15366066
15366066
    APTIV(安波福)
    汽车连接器 1Pin 1Row
15366066 数据手册
40 39 38 37 36 35 34 33 32 31 30 29 28 27 26 25 24 23 22 21 20 19 18 17 16 15 14 13 12 11 10 9 8 7 6 5 4 SYMBOL DEFINITION 3 DWG STATUS MISSING SYMBOLS DATE A DIMENSION WITHOUT AN INSPECTION REPORT SYMBOL DOES NOT REQUIRE INSPECTION. IT MAY BE CONTROLLED ON THE INDIVIDUAL COMPONENT DRAWING. SEE SEAL/MYLAR DETAIL M CAVITY NUMBER TOOL ID TOTAL NO OF INSPECTIONS REQUIRED LAST NO. USED 1 3-4 6 9 F F H H 06 - - - C G A K B A B C C 101 103 5.8 TYPE SAME AS TYPE 101 EXCEPT AS SHOWN AND AS NOTED IN CHART SEAL (SEE CHART) J SEAL/MYLAR ASSEMBLY DETAIL SECTION NO SCALE TYPE 101 SECTION H-H F-F OPTIONAL CONSTRUCTION 4 OPTIONAL CONSTRUCTION 1 H 1. THE MYLAR TAPE IS ONLY A CARRIER USED AS A PROCESS AID AND IS NOT PART OF THE FINAL HARNESS ASSEMBLY. SECTION 2. WHEN PARTS ARE SHIPPED, THEY MUST BE PACKED IN PLASTIC BAGS OR SHIPPING CONTAINERS MUST BE LINED WITH PLASTIC LINERS. BAGS OR LINER MUST BE SEALED TO AVOID ENTRY OF FOREIGN MATTER. B-B 235238 JS JS CD M 12191221,12191222,12191223-CHANGED MYLAR STRIP MATERIAL-SEE TQD 239244 SS SS CD 19FE04 R 08 - - 12191221-23 & 12191152-57 - UPDATED PDM ATTRIBUTES; 12191226-34 - UPDATED MAT'L SPEC; ALL ACTIVE PARTS - REMOVED LABEL 251754 MDH JAA RM 09MR04 R 09 - - 12191221-23 - CORRECTED REVISION LEVELS ON DRAWINGS 252831 LMB LMB MR 30MR04 R 10 - - ADDED CUSTOMER SPECIFIC DRAWING 253027 MJM MJM LN 02JL04 R 11 - - 121912221,12191222,12191223 - CORRECTED ECL 256636 LLJ LLJ MR 23FE05 R 12 - - ALL ACTIVE PARTS - ADDED RESTRICTED 265282 RH RH MR STATUS, ALTERNATE MATL SPEC, SEE NOTE 3 TO CABLE O.D. DIN AND DIM 'C' 24AU05 R 13 - - ALL PARTS - REVISED CHART; 12191227 REVISED INTERNAL NECK GROOVE, ADDED MYLAR/SEAL ASSEMBLY DETAIL 270772 PCP PCP MR 19MY06 R 14 - - ALL ACTIVE PARTS - REMOVED DIMS #4 & #6 FROM DWG AND DIM #7 ("F") FROM CHART 280824 AB BKD MR 08JN07 R 15 - - ADDED 13649970, 13652517 AND RELEASED, ALL ACTIVE PARTS - REVISED CHART 401495 PCP PCP TAV 03DE07 R 16 - - 12191235,13667445,15305351,15336674, 15366021-22,15366060-61,15366063-67 & 15473821 - WERE ON SHT 02; ALL PARTS - UPDATED CHART INFO AND SHEET 1 OF 1 WAS SHEET 1 OF 2; 15473821 - OBSOLETE 402609 JBD JAA MR L K 06DE07 R 17 - - 13681284 & 13681285 - RELEASED; 403110 JBD JAA TAV 13649970 - RESTRICTED, CABLE O.D. WAS 2.09-2.66, C WAS 3.45 & G WAS 5.75; 13652517 - RESTRICTED, C WAS 3.45 AND G WAS 5.75 12MY08 R 18 - - 13711484 & 13711485 - RELEASED ALL PARTS - UPDATED PDM ATTRIBUTES 404626 HAM TLD TAV 22MY08 R 19 - - 13681284 & 13681285 - MAT'L DESCRIPTION WAS FVMQ ORANGE & FVMQ BLUE 404799 TLD TLD TAV J 21JL08 R 20 - - 13649970, 13681284, 13681285, 13652517 - 405458 ACG FKV TAV OBSOLETE 11AU09 R 21 - - 12191226 & 15366021 - UPDATED PDM ATTRIBUTES 408599 JOA FKV MPR 17SE09 R 22 - - 12191226-34, 15366060, 15366021 & 13667445 - UPDATED PDM ATTRIBUTES 408962 JOA FRG MPR 19NO09 R 23 - - ALL ACTIVE PARTS - UPDATED PDM ATTRIBUTES; 13667445 - RESTRICTED; 15305351 - DIM 3.9 +0.2/-0.05 WAS DIM G 0.1 409494 JTZ FKV MPR 03DE09 R 24 - 15366021 - UPDATED PDM ATTRIBUTES 409594 DGL DGL MPR H 04MR10 R 25 - - 15305351 - UPDATED PDM ATTRIBUTES 410123 DGL DGL MPR 10JN10 R 26 - - 13824958 - RELEASED 411023 MAB JAA VMR 15SE10 R 27 - - 13846994 - RELEASED 411974 VMR VMR VMR 25OC10 R 28 - - 14OC11 R 29 - - ALL ACTIVE PARTS - ADDED OPTIONAL CONSTRUCTION 1, 2 & 3 VIEWS 415729 JTZ JTZ ACM 08MR12 R 30 - - ALL PARTS - ADDED REEL NUMBER 417407 EGH EGH EGH 09JA13 R 31 - - 15502631 - RELEASED 420941 JOR JFF JOR G 21JA13 R 32 - - 13667445 - UPDATED PART AVAILABILITY; 15502631 G WAS 6.35 421164 JOR JSM JOR 03AP13 R 33 - - 15473821 - UPDATED MATERIAL CALLOUT AND 421905 CBG CBG MAC DIM 3.9 +0.2/-0.05 WAS DIM 3.9+0.1/-0.05 23MY13 R 34 - - 15502631 - UPDATED PART AVAILABILITY 422688 JOR FRE JOR 05JN13 R 35 - - 12191226 - UPDATED PART AVAILABILITY 422854 JOR JSM JOR 16AP14 R 36 - - ALL PARTS - ADDED "25% OF WALL THK DISTANCE IS MAX NEGATIVE SPRUE PERMISSIBLE" NOTE 426282 CAR JAA EGH 10 C ALL PARTS +0.15/-0.1 WAS TYPE 104 WAS TYPE 101 EXCEPTION 25% OF WALL THK DISTANCE IS MAX NEGATIVE SPRUE PERMISSIBLE SECTION SECTION A-A C-C G E E GT 150 3.5 CL F 12191152 THRU 12191157 & 12191221 THRU 12191223 - REVISED TOOL QUALIFICATION DRAWING - FOR EXISTING TOOL ONLY, NOT TO BE USED ON NEW TOOLS NOTES DR APVD APVD 1 2 AUTH - 102 TYPE REVISION HISTORY 07 TYPE SAME AS TYPE 101 EXCEPT AS SHOWN AND AS NOTED IN CHART 7 1 11AP03 - 5 8 REEL NO. (C-5799) 07FE03 - ZONE 10 E MYLAR STRIP (SEE CHART) STG REV N/P CHG 5 2 L 2 15473821 15366022 15305351 12191229 SEE SEAL/MYLAR DETAIL 02 01 02 04 CABLE SEAL GT 150 E SECTION REV N/P MYLAR STRIP (SEE CHART) OPTIONAL CONSTRUCTION 2 01 01 02 01 01 04 D19 CABLE SEAL REEL NO. (C-5799) RESTRICTED 15366022 REPLACED BY USAGE 102 101 104 101 VMQ SELF-LUBRICATING REDDISH BROWN VMQ SELF-LUBRICATING GREEN VMQ SELF-LUBRICATING YELLOW VMQ SELF-LUBRICATING GREEN 2-2.2 1.4-1.9 1.7-2.1 1.4-1.9 2.4 2.4 2.4 2.4 TYPE MAT'L SPEC CABLE O.D. RANGE C 3.25 3.2 3.25 3.25 3.9 +0.2/-0.05 4 +0.1/-0.05 3.9 +0.2/-0.05 4 +0.1/-0.05 E +0.15/-0.1 0.029 0.034 0.033 0.034 