contact)
F
: Plug – FPC
SD : Plug – micro-coaxial cable
7 Additional separate component
GND : Ground plate (Note 2)
■Plug for discrete wire
Blank : No grounding plate
G
: With grounding plate
■Plug for FPC
G
5
■Grounding plate for FPC
G
■Plug for micro-coaxial cable
G
■Grounding plate for micro-coaxial cable
G
Note 1 : Number of contacts will differ depending on the connector style.
Note 2 : Grounding plates are required when terminating with the FPC and micro-coaxial cable.
●Contact
DF19A - 2830 SCF A (* *)
1
1 Conductor size
2830 : 28 to 30 AWG
3032 : 30 to 32 AWG
0036 : 36 AWG
2 Contact type
SCF : Plug contact, tape and reel
packaging
2
3
4
3 Plating
A : Gold
4 Packaging
Blank : 10,000 pcs/reel
(41) : 20,000 pcs/reel
B255
■Right angle receptacle, top-board mounting
A
B
2.375
2.175
0.25
5.7
1.65
1.65
Contact No. 1 indicator
C
BPCB mounting pattern
B±0.05
1.85±0.1
0.55±0.05
10
+0.1
P=1±0.05
1.65±0.1
2.5 +0.1
2.5±0.05
2
4.7
2.45
P= 1
1.1 +0.1
Outline of the receptacle
No conductive traces
Specification
(54) : Tape & reel packaging
(1,000 pcs/reel)
Unit : mm
Part No.
HRS No.
No. of contacts
A
DF19G-18P-1H (54)
DF19G-14P-1H (54)
685-0021-0 54
8
685-0004-0 54
14
DF19G-20P-1H (54)
685-0006-6 54
DF19G-30P-1H (54)
685-0015-7 54
Note : Order by number of reels.
B256
B
C
11.55
7
11.95
17.55
13
17.95
19
23.95
30
33.55
29
33.95
Remarks
RoHS
1.65mm high
YES
■Right angle receptacle, offset mounting
A
B
2.375
2.175
0.25
4.7
2.45
P=1
2
DF19K
identification indicator
6.7
F
1.46
F
C
B±0.05
3.175±0.1
2.975±0.1
P=1±0.05
1 +0.1
1.5 +0.1
0.55±0.05
2.5 +0.1
5.3±0.1
5.5±0.1
Outline of the plug
(2.2)
1
D +0.2
-0.1
E±0.1
Specification
(1,000 pcs/reel)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
DF19K-20P-1H (54)
685-0008-1 54
19
26.55 24.15 25.15
0.1
DF19K-30P-1H (54)
685-0032-6 54
30
33.55
29
36.55 34.15 35.15
0.1
Part No.
HRS No.
No. of contacts
A
B
DF19L-14P-1H (54)
685-0003-8 54
14
17.55
13
20.55 18.15 19.15
1.1
DF19L-20P-1H (54)
685-0019-8 54
19
26.55 24.15 25.15
1.1
DF19L-30P-1H (54)
685-0016-0 54
30
33.55
29
36.55 34.15 35.15
1.1
C
D
D
E
E
F
F
Remarks
RoHS
1.0mm high
YES
Remarks
RoHS
1.1mm high
YES
B257
■Right angle receptacle, reverse offset mounting
A
B
2.375
2.175
0.25
2
4.7
2.45
P=1
6.7
1
1.46
1
C
3.175±0.1
2.975±0.1
B±0.05
P=1±0.05
1+0.1
0.55±0.05
Outline of the plug
(2.2)
0.3
5.3±0.1
0.3
1.5
5.5±0.1
1
D +0.2
-0.1
E±0.1
Specification
(1,000 pcs/reel)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
DF19KR-14P-1H (54)
685-0024-8 54
14
17.55
13
20.55 18.15 19.15
DF19KR-20P-1H (54)
685-0023-5 54
19
26.55 24.15 25.15
B258
C
D
E
Remarks
RoHS
1.0mm high
YES
1.12
1.07
■ Vertical receptacle
P=1
0.25
0.95
B
1.3
1.56
5.22
A
1.96
3.8
1
A
0.25
2
+0.1
D±0.05
1.5 +0
2.5 +0.1
2.2±0.05
0.65 +0.1
0.65±0.05
(E)
+0.1
0.55±0.05
P=1±0.05
1.7 +0
1.45 +0
+0.1
Outline of the plus
1.46±0.05
C
(F)
G±0.05
0.8±0.05
Specification
(56) : Tape & reel packaging
(1,000 pcs/reel)
Conductive traces in this area must be covered by dielectric compound.
