PESDHC2FD4V5BH
Bi-directional 4.5V High Capacitance ESD Protector
Description
The PESDHC2FD4V5BH protects sensitive semiconductor components from
damage or upset due to electrostatic discharge (ESD) and other voltage
induced transient events. They feature large cross-sectional area junctions
for
conducting
high
transient
currents,
offer
desirable
electrical
characteristics for board level protection, such as fast response time, low
operating voltage. It gives designer the flexibility to protect one bi-directional
line in applications where arrays are not practical.
DFN1006-2L(Bottom View)
Feature
500W peak pulse power per line (tP = 8/20μs)
DFN1006-2L package
Replacement for MLV(0402)
Bidirectional configurations
Response time is typically < 1ns
Low clamping voltage
RoHS compliant
Transient protection for data lines to
Pin 1
Pin 2
Circuit Diagram
IEC61000-4-2(ESD) ±30KV(air), ±30KV(contact);
IEC61000-4-4 (EFT) 40A (5/50ns)
IEC61000-4-5 (Surge) 36A (8/20us)
Applications
Cellular phones
Portable devices
Digital cameras
Power supplies
22
Marking (Top View)
Mechanical Characteristics
Lead finish:100% matte Sn(Tin)
Mounting position: Any
Qualified max reflow temperature:260℃
Device meets MSL 1 requirements
Pure tin plating: 7 ~ 17 um
Pin flatness:≤3mil
Rev.06.2
1
www.prisemi.com
ESD Protector
PESDHC2FD4V5BH
Electronics Parameter
Symbol
VRWM
IR
I
Parameter
IPP
Peak Reverse Working Voltage
Reverse Leakage Current @ VRWM
VTRIG
Reverse trigger Current
VHOLD
Reverse holding voltage
VC
IT
Test Current
IPP
Maximum Reverse Peak Pulse Current
VC
Clamping Voltage @ IPP
PPP
Peak Pulse Power
CJ
Junction Capacitance
IF
Forward Current
VF
Forward Voltage @ IF
VHOLD
VTRIG VRWM
IT
IR
IR
IT
VRWM
VC
VTRIG
VHOLD
IPP
Electrical characteristics per line@25℃ (unless otherwise specified)
Parameter
Symbol
Conditions
Min.
VRWM
Reverse trigger voltage
VTRIG
ITRIG=2uA
4.7
VHOLD
IHOLD=50mA
4.6
IR
VRWM = 4.5V T=25℃
IPP
Clamping Voltage
VCL
IPP=16A
Clamping Voltage
VC
Clamping Voltage
Typ.
Max.
Units
4.5
V
V
1.0
μA
36
A
tp=100ns
6
V
IPP=1A
tP = 8/20μs
4.8
5.8
V
VC
IPP=20A
tP = 8/20μs
10
13
V
Clamping Voltage
VC
IPP=36A
tP = 8/20μs
14
18
V
Cj
VR=0V
80
90
pF
f = 1MHz
70
Absolute maximum rating@25℃
Rating
Symbol
Value
Units
Peak Pulse Power (tp=8/20μs)
Ppp
500
W
Operating Temperature
TJ
-55 to 150
TSTG
-55 to 150
Storage Temperature
Rev.06.2
2
www.prisemi.com
V
ESD Protector
PESDHC2FD4V5BH
tf=8μs
100
100
80
60
% Of Rated Power
IPP – Peak Pulse Current - % of
IPP
Typical Characteristics
tP =20μs(IPP /2)
40
60
40
10
15
Fig 1.Pulse Waveform
125
150
125
150
Z0=50Ω
tr=2ns
tp=100ns
12
16
4
IR(nA)
TLP Current(A)
100
Fig 2.Power Derating Curve
12
8
4
-12
-4
8
TLP Voltage(v)
25
50
75
100
Temperature (ºC)
Fig 3.TLP Measurement
Fig 4.Typical Leakage Current vs. Temperature
10000
20.0
Pulse waveform: tp=8/20us
15.0
Peak Pulse Power (W)
VC-Clamping Voltage (V)
75
TL – Lead Temperature - ℃
t - Time -μs
-20
50
10.0
5.0
19
28.5
38
100
10
1
10
100
1000
Pulse Duration(us)
IPP-Peak pulse current (A)
Fig 5. Clamping voltage vs. Peak pulse current
Rev.06.2
1000
3
Fig 6. Non-Repetitive Peak Pulse Power vs. Pulse time
www.prisemi.com
ESD Protector
PESDHC2FD4V5BH
Solder Reflow Recommendation
Peak Temp=257℃, Ramp Rate=0.802deg. ℃/sec
280
240
200
160
120
80
40
60
90
120
150
180
210
240
270
300
330
360
390
420
450
480
Time (sec)
PCB Design
For TVS diodes a low-ohmic and low-inductive path to chassis earth is absolutely mandatory in order to achieve good ESD
protection. Novices in the area of ESD protection should take following suggestions to heart:
Do not use stubs, but place the cathode of the TVS diode directly on the signal trace.