G VOL 15305352 12191155 MYLAR & CABLE SEAL ASM CM3 A1 03 AF REV N/P GT 280 AD AD AJ AY AG AJ - REV N/P RESTRICTED RESTRICTED RESTRICTED 15366060 15366021 REPLACED BY USAGE 101 102 102 101 101 102 101 FVMQ RED/BROWN FVMQ RED/BROWN VMQ SELF-LUBRICATING BLUE VMQ SELF-LUBRICATING WHITE VMQ SELF-LUBRICATING WHITE VMQ SELF-LUBRICATING BLUE VMQ SELF-LUBRICATING WHITE 1.2-1.9 1.86-2.4 1.86-2.4 1.2-1.9 1.2-1.9 1.86-2.4 1.2-1.9 2.8 2.8 2.8 2.8 2.8 2.8 2.8 TYPE MAT'L SPEC CABLE O.D. RANGE C 3.5 3.5 3.5 3.5 3.5 3.5 3.5 4.5 4.5 4.5 4.5 4.5 4.5 4.5 E +0.15/-0.1 G 0.041 0.037 0.037 0.041 0.041 0.037 0.041 VOL @0.1 12191153 12191152 MYLAR & CABLE SEAL ASM CM3 B8 B9 - REV N/P 0.1, 412355 DMC DMC MPR R0072686 M5235002 102 21AP15 R 37 - - ALL ACTIVE PARTS - ADDED OPTIONAL CONSTRUCTION 4 VIEW AND OPTIONAL CONSTRUCTION 3 REVISED GRAPHICS 429305 JVR JVM JGR F MYLAR STRIP TYPE 21JN16 R 38 - - 12191226 - CORRECTED PART AVAILABILITY 433473 KAS STO SYS 08JL19 R 39 - - 15366065-67 - ADDED MYLAR ASM PART NUMBER; 12191221 - CABLE SEAL WAS 12191222 - CABLE SEAL WAS 12191223 - CABLE SEAL WAS 443329 LVD ERG ERG 4.0 INTERNAL CAVITY DIAMETER 13846994 13824958 15366060 15366021 13667445 12191227 12191226 E-E AA AU AU AN 3.2 X 4.0 OVAL INTERNAL CAVITY DIAMETER C M5235002 M5235002 102 102 MYLAR STRIP TYPE & CABLE SEAL 12191232; 12191233; 12191234; 26FE20 R 40 - - 35289308 - ADDED FROM CUSTOMER PD AND ADDED "EQUIVALENT CABLE SEAL" INFO 551086 JLL JAA SV 03MR20 R 41 - - 35289308 - UPDATED PART AVAILABILITY 551204 LGD JAA SV E D 5.2 INTERNAL CAVITY DIAMETER D D D G 15366064 15366063 15366061 15336674 12191231 12191230 12191228 G 01 01 01 02 B17 C16 B17 CABLE SEAL AT AR AR AU - REV N/P RESTRICTED RESTRICTED RESTRICTED 15366064 15366063 15366061 REPLACED BY USAGE 101 101 101 103 101 101 101 VMQ SELF-LUBRICATING VIOLET VMQ SELF-LUBRICATING GRAY VMQ SELF-LUBRICATING DARK RED VMQ SELF-LUBRICATING BLUE VMQ SELF-LUBRICATING VIOLET VMQ SELF-LUBRICATING GRAY VMQ SELF-LUBRICATING DARK RED 1.86-2.4 1.2-1.9 2.09-2.66 2.7-3.2 1.86-2.4 1.2-1.9 2.09-2.66 3.45 3.45 3.45 3.6 @0.15 3.45 3.45 3.45 TYPE MAT'L SPEC CABLE O.D. RANGE C 3.5 3.5 3.5 3.5 3.5 3.5 3.5 5.75 5.75 5.75 5.75 @0.15 5.75 5.75 5.75 E +0.15/-0.1 G 0.067 0.073 0.063 0.056 0.067 0.073 0.063 VOL @0.1 12191157 12191156 12191154 MYLAR & CABLE SEAL ASM CM3 B6 B6 B6 - REV N/P M5235004 M5235004 M5235004 101 101 101 MYLAR STRIP TYPE NOTES 1. UNLESS OTHERWISE SPECIFIED AND/OR INDICATED: 104 TYPE SAME AS TYPE 101 EXCEPT AS SHOWN AND AS NOTED IN CHART DIMENSIONS ARE TO FACE OF VIEW SHOWN