LRE1206-21R007F5
LRE1206-21R007F5
    RALEC(旺诠)
    电流采样电阻 1206 7mΩ ±1% ±50ppm/℃ 1W
LRE1206-21R007F5 数据手册
RALEC LRE Series Metal Alloy Low-Resistance Resistor Product Specifications 旺詮 Document. No Released Date Page No. IE-SP-074 2020/07/22 1 1 Scope: 1.1 This specification is applicable to lead free and halogen free of RoHS directive for LRE series metal alloy low-resistance resistor. 1.2 The product is for general electronic purpose. 2 Explanation Of Part Numbers: LRE 0603 Type Size (inch) Metal Alloy Low Resistance Resistor 0402 0603 0805 1206 Written IE Checked - 2 Number of Terminals 2: 2 terminals Approved F Rated Power P=1/6W H=1/5W G=1/4W F=1/3W E=3/4W C=1/2W 1=1.0W A=1.5W QA Signing R005 Resistance (4~5 Digits) EX: R0025 = 2.5 mΩ R005 = 5mΩ R010 = 10mΩ F 5 Tolerance Packaging D=±0.5% F=± 1.0% G=± 2.0% J=± 5.0% 5=5,000pcs TH=10,000pcs Remark Issue Dep.DATA Center. IT'S NOT UNDER CONTROL FOR PDF FILE PLS NOTE THE VERSION STATED.. Do not copy without permission Series No.60 RALEC 旺詮 Document No. Released Date Page No. LRE Series Metal Alloy Low-Resistance Resistor Product Specifications IE-SP-074 2020/07/22 2 3 Product Specifications: Type Max. # of Rating Terminals Power Rating Current Overload Current 2 -- ≦±200 -- 3 ≦±125 -- 4~5 ≦±50 -- 10 ≦±600 -- ≦±200 -- 3 ≦±125 -- 4~5 ≦±50 -- 10 ≦±200 -- 3 1/4W ≦±125 -- 4~5 ≦±50 -- 10 1/3W ≦±50 --- 1≦ R <4 1/5W ≦±450 1/3W 0603 Ir=ඥP⁄R 2 1/2W 1/2W 0805 2 3/4W 1/2 W 1206 Resistance Range (mΩ) F (±1%) D (±0.5%) G (±2%) J (±5%) ≦±600 1/6W 0402 T.C.R. (ppm/°C) 2 1W lo=ඥ4P⁄R 1.5≦ R <3 1.5≦ R <3 10 10≦ R ≦60 -- 4≦ R ≦60 ≦±450 ≦±50 10≦ R ≦15 4≦ R ≦15 ≦±100 -- 1.5≦ R <3 ≦±75 -- 3≦ R <5 ≦±50 5≦ R ≦70 5≦ R ≦70 ≦±100 -- 1.5≦ R <3 ≦±75 -- 3≦ R <5 ≦±50 5≦ R ≦10 5≦ R ≦10 ≦±400 -- 1≦ R <2 ≦±75 -- 2≦ R <4 ≦±50 5≦ R ≦75 4≦ R ≦75 ≦±400 -- 1≦ R <2 ≦±75 -- 2≦ R <4 ≦±50 5≦ R ≦75 4≦ R ≦75 ≦±50 Operating Temperature Range 2≦ R <4 -55~+150°C Ir=Rating Current(A) Io= Overload Current(A) P= Rating Power(W) R=Resistance(Ω) Remark IT'S NOT UNDER CONTROL FOR PDF FILE PLS NOTE THE VERSION STATED.. Do not copy without permission Issue Dep.DATA Center. Series No.60 RALEC 旺詮 LRE Series Metal Alloy Low-Resistance Resistor Product Specifications Document No. Released Date Page No. IE-SP-074 2020/07/22 3 3.1 Power Derating Curve: Operating Temperature Range: - 55 ~+150 ℃ For resistors operated in ambient temperatures 70°C, power rating shall be derated in accordance with the curve below: 70 Rating Power(%) 100 80 60 40 150 20 0 -55 Remark 80 100 120 140 160 Ambient Temperature(℃) 20 40 60 IT'S NOT UNDER CONTROL FOR PDF FILE PLS NOTE THE VERSION STATED.. Do not copy without permission Issue Dep.DATA Center. Series No.60 RALEC 旺詮 LRE Series Metal Alloy Low-Resistance Resistor Product Specifications Document No. Released Date Page No. IE-SP-074 2020/07/22 4 4 Physical Dimensions: 0402/0603/0805 1206 R005 W L T1 T1 H Type Power Rating (Watts) Resistance Range (mΩ) L W H T1 1/6 & 1/5 1.5~5 10 0.039±0.004 (1.00±0.10) 0.020±0.004 (0.50±0.10) 0.010±0.004 (0.25±0.10) 0.010±0.004 (0.25±0.10) 1/4 3~5 10 1/3 10 0.039±0.004 (1.00±0.10) 0.020±0.004 (0.50±0.10) 0.010±0.004 (0.25±0.10) 0.010±0.004 (0.25±0.10) 1/3 1 ~ 60 1/2 2 ~ 15 0.063±0.008 (1.60±0.20) 0.031±0.008 (0.80±0.20) 0.010±0.004 (0.25±0.10) 0.012±0.006 (0.30±0.15) 1/2 & 3/4 1.5 2 2.5 0.08±0.008 (2.032±0.20) 0.05±0.008 (1.270±0.20) +0.002 -0.004 +0.05 (0.35 ) -0.10 0.02±0.006 (0.50±0.15) 1/2 3 ~ 70 3/4 3 ~ 10 0.08±0.008 (2.032±0.20) 0.05±0.008 (1.270±0.20) +0.002 -0.004 +0.05 (0.30 ሻ -0.10 0.014±0.008 (0.35±0.20) 0.016±0.008 (0.40±0.20) 0.035±0.008 (0.90±0.20) 0.024±0.008 (0.60±0.20) 0.014±0.008 (0.35±0.20) 0402 0603 0805 0.014 0.012 1≦R<3 1206 1/2 & 1 3≦R<4 0.126±0.008 (3.20±0.20) 0.063±0.008 (1.60±0.20) 4≦R≦75 Remark IT'S NOT UNDER CONTROL FOR PDF FILE PLS NOTE THE VERSION STATED.. Do not copy without permission Issue Dep.DATA Center. Series No.60 RALEC 旺詮 LRE Series Metal Alloy Low-Resistance Resistor Product Specifications Document No. Released Date Page No. IE-SP-074 2020/07/22 5 4.1 Material of Alloy Type Watts LRE0402 1/6W 1/5W 1/4W 1/3W LRE0603 LRE0805 Resistance Copper-Manganese Alloy 1.5mΩ≤R≤10mΩ 1/3W 1/2W Copper-Manganese Alloy 1mΩ≤R
LRE1206-21R007F5 价格&库存
很抱歉,暂时无法提供与“LRE1206-21R007F5”相匹配的价格&库存,您可以联系我们找货
LRE1206-21R007F5
  • 10+0.31951
  • 100+0.25512
  • 1000+0.19881
库存:4770
LRE1206-21R007F5
    • 10+0.36710
    • 100+0.29312
    • 300+0.25618
    • 1000+0.22842
    库存:3167