Do not make false economies and save copper for the ground connection.
Place via holes to ground as close as possible to the anode of the TVS diode.
Use as many via holes as possible for the ground connection.
Keep the length of via holes in mind! The longer the more inductance they will have.
Rev.06.2
4
www.prisemi.com
ESD Protector
PESDHC2FD4V5BH
Product dimension (DFN1006-2L)
A
Dim
B
C
R
D
E
Millimeters
MIN
MAX
MIN
MAX
A
0.013
0.020
0.34
0.50
B
0.000
0.002
0.00
0.05
C
0.037
0.043
0.95
1.080
D
0.022
0.027
0.55
0.680
E
0.016
0.024
0.40
0.60
F
0.008
0.012
0.20
0.30
H
R
F
Inches
0.015Typ.
0.001
0.005
0.40Typ.
0.05
0.15
H
1.10
0.60
0.40
Unit:mm
Suggested PCB Layout
Ordering information
Device
Package
Reel
Shipping
PESDHC2FD4V5BH
DFN1006-2L (Pb-Free)
7"
10000 / Tape & Reel
Rev.06.2
5
www.prisemi.com
ESD Protector
PESDHC2FD4V5BH
Load with information
USER DIRECTION OF FEED
Φ1.50 ± 0.10
2.00 ± 0.05
2.00 ± 0.05
4.00 ± 0.10
1.75 ± 0.10
3.50 ± 0.05
8.00 ± 0.10
Φ0.50 ± 0.05
Unit:mm
Rev.06.2
6
www.prisemi.com
ESD Protector
PESDHC2FD4V5BH
IMPORTANT NOTICE
and
are registered trademarks of Prisemi Electronics Co., Ltd (Prisemi) ,Prisemi
reserves the right to make changes without further notice to any products herein. Prisemi makes
no warranty, representation or guarantee regarding the suitability of its products for any particular
purpose, nor does Prisemi
assume any liability arising out of the application or use of any
product or circuit, and specifically disclaims any and all liability, including without limitation
special, consequential or incidental damages. “Typical” parameters which may be provided in
Prisemi data sheets and/or specifications can and do vary in different applications and actual
performance may vary over time. All operating parameters, including “Typicals” must be
validated for each customer application by customer’s technical experts. Prisemi does not
convey any license under its patent rights nor the rights of others. The products listed in this
document are designed to be used with ordinary electronic equipment or devices, Should you
intend to use these products with equipment or devices which require an extremely high level of
reliability and the malfunction of with would directly endanger human life (such as medical
instruments, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety
devices), please be sure to consult with our sales representative in advance.
Website: http://www.prisemi.com
For additional information, please contact your local Sales Representative.
©Copyright 2009, Prisemi Electronics
is a registered trademark of Prisemi Electronics.
All rights are reserved.
Rev.06.2
7
www.prisemi.com
很抱歉,暂时无法提供与“PESDHC2FD4V5BH”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+0.07603
- 2000+0.05148
- 4000+0.05071
- 10000+0.04504
- 50000+0.03802
