SLSS49E
High Voltage Hall Effect Switch Sensor
Introduction
SLSS49E Linear Hall-effect sensor is small, versatile device that is operated by the magnetic field from a
permanent magnet. The linear sourcing output voltage is set by the supply voltage and varies in
proportion to the strength of the magnetic field. The integrated circuitry features low noise output, which
makes it unnecessary to use external filtering. The sensor Interfaces with many electrical components
without buffering. It includes thin film resistors to provide increased temperature stability and accuracy.
The linear Hall-effect sensor has an operating temperature range of -40 °C to 150°C, appropriate for
consumer, industrial and medical environments. The sensor is available in 2 package styles, which are
TO92 and SOT23.
Features
Potential Applications
Miniature construction
Current sensing
Low current consumption of 5 mA at 5 Vdc
Motor control
Voltage range of 3 Vdc to 12 Vdc
Position sensing
Low noise output
Magnetic code reading
Temperature range of -40 °C to 150 °C
Rotary encoder
Highest ESD performance up to ±4 kV
Ferrous metal detector
React differently to the Antarctic and Arctic
Liquid level sensing
magnetic fields
Weight sensing
Package
www.slkormicro.com
1
SLSS49E
Ordering information
Part number
Package
Packing
Ambient, TA
SLSS49E-9
TO92S
Bulk, 1000 pieces/bag
-40℃ to 150℃
SLSS49E-3
SOT23
Tape&Reel, 3000 pieces/reel
-40℃ to 150℃
Pin assignment
Pin number
Name
Function
1
2
3
VDD
GND
Vout
Power supply
Ground
Output
Absolute Maximum Ratings
The absolute maximum value is the limiting value when the chip is applied, above which the chip can be
damaged. Although the function of the chip is not necessarily damaged when the absolute maximum
value is exceeded, the reliability of the chip may be affected if the absolute maximum value is exceeded
for a certain time.
Parameter
Symbol
Value
Units
Supply voltage
VDD
15
V
Reverse voltage
VDD
-0.5
V
Output Current
IOUT
5
mA
Operating temperature range
Ta
-40~150
Storage temperature range
Ts
-40~165
www.slkormicro.com
2
SLSS49E
Electrical and magnetic characteristics (Ta=25˚C, VDD =5.0V)
Parameter
Operating
voltage
Supply current
Output Current
Response Time
Test
Conditions
Min
Typ
Max
Units
VDD
3
5
12
V
IDD
IOUT
Trs
3
5
8
1.5
mA
mA
uS
Symbol
3
Quiescent
Output Voltage
Vo
Sensitivity
Sen
Min Output
Voltage
Vmin
B= -460G
1
V
Max Output
Voltage
Vmax
B= 460G
4
V
Output load
resistance
RL
|ΔVOUT|
很抱歉,暂时无法提供与“SLSS49E-3”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.93390
- 200+0.71830
- 1500+0.62370
- 3000+0.58080
- 国内价格
- 5+0.87933
- 50+0.77180
- 600+0.66817
- 1200+0.65815
- 3000+0.60422
- 国内价格 香港价格
- 1+1.405221+0.18163
- 国内价格 香港价格
- 5+1.196565+0.15466
- 10+1.1177910+0.14448
- 25+1.0317725+0.13336
- 50+0.9755650+0.12609
- 100+0.92265100+0.11926
- 500+0.81684500+0.10558
- 1000+0.777821000+0.10054
- 国内价格
- 5+0.96907
- 50+0.85056
- 150+0.79977
- 500+0.73636
- 3000+0.66588
- 6000+0.64895
