ES3JF
ES3JF
    JINGDAO(晶导微电子)
    SMAF(DO-214AD)
    表面贴装超快速恢复整流器 反向电压–50至600V 正向电流–3 A
ES3JF 数据手册
山东晶导微电子有限公司 ES3AF THRU ES3JF Jingdao Microelectronics Surface Mount Superfast Recovery Rectifier Reverse Voltage – 50 to 600 V PINNING Forward Current – 3 A PIN FEATURES • For surface mounted applications • Low profile package • Glass Passivated Chip Junction • Superfast reverse recovery time • Lead free in comply with EU RoHS 2011/65/EU directives DESCRIPTION 1 Cathode 2 Anode 1 2 Top View Marking Code: ES3AF~ES3JF: ES3A~ES3J Simplified outline SMAF and symbol MECHANICAL DATA • Case: SMAF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 27mg / 0.00095oz Absolute Maximum Ratings and Characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase, half wave, 60 Hz, resistive or inductive load. For capacitive load, derate current by 20%. Symbols ES3AF ES3BF ES3CF ES3DF ES3EF ES3GF ES3JF Units Maximum Repetitive Peak Reverse Voltage V RRM 50 100 150 200 300 400 600 V Maximum RMS voltage V RMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage V DC 50 100 150 200 300 400 600 V Maximum Average Forward Rectified Current at T c = 125 °C I F(AV) 3 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 80 A Maximum Forward Voltage at 3 A VF Parameter Maximum DC Reverse Current T a = 25 °C at Rated DC Blocking Voltage T a =125 °C Typical Junction Capacitance at V R =4V, f=1MHz Maximum Reverse Recovery Time (1) Typical Thermal Resistance (2) Operating and Storage Temperature Range 1.25 1 1.68 V IR 5 100 μA Cj 40 pF t rr 35 ns RθJA RθJC 50 16 °C/W T j , T stg -55 ~ +150 °C (1)Measured with I F = 0.5 A, I R = 1 A, I rr = 0.25 A . (2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas. 2016.12 SMAF-E-ES3AF~ES3JF-3A600V Page 1 of 3 山东晶导微电子有限公司 ES3AF THRU ES3JF Jingdao Microelectronics Fig.1 Reverse Recovery Time Characteristic And Test Circuit Diagram 50 ohm Noninductive t rr 10 ohm Noninductive +0.5 D.U.T + PULSE GENERATOR Note 2 25Vdc approx 0 - -0.25 1 ohm NonInductive OSCILLOSCOPE Note 1 -1.0 Note:1.Rise Time = 7ns, max. Input Impedance = 1megohm,22pF. 2. Ries Time =10ns, max. Source Impedance = 50 ohms. 10ns/div Set time Base for 10ns/div Fig.3 Typical Reverse Characteristics 4.0 300 3.5 100 I R - Reverse Current ( μ A) Average Forward Current (A) Fig.2 Maximum Average Forward Current Rating 3.0 2.5 2.0 1.5 1.0 0.5 Single phase half-wave 60 Hz resistive or inductive load T J =125°C 10 T J =75°C 1.0 T J =25°C 0.1 0.0 25 50 75 100 125 150 175 20 0 40 Case Temperature (°C) Junction Capacitance ( pF) Instaneous Forward Current (A) T J =25°C 1.0 ES3AF~ES3DF ES3EF/WS3GF 0.1 80 100 Fig.5 Typical Junction Capacitance Fig.4 Typical Forward Characteristics 10 60 % of PIV.VOLTS ES3JF 0.01 T J =25°C 100 10 T J=25°C f = 1.0MHz V sig = 50mV p-p 1 0.001 0 0.5 1.0 1.5 2.0 2.5 Instaneous Forward Voltage (V) 0.1 1.0 10 100 Reverse Voltage (V) Peak Forward Surage Current (A) Fig.6 Maximum Non-Repetitive Peak Forward Surage Current 120 100 80 60 40 20 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2016.12 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 ES3AF THRU ES3JF Jingdao Microelectronics PACKAGE OUTLINE Plastic surface mounted package; 2 leads SMAF ∠ALL ROUND C A ∠ALL ROUND HE g Top View mil Bottom View A C D E e g HE max 1.2 0.20 3.7 2.7 1.6 1.2 4.9 min 0.9 0.12 3.3 2.4 1.3 0.8 4.4 max 47 7.9 146 106 63 47 193 min 35 4.7 130 94 51 31 173 UNIT mm g pad e E A pad D E A V M 7° The recommended mounting pad size Marking Type number 2.2 (86) 1.6 (63) 1.8 (71) 1.6 (63) mm Unit : (mil) 2016.12 ∠ JD612058B0 Marking code ES3AF ES3A ES3BF ES3B ES3CF ES3C ES3DF ES3D ES3EF ES3E ES3GF ES3G ES3JF ES3J Page 3 of 3
ES3JF
物料型号为 ES3AF 至 ES3JF,是山东晶导微电子有限公司生产的表面安装超快速恢复整流器。
以下是该器件的详细信息:
- 器件简介:适用于表面贴装应用,具有低轮廓封装、玻璃钝化芯片结、超快速反向恢复时间和符合欧盟RoHS 2011/65/EU指令的无铅特性。
- 引脚分配:1号引脚为阴极,2号引脚为阳极。
- 参数特性:包括最大重复峰值反向电压(VRRM)、最大有效值电压(VRMS)、最大直流阻断电压(Voc)、最大平均正向整流电流(IF(AV))、峰值正向浪涌电流(IFSM)、最大正向电压(VF)、最大直流反向电流(IR)、典型结电容(Cj)、最大反向恢复时间(trr)和典型热阻(ROJA Rec)。
- 功能详解:提供了反向恢复时间特性和测试电路图、最大平均正向电流额定值、典型反向特性、典型正向特性、典型结电容和最大非重复峰值正向浪涌电流的图表。
- 应用信息:适用于单相半波60Hz的电阻性或感性负载。
- 封装信息:塑料表面贴装封装,2个引脚,提供了封装的详细尺寸和推荐的安装垫尺寸。
以上信息摘自提供的PDF文档。
ES3JF 价格&库存
很抱歉,暂时无法提供与“ES3JF”相匹配的价格&库存,您可以联系我们找货
ES3JF
  • 20+0.25231
  • 300+0.19204
  • 1200+0.18916
  • 3000+0.18349
库存:1720