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
DF19-14P-1V (56)
685-0036-7 56
14
17.9
13
15.25 14.95 6.675 6.325
C
D
E
F
13
G
DF19-20P-1V (56)
685-0037-0 56
19
21.25 20.95 9.675 9.325
19
RoHS
YES
B259
■Plug (Discrete wire)
DF19-*S-1C
DF19G-*S-1C(05)
A
B
A
B
P=1
6.1
6.1
P=1
Contact No. 5 and multiples indicator
1.5
1.5
A
A
Specification
Blank,(05) : Bag packaging
(100 pcs/pack)
Unit : mm
Part No.
HRS No.
No. of contacts
A
B RoHS
DF19 -18S-1C
685-0029-1
8
11.5 7
DF19G -18S-1C(05) 685-0022-2 05
8
11.5 7
DF19 -14S-1C
685-0012-9
14
17.5 13
DF19G -14S-1C(05) 685-0005-3 05
14
17.5 13
DF19 -20S-1C
685-0011-6
DF19G -20S-1C(05) 685-0007-9 05
DF19 -30S-1C
685-0013-1
30
33.5 29
DF19G -30S-1C(05) 685-0014-4 05
30
33.5 29
YES
Part No.
HRS No.
No. of contacts
A
■Crimp contacts
Part No.
HRS No.
Packaging
DF19A-2830SCFA (* *) 685-0048-6 **
DF19A-3032SCFA (* *) 685-0046-0 ** Tape & reel
DF19A-3336SCFA (* *) 685-0047-3 **
Quantity
See Specifications
number below
Finish
RoHS
Gold plated YES
0.63
0.7
Specification number * *(* *)
Blank : Tape & reel packaging (10,000 pcs/reel)
(41) : Tape & reel packaging (20,000 pcs/reel)
2
Jacket diameter
Wire size (stranded wire conductor)
0.9
●Applicable cable (Tin plated annealed conductor)
28 AWG (7/ 0.127mm)
0.5mm to 0.6mm
0.5
30 AWG (7/ 0.1mm)
32 AWG (7/ 0.08mm)
36 AWG (7/ 0.05mm)
●Applicable UL style
●UL1571(thin type) (Note2)
0.27mm
Carrier strip
●Strip length
●1.2mm to 1.9mm
Note 1 : When using other than the recommended wire, contact your Hirose sales representative.
Note 2 : Contact your Hirose sales representative when using 36 AWG.
●Tools
Part
Part No.
HRS No.
Applicator
AP105-DF19S
901-4571-3
Press unit
CM-105C
901-0001-0
Note 1 : Use of other than Hirose Electric approved tools will void the product warranties.
Note 2 : Contact Hirose for the wire striping, contact crimp and contact insertion instructions.
Note 3 : Please do the crimping operations according to the "Crimping quality standard" and "Crimping condition table".
B260
B RoHS
Note: Order by number of bags.
5.1
Shown with terminated and installed contacts
14
No. of contacts
indicator
t=0.15
YES
■Plug (Flat Printed Circuit)
Note: Socket and grounding plate is required.
A
B
C
5.95
P=1
A
1.2
CAV No.
t=0.145±0.03
Ground area <
Signal area <
R
1±0 0.2
.05
0.05
0.05
:1 to 5μm thick solder plated>
0.3±0.15
R0.
0.4±0.05
0.35±0.03
E±0.05
(0.35)
MA
XR
MAXR0 0.2
.2
3.6
0.35±0.25
Polarizing mark indicator
2.2±0.05
0.2±0.15
0.2±0.1
0.3±0.15
1.85±0.25
2±0.15
D±0.08
0.45±0.3
C±0.05
P=1±0.03
0.7±0.03
.2
R0
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
E
DF19G-14S-1F(05)
685-0017-2 05
14
17.5
17.1
13
15.6
14
DF19G-20S-1F(05)
685-0009-4 05
23.1
19
21.6
DF19G-30S-1F(05)
685-0033-9 05
30
33.5
33.1
29
31.6
30
RoHS
Specification
(100 pcs/pack)
YES
Note : Order by number of bags.