AND AUTOMATICALLY ROUNDED BY COMPUTER FOR INSPECTION (SEE MATH MODEL FOR PRECISE DIMENSIONS). FOR ALL OTHER DIMENSIONS NOT SHOWN BUT REQUIRED FOR TOOL BUILD, SEE MATH MODEL FOR PRECISE TOOL PATH DATA. C C 2. PARTS SHOULD BE MADE FROM VIRGIN MATERIAL ONLY. 5.8 INTERNAL CAVITY DIAMETER 3. CABLE SEALS MADE FROM LOWER OIL MATERIAL (1-2%)ARE RECOMMENDED FOR THE LOOSE PIECE SEAL APPLICATION PROCESS. SEAL/MYLAR ASSEMBLY DETAIL NO SCALE 102 TYPE SAME AS TYPE 101 EXCEPT AS SHOWN OPTIONAL CONSTRUCTION 3 THIS IS THE PREFERRED CONSTRUCTION FOR NEW TOOL BUILDS (ANTI-STICK RING) B NOTES 1. THE MYLAR TAPE IS ONLY A CARRIER USED AS A PROCESS AID AND IS NOT PART OF THE FINAL HARNESS ASSEMBLY. 2. WHEN PARTS ARE SHIPPED, THEY MUST BE PACKED IN PLASTIC BAGS OR SHIPPING CONTAINERS MUST BE LINED WITH PLASTIC LINERS. BAGS OR LINER MUST BE SEALED TO AVOID ENTRY OF FOREIGN MATTER. SECTION A G-G 01 01 01 01 01 01 02 02 01 01 01 03 D13 B17 C16 CABLE SEAL AB AD AF AF AD AD AC AC AW AU AV AT - REV N/P RESTRICTED RESTRICTED RESTRICTED RESTRICTED RESTRICTED RESTRICTED RESTRICTED 12191235 EQUIVALENT CABLE SEAL USAGE 15366067 15366066 15366065 REPLACED BY 101 101 101 101 101 101 101 101 101 101 101 101 101 101 101 TYPE VMQ SELF-LUBRICATING VIOLET VMQ SELF-LUBRICATING BLUE FVMQ GREEN FVMQ RED/BROWN FVMQ/VMQ BLEND ORANGE FVMQ/VMQ BLEND BLUE FVMQ ORANGE FVMQ BLUE VMQ SELF-LUBRICATING TAN VMQ SELF-LUBRICATING YELLOW VMQ SELF-LUBRICATING ORANGE VMQ SELF-LUBRICATING VIOLET VMQ SELF-LUBRICATING TAN VMQ SELF-LUBRICATING YELLOW VMQ SELF-LUBRICATING ORANGE 3.4-3.9 2.7-3.4 1.2-1.9 1.86-2.4 1.2-1.9 1.86-2.4 1.2-1.9 1.86-2.4 2.5-3.2 1.86-2.4 1.2-1.9 3.4-3.9 2.5-3.2 1.86-2.4 1.2-1.9 MAT'L SPEC CABLE O.D. RANGE 4.25 +0.2/-0 4.25 4.25 4.25 4.25 4.25 4.25 4.25 4.25 4.25 4.25 4.25 +0.2/-0 4.25 4.25 4.25 C +0.15/-0.1 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 3.5 6.35 6.35 +0.15/-0 6.35 6.35 6.35 6.35 6.35 6.35 6.35 +0.15/-0 6.35 6.35 6.35 6.35 +0.15/-0 6.35 6.35 E G @0.1 0.063 0.082 0.102 0.096 0.102 0.096 0.102 0.096 0.085 0.096 0.102 0.063 0.085 0.096 0.102 VOL CM3 12191223 12191222 12191221 12191224 MYLAR & CABLE SEAL ASM D10 B10 B10 B1 - - M5235003 M5235003 M5235003 R0065622 - 40 39 38 37 36 35 A1x5 34 CONTACT APTIV SALES TO ASSURE AVAILABILITY OF PARTS. 