SS1045 THRU SS10200 SMC
Surface Mount Schottky Barrier Rectifier
Pinning
Reverse Voltage - 45 to 200 V
1.Cathode
Forward Current - 10 A
FEATURES
Metal silicon junction, majority carrier conduction
For surface mounted applications
Low power loss, high efficiency
1
2.Anode
2
DO-214AB/SMC
High forward surge current capability
Marking Code
For use in low voltage, high frequency inverters,
SS1045
S1045
SS1060
S1060
Lead free in comply with EU RoHS 2011/65/EU directives
SS10100
S10100
MECHANICAL DATA
Case: DO-214AB/SMC
Terminals: Solderable per MIL-STD-750, Method 2026
SS10200
S10200
free wheeling, and polarity protection applications
Approx. Weight: 0.22g / 0.0077oz
Absolute Maximum Ratings and Electrical characteristics
Ratings at 25 ° ambient temperature unless otherwise specified.Single phase, half wave,
60Hz resistive or inductive load,for capacitive load, derate by 20 %
Symbols
SS1045
SS1060
SS10100
SS10200
Units
Maximum Repetitive Peak Reverse Voltage
VRRM
45
60
100
200
V
Maximum RMS voltage
VRMS
32
42
70
140
V
Maximum DC Blocking Voltage
VDC
45
60
100
200
V
Maximum Average Forward Rectified Current
IF(AV)
Parameter
Peak Forward Surge Current, 8.3ms Single Half Sinewave Superimposed On Rated Load (JEDEC method)
IFSM
Maximum Instantaneous Forward Voltage at 8 A
VF
Maximum Instantaneous Reverse Current TA = 25°C
at Rated DC Reverse Voltage
T A = 100°C
IR
Typical Thermal Resistance
(2)
Operating Junction Temperature Range
Storage Temperature Range
A
10.0
A
200
0.55
0.75
0.90
0.5
50
RθJA
V
mA
°C/W
Tj
-55 ~ +150
°C
Tstg
-55 ~ +150
°C
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.yfwdiode.com
1/3
Dongguan YFW Electronics Co, Ltd.
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( mA)
Fig.1 Forward Current Derating Curve
Average Forward Current (A)
12.0
10.0
8.0
6.0
4.0
2.0
0.0
25
50
75
100
125
150
1000
100
T J =25°C
1
Case Temperature (°C)
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
1
SS1045C
SS1060C
SS10100C
0.1
0.5
1.0
40
80
100
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
T J =100°C
10
1.5
2.0
Instaneous Forward Voltage (V)
Fig.4- Typical Transient Thermal Impedance
100
10
1
0.01
0.1
1
10
100
t, Pulse Duration(sec)
Peak Forward Surage Current (A)
Fig.5 Maximum Non-Repetitive Peak
180
175
150
125
100
75
50
25
8.3 ms Single Half Sine Wave
(JEDEC Method)
00
1
10
100
Number of Cycles at 60Hz
www.yfwdiode.com
2/3
DO-214AB SMC
Package Outline
Plastic surface mounted package; 2 leads
E
A
A1
A
C
b
D
L
E1
VM
A
A
E
D
E1
A1
C
L
b
max
2.62
7.0
6.2
8.0
0.21
0.31
1.6
3.25
min
2.00
6.5
5.6
7.6
0.05
0.15
0.9
2.75
max
103
276
244
315
8.3
12
63
128
min
79
256
220
299
2.0
5.9
35
108
UNIT
mm
mil
The recommended mounting pad size
4.1
(160)
3.8
(150)
4.3
(170)
4.1
(160)
mm
Unit :
(mil)
Summary of Packing Options
Package
DO-214AB SMC
www.yfwdiode.com
Packing Description
Packing Quantity
Industry Standard
Tape/Reel,13”reel
3000
EIA-481-1
3/3
很抱歉,暂时无法提供与“SS10100”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 50+1.18335
- 500+1.06501
- 5000+0.98612
- 10000+0.94668
- 30000+0.90723
- 50000+0.88357
- 国内价格
- 5+1.44008
- 50+1.18628
- 150+1.07752
- 500+0.94176
- 3000+0.88128
- 6000+0.84500