■Ground plate for FPC
A
B
No. of contacts indicator
4.1
Shown terminated with FPC
SIGNAL
14
1.5
C
D
Unit : mm
Part No.
HRS No.
No. of contacts
A
B
C
D
DF19G-14S-1F-GND(05)
685-0018-5 05
14
15.75 14.35 17.5
14.4
DF19G-20S-1F-GND(05)
685-0010-3 05
20.4
DF19G-30S-1F-GND(05)
685-0034-1 05
30
31.75 30.35 33.5
30.4
RoHS
Specification
(100 pcs/pack)
YES
●Grounding plate installation tools
Type
Part No.
HRS No.
Desktop tool (for 14 pos.)
DF19G-14S/PR-MD2
902-4514-6
Desktop tool (for 20 pos.)
DF19G-20S/PR-MD2
902-4513-3
Desktop tool (for 30 pos.)
DF19G-30S/PR-MD2
902-4518-7
Note1 : Product is not guaranteed unless Hirose approved tools are used.
B261
6.1
P=1
1.33
C±0.2
D±0.15
P=1±0.1
Inner conductor
Insulator
Grounding bar
0.7±0.05
3±0.1
0.9MAX
A
B
Solder coat 1.2MIN
■Plug (Micro-coaxial cable)
Outer conductor
Jacket
Note 1 : Connectors are designed to allow termination without cutting
of the pitch loss prevention tape.
Note 2 : Required Solder coating for inner conductor.
Note 3 : When using 2-conductor micro-coaxial cable some contact
positions will not be used.
Contact your Hirose sales representative.
Shown terminated with micro-coaxial cable
No. of contacts
A
B
C
D
DF19G-14S-1SD(05) 685-0026-3 05
Part No.
HRS No.
14
17.4
13
14.8
13
DF19G-20S-1SD(05) 685-0025-0 05
19
20.8
19
YES
Specification
(100 pcs/pack)
●Applicable cable (Micro-coaxial cable)
Wire size (stranded wire center conductor)
Jacket diameter
40 AWG (7/ 0.03mm)
0.3mm to 0.4mm
4.36
A
Specification
Blank : Bag packaging
(100 pcs/pack)
Unit : mm
B262
RoHS
Part No.
HRS No.
No. of contacts
A
DF19G-14S-1SD-GND
685-0028-9
14
17.5
DF19G-20S-1SD-GND
685-0027-6
RoHS
YES
1.27
Cable preparation
.5 +0
G
G-G
1.75±0.15
t=0.3±±0.1
C±0.1
B±0.1
A±0.3
0 1
12±0.1
2±0.1 4±0.1
D±0.3
E +20
F
G
Unreeling direction
H-H
(2.3)
7.8±0.3
D
E
F
-------- 11.5
16.1
24.4
30.4
40.4
20.2
22.1
44.4
50.4
44
40.4
20.2
28.1
44.4
50.4
30
56
50.2
26.2
38.1
56.4
62.4
40.4
20.2
28.1
44.4
50.4
DF19K-30P-1H(54)
30
56
52.4
26.2
38.1
56.4
62.4
DF19L-14P-1H(54)
14
44
40.4
20.2
22.1
44.4
50.4
DF19L-20P-1H(54)
40.4
20.2
28.1
44.4
50.4
DF19L-30P-1H(54)
30
56
52.4
26.2
38.1
56.4
62.4
12±0.1
1.75±0.1
Unit : mm
No. of contacts
A
B
DF19G-18P-1H(54)
08
24
DF19G-14P-1H(54)
14
44
DF19G-20P-1H(54)
DF19G-30P-1H(54)
DF19K-20P-1H(54)
Ø1
.5 +0
0 .1
C
H
Top-board mounting
(1.65mm high)
Offset mounting
(1.0mm high)
Offset mounting
(1.1mm high)
G-G
1.75±0.15
t=0.3±0.1
2±0.5
C±0.1
B±0.1
A±0.3
G
Remarks
Ø1.5 in the rear
D±0.3
Part number label
Ø13
H
Ø21
Connector
G
H-H Unreeling direction
E +20
2.85±0.15
(2.3)
F
7.8±0.3
Unit : mm
No. of contacts
A
B
C
D
E
F
DF19KR-14P-1H(54)
14
44
40.4
20.2
22.1
44.4
50.4
Reverse type of DF19K
DF19KR-20P-1H(54)
40.4
20.2
28.1
44.4
50.4
4±0.1
3.7±0.2
H
2±0.5
Part number label
1
G
t=0.4±0.1
Unreeling direction
Depth of 1.5
diameter
Ø13
Ø2
H
D±0.2
G
Ø80
Ø380±2
12±0.1
2±0.1
C±0.1
B±0.1
A±0.3
.1
+0 0
5+
Ø1
●DF19-*P-1V(56)
Remarks