5. THIS PRODUCT IS NOT CATEGORIZED AS AN APPEARANCE ITEM, MINOR IMPERFECTIONS INCLUDING, BUT NOT LIMITED TO, FLOW MARKS, COLOR BLEMISHES, GATE VESTIGE, AND SOFT FLASH THAT DO NOT AFFECT THE FIT, FORM, OR FUNCTION OF THE PART ARE PERMISSIBLE PER DPNP-4.7-CS-01. SECTION REV N/P MYLAR STRIP FRAME NO SHEET NO STG REV DWG TYPE PART DRAWING DR D-D 20:1 3 OF 3 1 OF 1 R 41 33 - A1x5 18 32 31 30 29 28 27 26 25 24 23 22 21 20 19 DISTR CODE VOLUME (CM3) D SEE CHART TYPE SCALE PROCESS SENSITIVE DIMENSION FRAME NO SHEET NO STG REV 20:1 2 OF 3 1 OF 1 R 41 17 DIMENSIONAL RANGE (MM) CHART E 0 20 30 70 FROM 100 TO 20 30 70 100 TOLERANCE UNLESS OTHERWISE SPECIFIED 0.15 0.2 0.3 0.4 0.5 ANGULAR TOLERANCE 2 N/P 16 15 14 13 12 11 10 9 8 7 6 5 4 APVD1 APVD2 APVD3 K. MONTERO D. BRANTINGHAM S. C. HSIEH B 19OC94 19OC94 04MR95 APVD4 APVD5 SUBSTANCES OF CONCERN AND RECYCLED CONTENT PER APTIV 10949001 MATERIAL SEE CHART DRAWING NAME REFERENCE TAXI SEAL CBL 1W GT DIMENSIONS ENCLOSED IN INDICATE REFERENCE DIMENSIONS AND NO TOLERANCE LIMITS ARE ESTABLISHED 12191225 THIS DRAWING IS THE PROPERTY OF APTIV AND CONTAINS APTIV CONFIDENTIAL INFORMATION. THE REPRODUCTION, DISTRIBUTION AND UTILIZATION OF THIS DOCUMENT OR ITS RELATED CAD MATH DATA, AS WELL AS COMMUNICATION OF ANY CONTENT TO OTHERS, WITHOUT EXPRESS AUTHORIZATION, IS PROHIBITED. DATE THIS DOCUMENT IS IN ACCORDANCE WITH ASME Y14.5M-1994 AS AMENDED BY THE GM GLOBAL DIMENSIONING AND TOLERANCING ADDENDUM - 1997. ALL GEOMETRIC TOLERANCES AND RELATED DATUMS APPLY RFS. RULE #1(PERFECT FORM AT MMC) DOES NOT APPLY WHEN RELATIONSHIP BETWEEN FEATURES IS ESTABLISHED BY ORIENTATION OR LOCATION TOLERANCES. SEPARATE POSITION CALLOUTS MAY BE GAGED SEPARATELY, REGARDLESS OF DATUM REFERENCE. ALL DIMENSIONS ARE IN MILLIMETERS SIZE WARREN, OH COPYRIGHT 1994 APTIV. ALL RIGHTS RESERVED. STYLE UNLESS OTHERWISE SPECIFIED N/P CONNECTION SYSTEMS PART NUMBERS THAT DO NOT HAVE A LINE PRESENT INDICATE THAT PHYSICAL PARTS ARE AVAILABLE FOR ORDERING. DRAWING NUMBER 12191225 SCALE 4. CABLE SEALS MADE FROM HIGHER OIL MATERIAL (4%)ARE RECOMMENDED FOR THE MYLAR/CABLE SEAL ASSEMBLY PROCESS. 5 DRAWING NUMBER SIZE 101 101 101 - A DRAWING NUMBER THIRD ANGLE PROJECTION 12191225 DO NOT SCALE USE MATH DATA 3 SIZE SCALE FRAME NO SHEET NO STG A1x5 2 20:1 1 OF 3 1 OF 1 R 1 REV N/P 41 - 121 35289308 15502631 13711485 13711484 13681285 13681284 13652517 13649970 15366067 15366066 15366065 12191235 12191234 12191233 12191232 A LINE DRAWN THROUGH A PART NUMBER INDICATES THAT PHYSICAL PARTS ARE NOT AVAILABLE FOR ORDERING. Time: 13:39:06 GT 280 User: gj58wn Part: 12191225-CUS01-S01/41 Date: 04-Mar-20 gj58wn,03042020,13:38,1124pass,nor SEAL (SEE CHART)
15366066 价格&库存
很抱歉,暂时无法提供与“15366066”相匹配的价格&库存,您可以联系我们找货
    • 12000+0.12100
    库存:11880
    15366066
      • 20+0.20606
      库存:82