1.75±0.1
Connector
4±0.2
Ø13
H
2.5±0.15
●DF19KR-*P-1H(54)
Depth of 1.5
diameter
Ø 21
H
2±0.5
Part number label
Ø80
Ø330
Ø1
Ø80
Ø330
●DF19G-*P-1H(54)
●DF19K -*P-1H(54)
●DF19L -*P-1H(54)
1.75±0.1
BEmbossed Carrier Tape Dimensions Receptacles
E+2
+0
F
Unit : mm
Connector
No. of contacts
A
B
C
D
E
F
DF19-14P-1V(56)
14
32
28.4
14.2
18.2
32.4
38.4
DF19-20P-1H(56)
40.4
20.2
24.2
44.4
50.4
Remarks
Vertical receptacle
B263
BUse recommendations
1. Recommendedtemperature profile
Temperature(ç)
250ç
220
200ç
180
150ç
Preheating
60 to 120(S)
soldering
250ç
10(s)max
220ç min 60(s)max
100ç
B264
50ç
30
50
100
150
200
TIME(S)
Note 1 : Up to 2 cycles of Reflow soldering are possible under the same
conditions, provided that there is a return to normal temperature
between the first and second cycle.
Note 2 : The temperature profile indicates the board surface temperature at
the point of contacts with the connector terminals.
Note 3 : The product can be used without trouble though the surface of a
grounding plate might discolor.
2. Manual soldering
Manual soldering : 290±10ç for 3 seconds
3. Screen thickness
0.15mm
4. Board warpage
Maximum of 0.03mm at the connector center, with both ends of the connector as
reference points.
5. Cleaning conditions
Refer to “Wire-to-Board Connector Use Handbook.”
6. Termination conditions
7. Cautions
■ Do not twist when mating/un-mating.
8. Precautions
BPlug (FPC Type) Termination Procedures
(Dedicated Assembly Tooling is required.)
Insert the FPC diagonally from the top surface of the grounding plate.
Pass the FPC through the grounding plate.
Step 1
After passing through, lower the FPC (as shown) to horizontal position.
Signal surface
Step 2
Ground surface
Extend the FPC out and fully insert into the socket.
Exercising caution slide the grounding plate forward and pre-insert it over the socket.
Step 4
Assembly point: Slightly raise the FPC to an angle of about 30 degrees,
and then insert the grounding plate over the socket.
Using the dedicated installation tool, insert the grounding plate.
1.7
Final
completion
Note 1 : The grounding plate and the plug are supplied as separate components.
Note 2 : Dedicated assembly fixtures are required at each stage of the termination process. For detail, refer to the instruction manual
supplied with the tools.
Note 3 : Do not apply excessive forces to FPC (Bending or twisting) as it may introduce cracks in the copper foil (on the cover film edge).
Note 4 : To protect the FPC, insertion and disconnection of the connectors should be performed parallel to the mating direction.
Note 5 : Do not apply excessive tension to FPC.
Note 6 : Refer to FPC manufacturer for bend radius and other specific recommendation. Distance should be allowed for the bending
position, as illustrated below.
MIN 5
SIGNAL
MIN 10
Step 3
Note 7 : Follow the instruction manuals for the termination and assembly fixtures and tools.
B265
